727 / Powerglide: Parasitic HP loss differences? #192006
01/13/09 12:15 AM
01/13/09 12:15 AM
Utah
topbrent Offline OP
topbrent  Offline OP
Utah
As the title states...
What is the average HP loss difference between a basic bracket prepped powerglide and a basic performance manual VB 727.
Or put a different way...how much less power does a Powerglide eat vs a 727.
Let's not make this a comparison between PG's and a super-man 727 with every trick known to man...or a pro-trans 904 stuffed into a 727's shorts.
Basic 727 to basic powerglide.
Also, does anyone know the weight difference between a 'glide and a 727?
What does a 727(no converter) dry weigh?
PG's weigh around 95-100 lbs, I think.
Re: 727 / Powerglide: Parasitic HP loss differences? [Re: topbrent] #192007
01/13/09 01:06 AM
01/13/09 01:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I seen some info on this a few years back and if I
recall the glide used the least amount of power
and the 727 was 2nd worst(the ford trans was worst)
and I want to say there was 35hp difference between
the glide and 727
Re: 727 / Powerglide: Parasitic HP loss differences? [Re: MR_P_BODY] #192008
01/13/09 01:42 AM
01/13/09 01:42 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
powerglide....18 hp
904...........24 hp
c4............24 hp
727 ..........45 hp
400 ..........45 hp
c6.............63 hp
this is what i remember...
Tony
70 AARCuda Vitamin C
Re: 727 / Powerglide: Parasitic HP loss differences? [Re: 70AARcuda] #192009
01/13/09 09:00 AM
01/13/09 09:00 AM
gregsdart Offline
gregsdart  Offline
It would be fun to do a real honest test of this, and i think the only way would be to use a stock glide, a stock 727, then run a given amount of torque through them and see just how much torque is measured coming out. That way it could be converted to a percentage and be given for each gear, which i think is important. Weight differance should be about fifty pounds stock, thirty totally moded 727?
Re: 727 / Powerglide: Parasitic HP loss differences? [Re: gregsdart] #192010
01/13/09 09:05 AM
01/13/09 09:05 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
I wonder how much HP a 833 manual trans uses, compared to the automatics
Re: 727 / Powerglide: Parasitic HP loss differences? [Re: gregsdart] #192011
01/13/09 12:24 PM
01/13/09 12:24 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
If someone has the transmissions and a test vehicle and willing to do the swap I'll provide some help, the lift, tools and dyno at no charge. I'm also interested in the REAL answer to this question.....
Re: 727 / Powerglide: Parasitic HP loss differences? [Re: 1badx] #192012
01/13/09 01:00 PM
01/13/09 01:00 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I thought I had read that the 904 was 27 & 727 was 37,would be nice to see real numbers that were recent.
Mitch
Re: 727 / Powerglide: Parasitic HP loss differences? [Re: topbrent] #192013
01/13/09 04:36 PM
01/13/09 04:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
These numbers are from an article in Car Craft Magazine.
Powerglide_____18 hp
TH-350________36 hp
TH-400________44 hp
Ford_C-6______55-60 hp
Ford_C-4______28 hp
Ford_FMX______25 hp
Chrysler_A904__25 hp
Chrysler_727___45 hp
Re: 727 / Powerglide: Parasitic HP loss differences? [Re: John_Kunkel] #192014
01/13/09 04:39 PM
01/13/09 04:39 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
i was close...LOL
was doing them off of memory...
Tony
Re: 727 / Powerglide: Parasitic HP loss differences? [Re: 1badx] #192015
01/13/09 08:03 PM
01/13/09 08:03 PM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
Since you are planning to do this in a car, how do you plan to get a glide converter and a 727 converter to be exactly the same to make this test accurate?
Re: 727 / Powerglide: Parasitic HP loss differences? [Re: SCDaytona] #192016
01/13/09 08:38 PM
01/13/09 08:38 PM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
I know this sounds stupid but I believe there is such a thing as a transmission dyno for testing trannies.ie you wouldnt need a convertor just drives off a electric motor I believe.
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: 727 / Powerglide: Parasitic HP loss differences? [Re: SCDaytona] #192017
01/13/09 10:20 PM
01/13/09 10:20 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Good point! So much for that idea......
Re: 727 / Powerglide: Parasitic HP loss differences? [Re: Mopar_racer_99] #192018
01/13/09 10:31 PM
01/13/09 10:31 PM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
Bingo. We have a winner. It has already been done and the numbers posted probably came from this kind of testing.
Re: 727 / Powerglide: Parasitic HP loss differences? [Re: SCDaytona] #192019
01/14/09 01:30 AM
01/14/09 01:30 AM
Ontario Canada
Hutch Offline
Hutch  Offline
Ontario Canada
Its almost impossible to accurately answer this question. In the past some numbers were issued to it but how they came up with the numbers is beyond me.
There are too many variables, including converter design , converter charge circuits, trans ratio , axle ratio, vehicle weight , motor max RPM, shift rpm.
Some transmissions in some applications will take more power to run but you can't just say its 20hp VS a glide, no way.
The losses will be greater if the parts used in the trans are a larger diameter , so all we can say for sure is the smaller the diameter of the parts used , the less power the transmission will require to run and thats about as far as it goes.
Don't assume that because one trans is heavier than another , that its all rotating weight either.
The powerglide is an efficient design and the internals come to speed progressively ,all 3 speeds have anti rotation to deal with (parts have to reverse then stop then start again) for a shift sequence and that takes time and power to do.
Hutch
Re: 727 / Powerglide: Parasitic HP loss differences? [Re: Hutch] #192020
01/14/09 10:19 AM
01/14/09 10:19 AM
gregsdart Offline
gregsdart  Offline
Hutch
Hutch, thanks for the great input. A lot of us forget the little details(!) like reverse rotation, shaft diameters, circuitry, converter type and from what i have read the ability to build a better converter for a glide due to space limitations that plague a torqueflite. All in all, both have a place.
In your opinion, what would be the most efficient three or more speed system (high $$ OK) to build? Lenco with converter? similar?
Re: 727 / Powerglide: Parasitic HP loss differences? [Re: gregsdart] #192021
01/15/09 12:49 AM
01/15/09 12:49 AM
Ontario Canada
Hutch Offline
Hutch  Offline
Ontario Canada
Hutch, A lot of us forget the little details(!) like reverse rotation, shaft diameters, circuitry, converter type and from what i have read the ability to build a better converter for a glide due to space limitations that plague a torqueflite. All in all, both have a place.
If you were not restricted , the most efficient would be to use a converter drive with a Liberty.
There are a few designs of converter drives out there and I really can't give any of them the thumbs up but a Bruno can be reworked to perform well.
Hutch
