Plymouth Duster Ignition Switch Replacement
#1917925
09/23/15 10:06 AM
09/23/15 10:06 AM
Posts: 607 NY
old340dog
NY
Looks like I have to replace my ignition switch in my duster. I must admit this is unchartered waters for me. So I have questions and am kind of hestitate to do this.Should a knowledgable mechanic do this? There are really no old mopar gurus in my area (central ny)to go too.I've been looking at some manuals and have some questions. Do I need to pull the whole steering column to do this job? Any special tools needed? Any watchouts, do's and don'ts? Thanks for any help.
old340dog
Re: Plymouth Duster Ignition Switch Replacement
[Re: old340dog]
#1918113
09/23/15 03:22 PM
09/23/15 03:22 PM
RapidRobert
#1 before doing ANY electrical work ALWAYS pull a batt cable (either one). you would need a steering wheel puller which are dirt cheap then you'll have easy access to the innards. been awhile & dont remem if there is a pin you depress or what but it wont be difficult at all once you get in there. Go for it!
[Re: RapidRobert]
#1918177
09/23/15 04:48 PM
09/23/15 04:48 PM
Posts: 607 NY
old340dog
NY
I always disconnect the battery on electical work. My concerns are how far do you have to tear the column down or remove stuff before you get to the switch? I know there is a pin to press to get the lockset out. But do I have to drop the column down to be able to get the switch and wiring harness out and the new setup in? None of the books I have cover any of this.
old340dog
[Re: old340dog]
#1918194
09/23/15 05:16 PM
09/23/15 05:16 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If you fold the connector so it is parallel to the wiring it will slide down the column just fine, you don;t need to remove the modex connectors to do that.
