4 spd gurus
#1915303
09/18/15 10:09 PM
09/18/15 10:09 PM
Posts: 1,444 NEW JERSEY
dynamite
NEW JERSEY
Can you identify this 4 spd for me ,still in car , I'm told it has 18 splines.. all the numbers I can find are 640, below that C99539 or C99599 then there is a 33 3..And where can I get a new shifter mechanism for it ....Thanks
Re: 4 spd gurus
[Re: dynamite]
#1915392
09/19/15 12:09 AM
09/19/15 12:09 AM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
You can't always trust the numbers on the pad because I have built a bunch of 18 spline transmissions out of big bearing 23 spline cases. I have also put 23 spline gears into an original small bearing 67 HEMI box. Sometimes you build whatever you have on the shelf. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: 4 spd gurus
[Re: dynamite]
#1915841
09/19/15 08:29 PM
09/19/15 08:29 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Brewer Performance has a break down of transmission # but as fourgearsavoy said it is only a good number if nobody screwed with it.
Re: 4 spd gurus
[Re: dynamite]
#1916209
09/20/15 05:53 PM
09/20/15 05:53 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Got the numbers on the r/t side tab..C99129H.. You're posting the raised casting numbers which can't always be used to ID the origins of the trans. Stamped numbers on a raised pad on the right side have the build data. If no raised pad it's pre-'68.
