Re: TWIN TURBO 1800+HP Dodge Dart Swinger [Re: theraif] #1922202
09/30/15 12:27 AM
09/30/15 12:27 AM
toronto
6PAK70CUDA Offline
6PAK70CUDA  Offline
toronto
How cool is that! I love the $150 car bit. I was saying to myself 1.22 in the 60ft is pretty soft and then I see the result of applying more power on the launch: the weakest link breaks (trans in this case). Good luck to you guys and hope you get the trans issues sorted out.
Re: TWIN TURBO 1800+HP Dodge Dart Swinger [Re: theraif] #1922294
09/30/15 08:01 AM
09/30/15 08:01 AM
Mo.
racerx Offline
racerx  Offline
Mo.
so were the entire group of guys hanging around it!
Yes they were thumbs
Re: TWIN TURBO 1800+HP Dodge Dart Swinger [Re: theraif] #1922340
09/30/15 10:13 AM
09/30/15 10:13 AM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Efidart if you dont mind sharing alittle info what size rear tire are you planting to the pavement? Also whats your launch rpm and boost psi,and lastly all in boost psi?
Im in the process of building a tamer version of what you guys have in the dart. Im hoping my junk will make around 1200rwhp on about 12psi. But only time will tell
Thanks in advance
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: TWIN TURBO 1800+HP Dodge Dart Swinger [Re: turbo toad] #1922344
09/30/15 10:22 AM
09/30/15 10:22 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Not sure exactly TT, but it's big!
213hrd-150900-faces-of-drag-week-2015-racers-portraits - Copy.jpgdrag-week-2015-day-3-action-40 - Copy.jpg
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: TWIN TURBO 1800+HP Dodge Dart Swinger [Re: theraif] #1922348
09/30/15 10:33 AM
09/30/15 10:33 AM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Thanks moparbilly ill add those pics to my archive. Man that dart leaves hard! drive
Sorry to hear about your accident will hope for a speedy recovery
Re: TWIN TURBO 1800+HP Dodge Dart Swinger [Re: theraif] #1923051
10/01/15 04:49 AM
10/01/15 04:49 AM
AB
E
Efidart Offline
Efidart  Offline
E
AB
Thanks for the kind words, the car has always been a work in progress.
I used to run a single 118 mm turbo before with victor heads on the same shortblock, made 1550 rwhp and ran 7.90 all day with ease.
Hoping to get a 1.15-1.18 short time out of it when its turned up. I need to add more bite to the car off the line as it spins before it lifts the tires on initial hit. Usually was launching at 4800 and 4-5lbs boost and it seemed to like it there, 5000 is a little much.
Tires are 33x16-15 hoosiers, I've also ran the 33x18.50 ET streets with good results also.
All in boost didn't matter between 14-20 lbs for ET. It drove through the converter faster with 20 lbs so we just left it around 17-18 so it didn't put too much heat into the trans. Will be nice to see RPM drop and it to pickup ET and MPH when it actually starts locking up harder.
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
