Page 4 of 12 1 2 3 4 5 6 11 12
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1918802
09/24/15 02:54 PM
09/24/15 02:54 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I'm a bit concerned about what looks to be a casting flaw in that threaded hole in the pass side valley wall...
Re: 420cid build with a new Ritter Aluminum Block [Re: TRENDZ] #1918809
09/24/15 02:58 PM
09/24/15 02:58 PM
Kansas, Topeka
69 lawndart Offline OP
Kansas, Topeka
Yes sir there was a problem with the pipe threads on the inside lifter wall, we just drilled them out and tapped them to 1/2 NPT. the original size was 3/8NPT.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1918867
09/24/15 04:15 PM
09/24/15 04:15 PM
Kansas, Topeka
Kansas, Topeka
I just got an E-mail back from Kent If you need his Contact information just send me a message and I will send you the information.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1919221
09/25/15 12:23 AM
09/25/15 12:23 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
good/bad otherwise I hope you stick with us on this build. We've seen one guy years ago "promise" that he was going to make a iron block work and stated that there were a "few" running in dirt track cars although no proof was ever uncovered.... that never happened. We've lived Whitedart's he77 with his build (only running one that I know of....and BOY does it!!). Luckily he had a very qualified builder that saw it through. We had the aluminum "prototype" build that seemingly almost made it, but some failure set it back and iirc, life got in the way and it got shoved to the corner....or something. I wish you the best... there are A LOT of really good head packages out there needing a good foundation. I was so dangerously close to getting an iron Ritter block in 12.... but being I work at a dealer, a couple of guys REALLY leaned on my to go the R3 route so I did.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1919234
09/25/15 12:46 AM
09/25/15 12:46 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Knowing MC like I do he will see this build through.Good or bad.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1919255
09/25/15 01:42 AM
09/25/15 01:42 AM
Kansas, Topeka
Kansas, Topeka
Ok I fixed the rear main oiling hole this evening not to bad just put the main cap in the mill and made a slot to the oil hole in the main line up with the oil pump feed hole.
Yes I will finish this engine, I am taking my time checking everything I can think of. If anyone sees something that there might be a question on please say something. I figure out some way to check it.
rear main cap
main cap 2
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1919271
09/25/15 02:52 AM
09/25/15 02:52 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Having seen both of Whitedart's iron blocks machine work as delivered I have to say CHECK EVERY surface, bolt hole, treaded plug, etc.
Alot of things were not drilled/tapped streight, machined parallel or to size. Brad at QMP saved his block, most shops would have scrapped it.
Yours looks like a cool build, and I hope it all plays well for you.
"Just a Bracket car dressed up like a streetcar"
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1919367
09/25/15 12:00 PM
09/25/15 12:00 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
"I have a set of W9's on my other R3 block (468 cid) with 59 deg lifter angle. That set of heads is a set of Chapman done heads and they are to small for that motor it gives up at 6800 but it pulls hard in the mid range.
This one is going to get the W9RP that Curtis Boggs from RFD did."
Curious, what kinda flow numbers does a Chapman W9RP have to choke off a 468ci at 6800? work
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1919381
09/25/15 12:24 PM
09/25/15 12:24 PM
Kansas, Topeka
Kansas, Topeka
The Heads on the 468 are standard W9's done by Champman, they flow in the 360 CFM range at .700 lift through the intake and throttle body. The minimum cross section on W9 heads is small in comparison to the W9RP's.
The heads that are going on this 420 cid motor are W9RP done by Curtis Boggs at RFD and they flow well over 425 CFM at .800 lift and continue to flow better up to 1" lift. The W9RP will not fit on the 59 deg motor because the rocker offset is not enough, the pushrod will hit the head.
Re: 420cid build with a new Ritter Aluminum Block [Re: Just-a-dart] #1919384
09/25/15 12:32 PM
09/25/15 12:32 PM
Kansas, Topeka
Kansas, Topeka
Thanks for the information. I have assembled all of the heads, head studs and valve train the only thing I have not put on the motor yet is the clutch and bellhousing that will need to be indexed in, that is a standard thing I do on all of my motors, and the timing cover and water pump.
Thanks for all of the input on this build.
Mike
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1919411
09/25/15 01:05 PM
09/25/15 01:05 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I'm more than happy to share any information that I have gained. I will say that these motors have a tendency to have oil drain back issues crankcase pressure going up kind of prevent oil from going down. I also drill through the china wall into the timing case area to help vent the crankcase I also enlarge the oil drain backs in the front and and back . And drilled for 1/8 holes cam tunnel
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: 420cid build with a new Ritter Aluminum Block [Re: WHITEDART] #1919419
09/25/15 01:20 PM
09/25/15 01:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are these blocks setup for a dry sump? sounds like
a dry sump would be a better way to go with the drain
back and pressure issues
wave
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1919431
09/25/15 01:33 PM
09/25/15 01:33 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Finaly a good technical post again:D
Re: 420cid build with a new Ritter Aluminum Block [Re: WHITEDART] #1919471
09/25/15 02:10 PM
09/25/15 02:10 PM
Kansas, Topeka
Kansas, Topeka
Yes I agree that is why I drilled and tapped 4 of 1/2 NPT holes in the cam valley right next to the cam bearing main. To try and get the oil drain back to the crankcase. I also plan on putting my vacuum pump on the fuel pump plate in the timing cover. My logic is to make the crankcase lower pressure than the top end and kinda pull the oil and vapor through the holes and drain backs. Thanks for the input.
Re: 420cid build with a new Ritter Aluminum Block [Re: MR_P_BODY] #1919472
09/25/15 02:12 PM
09/25/15 02:12 PM
Kansas, Topeka
Kansas, Topeka
wave
I think you are correct on this one, but since this is a street/race car in a stock chassis I don't have the room for a dry sump.
Re: 420cid build with a new Ritter Aluminum Block [Re: 1Fast340] #1919529
09/25/15 03:32 PM
09/25/15 03:32 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
iagree drive
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1919862
09/26/15 12:41 AM
09/26/15 12:41 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Originally Posted By 69 lawndart
At this point in time that is the plan, I saw you and was wanting to get over and talk to you and see what you have updated on the car. I hope to have this thing back in the car by the end of the year. That gives me all of next year to sort it out. I have talked to some of the guys that have had problems with these blocks and so far most of the major problems were fixed when I got the block. There have been a few small things but nothing major.
Mike
Mike,
The car is Clark's (Bad340Fish above). I am his dad, road flunky and navigator. We did not hang around long at Cordova, we wanted to beat the rain out of town.
This is going to be an epic thread, keep it going.
Thanks,
Bill
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1919870
09/26/15 12:58 AM
09/26/15 12:58 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Just keep that Grandson watching those videos I shared of MC. Say no to the bowtie stuff Bill. LOL.DW is a blur and its hard to talk to everyone.I "Think" I waved at you once and talked to Clark for 20 seconds.LOL.Glad to follow this build and I have not seen anything. LOL
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1922965
10/01/15 12:27 AM
10/01/15 12:27 AM
Kansas, Topeka
Kansas, Topeka
OK, since I am waiting on the new head gaskets to show up, I assembled the top end with all of the studs, heads, rockers and used gaskets,so far everything is fitting up nice.
rockers
intake side
lifters
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1922993
10/01/15 01:17 AM
10/01/15 01:17 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
drive
