Hemi valve cover gaskets, what do you use? #1919740
09/25/15 09:20 PM
09/25/15 09:20 PM
Big Western Pencilveinya
U
Uncle Barry Offline OP
U
Got my hemi running. Seems to run AWESOME! But I can't get my covers to seal up. I'm using the stamped steel chrome covers and wondering what you folks use for gaskets? I have cork ones in it now. Any info you folks can share with me? Thanks
Re: Hemi valve cover gaskets, what do you use? [Re: Uncle Barry] #1919753
09/25/15 09:46 PM
09/25/15 09:46 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
FEL-PRO Blue gaskets for me. the thickest ones you can get.
Re: Hemi valve cover gaskets, what do you use? [Re: Sammy] #1919795
09/25/15 10:51 PM
09/25/15 10:51 PM
California
mickm Offline
mickm  Offline
California
i'll need to look. i use the felpro, but i'm not sure about the blue. i even need to double mine up so the stock valve covers clear the rockers, and they seal perfectly!
Re: Hemi valve cover gaskets, what do you use? [Re: Uncle Barry] #1919797
09/25/15 10:54 PM
09/25/15 10:54 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Fel-Pro 1657
Re: Hemi valve cover gaskets, what do you use? [Re: Uncle Barry] #1919880
09/26/15 01:16 AM
09/26/15 01:16 AM
U
U
Thanks guys! Looks like a summit trip in the morning thumbs
Re: Hemi valve cover gaskets, what do you use? [Re: Uncle Barry] #1919889
09/26/15 01:35 AM
09/26/15 01:35 AM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Those Fel-Pro 1657 won't work on a stamped steel valve cover. There made for cast aluminium valve covers. You need to use either cork or something thick.(neoprene)
Re: Hemi valve cover gaskets, what do you use? [Re: Uncle Barry] #1919904
09/26/15 02:20 AM
09/26/15 02:20 AM
Make sure that the bottom lip is flat and not pull down much around the bolt holes scope up Dang them Hemiroid problems whistling shruggy
Re: Hemi valve cover gaskets, what do you use? [Re: Uncle Barry] #1919942
09/26/15 08:59 AM
09/26/15 08:59 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Call Super Performance.
Re: Hemi valve cover gaskets, what do you use? [Re: OUTLAWSSAA] #1920004
09/26/15 12:06 PM
09/26/15 12:06 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
iagree
Your only option is the cork & rubber for the stamped steel valve covers.
It's very easy to over torque the bolts and bend the sealing flange with the cork & rubber gaskets. Be sure and take the time to check and correct where necessary or you may continue to have leaks even with new gaskets.
We offer a quality gasket for your application also
Superformance Products
Re: Hemi valve cover gaskets, what do you use? [Re: roadhazard] #1920375
09/27/15 12:42 AM
09/27/15 12:42 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have changing out all my gaskets to SUPERPERFORMANCE.Ordered 2 oil pan,4 waterpump, and4 carb base and an intake.Best feeling gaskets I have found.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hemi valve cover gaskets, what do you use? [Re: Uncle Barry] #1920511
09/27/15 11:49 AM
09/27/15 11:49 AM
wappinger falls new york
Jimi_Vignogna Offline
I have the $200.00 ebay sheet metal hemi covers, had to machine the sealing surface .080" to make them flat and use the felpro blue cover gasket . no leaks.
Re: Hemi valve cover gaskets, what do you use? [Re: OUTLAWSSAA] #1920584
09/27/15 01:47 PM
09/27/15 01:47 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Oops. Sorry. I never use stamped steel valve covers.
