4 spd gurus #1915303
09/18/15 10:09 PM
09/18/15 10:09 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Can you identify this 4 spd for me ,still in car , I'm told it has 18 splines.. all the numbers I can find are 640, below that C99539 or C99599 then there is a 33 3..And where can I get a new shifter mechanism for it ....Thanks
Re: 4 spd gurus [Re: dynamite] #1915357
09/18/15 11:17 PM
09/18/15 11:17 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Is there a raised pad on the passenger side? Those are the stamped numbers that we need.
Re: 4 spd gurus [Re: fastmark] #1915373
09/18/15 11:36 PM
09/18/15 11:36 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Thanks ,, I'll get under there. tomorrow and try to see numbers on the rt side
Re: 4 spd gurus [Re: dynamite] #1915392
09/19/15 12:09 AM
09/19/15 12:09 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
You can't always trust the numbers on the pad because I have built a bunch of 18 spline transmissions out of big bearing 23 spline cases. I have also put 23 spline gears into an original small bearing 67 HEMI box. shruggy Sometimes you build whatever you have on the shelf.
Gus beer
64 Plymouth Savoy
Dana 60
Re: 4 spd gurus [Re: fourgearsavoy] #1915833
09/19/15 08:19 PM
09/19/15 08:19 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Got the numbers on the r/t side tab..C99129H..
Re: 4 spd gurus [Re: dynamite] #1915841
09/19/15 08:29 PM
09/19/15 08:29 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Brewer Performance has a break down of transmission # but as fourgearsavoy said it is only a good number if nobody screwed with it.
Re: 4 spd gurus [Re: dynamite] #1916209
09/20/15 05:53 PM
09/20/15 05:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You're posting the raised casting numbers which can't always be used to ID the origins of the trans. Stamped numbers on a raised pad on the right side have the build data.
If no raised pad it's pre-'68.
