vibration after holeshot today. need opinions #1911317
09/12/15 10:28 PM
09/12/15 10:28 PM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
Pulled a hard hole shot today, everything went good except when I left of the throttle I had a really bad vibration, I stopped the car, the vibration is going with the engine at engine speed. Couldnt go much over 2500 rpm and its very very noticeable, I still have good oil pressure. And babies it home for about 5 miles. I'm guessing the new B&M flex plate cracked??? I just put it in. Convertor isn't slipping any, this is behind a 440 pushing 500-530 hp. What is the absolute best flex plate I can buy to put in this. I'm guessing / hoping that's the issue so I'm gonna order a new one anyhow if that's not ny problem I can use the extra flex plate anyhow. So guys what are your thoughts about this.
Re: vibration after holeshot today. need opinions [Re: Mally69] #1911344
09/12/15 11:17 PM
09/12/15 11:17 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Have you crawled under it to look for bad u-joints, cracked tailshaft housing or broken motor/transmission mounts? Lot's of things can break on launch. The B&M flex plate is a stout piece, I'd just start with good look around under the car.
Re: vibration after holeshot today. need opinions [Re: Mally69] #1911353
09/12/15 11:31 PM
09/12/15 11:31 PM
jersey
Spaceman Spiff Offline
jersey
so it vibrates with engine rpm? does it in park and neutral?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: vibration after holeshot today. need opinions [Re: Mally69] #1911397
09/13/15 12:38 AM
09/13/15 12:38 AM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
Well never tried it in park only in neutral and drive. It vibrates when I'm setting still in neutral and even worse under slight load, it happened all of a sudden Right as I left off the throttle, I have all brand new engine and tranny mounts. Its Def. Between the crank flange and the tranny. Converter doenst slip any and shifts fine. Just bad vibration worse at 2500-3000 rpm
Re: vibration after holeshot today. need opinions [Re: Mally69] #1911428
09/13/15 01:40 AM
09/13/15 01:40 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Sure it's not in the engine?
Re: vibration after holeshot today. need opinions [Re: Mally69] #1911452
09/13/15 02:04 AM
09/13/15 02:04 AM
Pennsylvania
ColorMeGreen Offline
Pennsylvania
Check the vibration damper for missing rubber.
Re: vibration after holeshot today. need opinions [Re: Mally69] #1911457
09/13/15 02:10 AM
09/13/15 02:10 AM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
It could be in the engine, I won't rule that out totally yet I just re bearinged the bottom end rods and mains this past spring my oil pressure seems normal still , I figured if it was the main bearing vibrating I ( thought ) I would have lost oil pressure , I have a fluid dampner on it now for two years. ,
Re: vibration after holeshot today. need opinions [Re: Mally69] #1911479
09/13/15 03:25 AM
09/13/15 03:25 AM
this might be way off but any possibility it dropped several cyls for whatever reason
Re: vibration after holeshot today. need opinions [Re: Mally69] #1911510
09/13/15 08:40 AM
09/13/15 08:40 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Bet you tore and engine mount. New or not that's the first thing Id check.
Angry white pureblood male
Re: vibration after holeshot today. need opinions [Re: Mally69] #1911554
09/13/15 11:25 AM
09/13/15 11:25 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
My first thoughts are I hoped you looked at your car closely before even posting this on the internet to find out what is wrong.
Then my second thought is I would look at my car closely before I ordered any parts for it.
Can't you just look to see if the flex plate cracked?
It sounds like your motor is out of balance, like a weight flew off of the torque converter or flex plate? Make sure the front of the motor is good( balancer, pulleys). Then I'd pull all 8 plugs and look at them. Hopefully it's not in the motor, but sounds like it.
Re: vibration after holeshot today. need opinions [Re: Mally69] #1911562
09/13/15 11:53 AM
09/13/15 11:53 AM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
If it were in the main bearings i would think id loose oil pressure I'm pretty sure. I have felt bad main bearings it has a deep thumpy vibration, that's kinda how this this, but my oil pressure is good. Is there any possibility that it could be in the converter? It doesn't seem to slip its a tci street fighter 3000-3500 but flashes to 3800 in my build
Re: vibration after holeshot today. need opinions [Re: Mally69] #1911564
09/13/15 11:55 AM
09/13/15 11:55 AM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
Def pulling the tranny out today after looking a bunch of stuff over
Re: vibration after holeshot today. need opinions [Re: Mally69] #1911567
09/13/15 11:57 AM
09/13/15 11:57 AM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
How hard of a holeshot? Hard enough to over-rev and kiss a valve? As stated look over everything carefully, if nothing obvious jumps out at you maybe do a quick compression check. DAMHIK
Old, tired, and sometimes broke down. Me, not my car...
Re: vibration after holeshot today. need opinions [Re: Challenger 1] #1911575
09/13/15 12:06 PM
09/13/15 12:06 PM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
I'm pretty sure I checked all possible easy fixes before posting this, also I posted this to see if anyone else may have had the same issues and could give me insight before I tear everything out. , and I've got so many diff projects going that ordering parts and having stuff on hand that I might not need right now is still going to be used reguardless
Re: vibration after holeshot today. need opinions [Re: Mally69] #1911581
09/13/15 12:19 PM
09/13/15 12:19 PM
interesting topic/sorry for your misfortune. do post what it ends up being
Re: vibration after holeshot today. need opinions [Re: Mally69] #1911595
09/13/15 12:42 PM
09/13/15 12:42 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
What damper?
Re: vibration after holeshot today. need opinions [Re: justinp61] #1911615
09/13/15 12:59 PM
09/13/15 12:59 PM
NJ
rth Offline
rth  Offline
NJ
Check fan blades, I would pull v/covers to check rockers and push rods. Try to determine if it's vibration or miss.
Re: vibration after holeshot today. need opinions [Re: rth] #1911654
09/13/15 02:08 PM
09/13/15 02:08 PM
PA
Mally69 Offline OP
Mally69  Offline OP
PA
The dampner been on it for two years, it's the chrome 440 source fluid dampner
Re: vibration after holeshot today. need opinions [Re: Shoozy] #1911685
09/13/15 02:56 PM
09/13/15 02:56 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
had a friend years ago that broke a connecting rod. The small end was still on the crank swinging around when it was running, yeah it vibrated a bit eek
A compression test will go along ways toward diagnosing the root cause.
Re: vibration after holeshot today. need opinions [Re: Mally69] #1911757
09/13/15 05:40 PM
09/13/15 05:40 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I know it's a long shot, but I had something similar happen to me one time on one of my cars. Pulled hard and starting vibrating and not running right. It turned out a plug wire vibrated off the cap and I was running on 7.
