Re: 1972 Cuda Power to manual conversion question.
[Re: Benforsp]
#1918289
09/23/15 07:14 PM
09/23/15 07:14 PM
Posts: 860 lancaster,california
johnnycuda
I converted my '70 Cuda to manual 20 years ago, but I used a manual box from a parts car slant 6 '70 Barracuda, I just ordered a pitman arm from Summit, for a Barracuda, and was not asked if it was power or manual steering, plan to change it and the idler arm this weekend. The company was Proforged Chassis, part # 103-10030.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: Benforsp]
#1918817
09/24/15 03:07 PM
09/24/15 03:07 PM
johnnycuda
I called Proforged this morning to ask, because I'd rather find out there is a difference before taking it apart, then finding out. The tech said '70-'72 E-body used a smaller sector shaft, after '73 it was larger. By the way, I had also ordered a pitman for the Valiant I'm building, and it was a different part number from the E-body, so the A-body pitman is different.
[Re: Benforsp]
#1918883
09/24/15 04:44 PM
09/24/15 04:44 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
Hello All,
I don't post often but read a great deal and try and follow along as time allows. Today I had an issue and I am hoping someone can help. I was replacing the power steering box in my 1972 cuda with a manual box and was under the impression the pitman arms were the same. Well I was wrong. The power steering pitman is too large (1.200") vs. the manual box output shaft (1.100"). I assume I need a different pitman? Any idea where I can get one? The manual box was out of a late 60's Dart and the power boz was original to the car. When I look for the part there is not a separate listing for a manual vs. power.
Thanks in advance!
Simon The box must have been changed unless you have a very late build 72 because 73 was the first year for the large output PS box.
