Re: Hemi valve cover gaskets, what do you use?
[Re: OUTLAWSSAA]
#1920004
09/26/15 12:06 PM
09/26/15 12:06 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Those Fel-Pro 1657 won't work on a stamped steel valve cover. There made for cast aluminium valve covers. You need to use either cork or something thick.(neoprene) Your only option is the cork & rubber for the stamped steel valve covers. It's very easy to over torque the bolts and bend the sealing flange with the cork & rubber gaskets. Be sure and take the time to check and correct where necessary or you may continue to have leaks even with new gaskets. We offer a quality gasket for your application also Superformance Products
[Re: roadhazard]
#1920375
09/27/15 12:42 AM
09/27/15 12:42 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I have changing out all my gaskets to SUPERPERFORMANCE.Ordered 2 oil pan,4 waterpump, and4 carb base and an intake.Best feeling gaskets I have found.
[Re: OUTLAWSSAA]
#1920584
09/27/15 01:47 PM
09/27/15 01:47 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
Those Fel-Pro 1657 won't work on a stamped steel valve cover. There made for cast aluminium valve covers. You need to use either cork or something thick.(neoprene) Oops. Sorry. I never use stamped steel valve covers.
