Re: vibration after holeshot today. need opinions
[Re: Mally69]
#1911353
09/12/15 11:31 PM
09/12/15 11:31 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
so it vibrates with engine rpm? does it in park and neutral?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Mally69]
#1911479
09/13/15 03:25 AM
09/13/15 03:25 AM
RapidRobert
this might be way off but any possibility it dropped several cyls for whatever reason
[Re: Mally69]
#1911510
09/13/15 08:40 AM
09/13/15 08:40 AM
Posts: 5,883 ohio
ruderunner
ohio
Bet you tore and engine mount. New or not that's the first thing Id check.
Angry white pureblood male
[Re: Mally69]
#1911554
09/13/15 11:25 AM
09/13/15 11:25 AM
Challenger 1
Cincinnati, Ohio
Pulled a hard hole shot today, everything went good except when I left of the throttle I had a really bad vibration, I stopped the car, the vibration is going with the engine at engine speed. Couldnt go much over 2500 rpm and its very very noticeable, I still have good oil pressure. And babies it home for about 5 miles. I'm guessing the new B&M flex plate cracked??? I just put it in. Convertor isn't slipping any, this is behind a 440 pushing 500-530 hp. What is the absolute best flex plate I can buy to put in this. I'm guessing / hoping that's the issue so I'm gonna order a new one anyhow if that's not ny problem I can use the extra flex plate anyhow. So guys what are your thoughts about this. My first thoughts are I hoped you looked at your car closely before even posting this on the internet to find out what is wrong. Then my second thought is I would look at my car closely before I ordered any parts for it. Can't you just look to see if the flex plate cracked? It sounds like your motor is out of balance, like a weight flew off of the torque converter or flex plate? Make sure the front of the motor is good( balancer, pulleys). Then I'd pull all 8 plugs and look at them. Hopefully it's not in the motor, but sounds like it.
[Re: Mally69]
#1911567
09/13/15 11:57 AM
09/13/15 11:57 AM
Posts: 9,654 Southern by Choice
Shoozy
I have a foot fetish
Southern by Choice
How hard of a holeshot? Hard enough to over-rev and kiss a valve? As stated look over everything carefully, if nothing obvious jumps out at you maybe do a quick compression check. DAMHIK
Old, tired, and sometimes broke down. Me, not my car...
[Re: Challenger 1]
#1911575
09/13/15 12:06 PM
09/13/15 12:06 PM
Posts: 92 PA
Mally69
PA
Pulled a hard hole shot today, everything went good except when I left of the throttle I had a really bad vibration, I stopped the car, the vibration is going with the engine at engine speed. Couldnt go much over 2500 rpm and its very very noticeable, I still have good oil pressure. And babies it home for about 5 miles. I'm guessing the new B&M flex plate cracked??? I just put it in. Convertor isn't slipping any, this is behind a 440 pushing 500-530 hp. What is the absolute best flex plate I can buy to put in this. I'm guessing / hoping that's the issue so I'm gonna order a new one anyhow if that's not ny problem I can use the extra flex plate anyhow. So guys what are your thoughts about this. My first thoughts are I hoped you looked at your car closely before even posting this on the internet to find out what is wrong. Then my second thought is I would look at my car closely before I ordered any parts for it. Can't you just look to see if the flex plate cracked? It sounds like your motor is out of balance, like a weight flew off of the torque converter or flex plate? Make sure the front of the motor is good( balancer, pulleys). Then I'd pull all 8 plugs and look at them. Hopefully it's not in the motor, but sounds like it. I'm pretty sure I checked all possible easy fixes before posting this, also I posted this to see if anyone else may have had the same issues and could give me insight before I tear everything out. , and I've got so many diff projects going that ordering parts and having stuff on hand that I might not need right now is still going to be used reguardless
[Re: Mally69]
#1911581
09/13/15 12:19 PM
09/13/15 12:19 PM
RapidRobert
interesting topic/sorry for your misfortune. do post what it ends up being
