Re: 727 / Powerglide: Parasitic HP loss differences?
[Re: topbrent]
#192007
01/13/09 01:06 AM
01/13/09 01:06 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I seen some info on this a few years back and if I recall the glide used the least amount of power and the 727 was 2nd worst(the ford trans was worst) and I want to say there was 35hp difference between the glide and 727 ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#192008
01/13/09 01:42 AM
01/13/09 01:42 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
powerglide....18 hp 904...........24 hp c4............24 hp 727 ..........45 hp 400 ..........45 hp c6.............63 hp
this is what i remember...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#192009
01/13/09 09:00 AM
01/13/09 09:00 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
It would be fun to do a real honest test of this, and i think the only way would be to use a stock glide, a stock 727, then run a given amount of torque through them and see just how much torque is measured coming out. That way it could be converted to a percentage and be given for each gear, which i think is important. Weight differance should be about fifty pounds stock, thirty totally moded 727?
[Re: topbrent]
#192013
01/13/09 04:36 PM
01/13/09 04:36 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
These numbers are from an article in Car Craft Magazine.
Powerglide_____18 hp TH-350________36 hp TH-400________44 hp Ford_C-6______55-60 hp Ford_C-4______28 hp Ford_FMX______25 hp Chrysler_A904__25 hp Chrysler_727___45 hp
[Re: John_Kunkel]
#192014
01/13/09 04:39 PM
01/13/09 04:39 PM
70AARcuda
las vegas
i was close...LOL
was doing them off of memory...
Tony
[Re: 1badx]
#192015
01/13/09 08:03 PM
01/13/09 08:03 PM
Posts: 488 Charleston, SC
SCDaytona
Charleston, SC
If someone has the transmissions and a test vehicle and willing to do the swap I'll provide some help, the lift, tools and dyno at no charge. I'm also interested in the REAL answer to this question.....
Since you are planning to do this in a car, how do you plan to get a glide converter and a 727 converter to be exactly the same to make this test accurate?
[Re: SCDaytona]
#192016
01/13/09 08:38 PM
01/13/09 08:38 PM
Posts: 976 Woodstock , Georgia
Mopar_racer_99
Woodstock , Georgia
I know this sounds stupid but I believe there is such a thing as a transmission dyno for testing trannies.ie you wouldnt need a convertor just drives off a electric motor I believe.
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
[Re: SCDaytona]
#192017
01/13/09 10:20 PM
01/13/09 10:20 PM
Posts: 411 Portersville, Pa
1badx
Portersville, Pa
Good point! So much for that idea......
[Re: Mopar_racer_99]
#192018
01/13/09 10:31 PM
01/13/09 10:31 PM
SCDaytona
Charleston, SC
Bingo. We have a winner. It has already been done and the numbers posted probably came from this kind of testing.
[Re: SCDaytona]
#192019
01/14/09 01:30 AM
01/14/09 01:30 AM
Posts: 296 Ontario Canada
Hutch
Ontario Canada
Its almost impossible to accurately answer this question. In the past some numbers were issued to it but how they came up with the numbers is beyond me. There are too many variables, including converter design , converter charge circuits, trans ratio , axle ratio, vehicle weight , motor max RPM, shift rpm. Some transmissions in some applications will take more power to run but you can't just say its 20hp VS a glide, no way. The losses will be greater if the parts used in the trans are a larger diameter , so all we can say for sure is the smaller the diameter of the parts used , the less power the transmission will require to run and thats about as far as it goes. Don't assume that because one trans is heavier than another , that its all rotating weight either. The powerglide is an efficient design and the internals come to speed progressively ,all 3 speeds have anti rotation to deal with (parts have to reverse then stop then start again) for a shift sequence and that takes time and power to do.
Hutch
[Re: Hutch]
#192020
01/14/09 10:19 AM
01/14/09 10:19 AM
gregsdart
Hutch
Hutch, thanks for the great input. A lot of us forget the little details(!) like reverse rotation, shaft diameters, circuitry, converter type and from what i have read the ability to build a better converter for a glide due to space limitations that plague a torqueflite. All in all, both have a place. In your opinion, what would be the most efficient three or more speed system (high $$ OK) to build? Lenco with converter? similar?
