M&H musclecar bias ply tires #1915870
09/19/15 09:53 PM
09/19/15 09:53 PM
wellington ohio
68-scatpack-rt Offline OP
In thin ice
In thin ice
wellington ohio
Hello all.
I'm looking at the M & H bias ply musclecar tires in 275 60 15 for my 68 coronet.
I'm mounting them on an 8 inch steel wheel.
I want the bias ply look as I only drive a few hundred miles per season.
Just to be clear, these are not their "cheater slick" bias ply.
Anyone use these tires?
unions....the folks who brought you the weekend!
Re: M&H musclecar bias ply tires [Re: 68-scatpack-rt] #1915875
09/19/15 10:03 PM
09/19/15 10:03 PM
fullmetaljacket Offline
Believe they are a "Cheater" type tire as I saw a pair the other day at a speed shop.
Re: M&H musclecar bias ply tires [Re: 68-scatpack-rt] #1915878
09/19/15 10:07 PM
09/19/15 10:07 PM
wellington ohio
In thin ice
In thin ice
wellington ohio
M&H makes both "musclecar" bias ply AND a bias ply "cheater slick".
I'm interested in the vintage looking "musclecar" bias ply version.
Re: M&H musclecar bias ply tires [Re: 68-scatpack-rt] #1915881
09/19/15 10:15 PM
09/19/15 10:15 PM
wellington ohio
In thin ice
In thin ice
wellington ohio
Re: M&H musclecar bias ply tires [Re: 68-scatpack-rt] #1915883
09/19/15 10:18 PM
09/19/15 10:18 PM
wellington ohio
In thin ice
In thin ice
wellington ohio
Re: M&H musclecar bias ply tires [Re: 68-scatpack-rt] #1915905
09/19/15 11:10 PM
09/19/15 11:10 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Rob I had a pair like what you are looking at when I first put the Savoy together. I really liked them and they hooked pretty good. They had a profile like a NASCAR tire with a wide sidewall. When I replace my ET Streets I will be buying another set of M&H tires up
Gus beer
64 Plymouth Savoy
Dana 60
Re: M&H musclecar bias ply tires [Re: 68-scatpack-rt] #1915906
09/19/15 11:13 PM
09/19/15 11:13 PM
Those both are Cheaters. One looks the part of a stock tire, but still is a soft compound/limited thread/wrinkle wall tire which constitutes a Cheater.
I could be wrong and just not up to speed on these M&H types.
Re: M&H musclecar bias ply tires [Re: 68-scatpack-rt] #1915907
09/19/15 11:16 PM
09/19/15 11:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By 68-scatpack-rt
May as well be a slick. You realize they are DOT-approved, bias-ply, street-legal tires. These M&H Racemaster muscle car drag tires are ideal for any class that uses a street-type race tire. Other features include state-of-the-art wrinkle wall construction on a black nylon bias-ply carcass.
Ran these for years, back when Protrac made them
http://m.summitracing.com/parts/cok-72146
and in the rain the hydroplaned easily.
Your choice isn't what I would run on a street car, ever. Get off the mobile version and hit the web version of Summit for the details.
Don't be the exception.
Re: M&H musclecar bias ply tires [Re: 68-scatpack-rt] #1915956
09/20/15 01:57 AM
09/20/15 01:57 AM
Lakewood, Colorado
runnerrt Offline
runnerrt  Offline
Lakewood, Colorado
I have the N50-15's of these and they are a cheater. Enough of a rain groove to be DOT and they wrinkle nice. They seem to wear decent and hook pretty well. Don't know if I would want to get caught in the rain with them.
1969 Super Bee High School car I got back 2004 Ram 2500
Re: M&H musclecar bias ply tires [Re: 68-scatpack-rt] #1916018
09/20/15 10:25 AM
09/20/15 10:25 AM
Central NC
gch Offline
gch  Offline
Central NC
I ran a pair years ago on my charger and from what I remember they hooked well and lasted quite a while on a casual driver.
Re: M&H musclecar bias ply tires [Re: gch] #1916050
09/20/15 12:20 PM
09/20/15 12:20 PM
No rain, no pain.
If you want a stock groove, side wall look, I believe Goodyear is now reproducing their famous L-60/G-60 in polyglass form tires. Also as mentioned above, the Pro-Trac tire is a good choice as well.
Re: M&H musclecar bias ply tires [Re: 68-scatpack-rt] #1916172
09/20/15 04:23 PM
09/20/15 04:23 PM
wellington ohio
In thin ice
In thin ice
wellington ohio
Thanks for the replies fellas!
I appreciate the input. I'll respond back when I figure this out and put some tires to use.
Re: M&H musclecar bias ply tires [Re: 68-scatpack-rt] #1916235
09/20/15 06:48 PM
09/20/15 06:48 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We ran those same tires on our 70 Road Runner way back in 1973. They hooked very well even with a 4-speed,and we ran them on a 8" wheel.
Nautilus Racing-
Re: M&H musclecar bias ply tires [Re: 68-scatpack-rt] #1916278
09/20/15 08:02 PM
09/20/15 08:02 PM
wellington ohio
In thin ice
In thin ice
wellington ohio
Which ones Chris?
Re: M&H musclecar bias ply tires [Re: 68-scatpack-rt] #1916463
09/21/15 12:35 AM
09/21/15 12:35 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
http://www.summitracing.com/parts/cok-72146
These are the new version of what I currently have on my RT.
Careful, your character's showing!
Re: M&H musclecar bias ply tires [Re: 68-scatpack-rt] #1917093
09/21/15 11:21 PM
09/21/15 11:21 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
What kind of pressure and burnout procedure do you use on those M+H cheaters? I have 275/60/15 if it matters.
Sorry for the hijack.
Kevin
Re: M&H musclecar bias ply tires [Re: 68-scatpack-rt] #1917745
09/22/15 10:56 PM
09/22/15 10:56 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Which ones Chris?
The same ones you are looking at..the ones with the tread all the way across. Used the same size too,although back then they were listed as a 10.0x28.0. I don't remember if we used tubes,I'm pretty sure we did,my Dad always used them and we screwed the wheels to the tires. All I know is that Road Runner (we still have it) would hook in a car wash with those tires and 3800# S/S springs.
Nautilus Racing-
