Where to buy a 10 point socket for a o4 stratus r/t?
#191003
01/11/09 10:23 PM
01/11/09 10:23 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I need a 10 point socket to remove the trans from my 04 stratus r/t with a manual trans. Theres 6 or 8 bolts that go from a flex plate I guess to the flywheel. But they are 10 point and approx 13mm... which I have never seen. So wondering if anyone can help out, been looking for weeks with no luck.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Where to buy a 10 point socket for a o4 stratus r/t
[Re: Silver70]
#191016
02/06/09 03:12 PM
02/06/09 03:12 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Anyone else... I'm pretty well screwed til I get it apart.
swing by the dealer and see if you can ask a tech what it is , or go to the miller/spx site and see if you can find it .
[Re: Silver70]
#191017
02/06/09 03:19 PM
02/06/09 03:19 PM
JohnRR
U.S.S.A.
[Re: rhandwor]
#191022
05/14/10 09:00 PM
05/14/10 09:00 PM
Posts: 2 Athens Ga
rhandwor
Athens Ga
JTC makes a Honda 10 point but its to large. Get a set of damaged nut removers like Grey Pneumatic 2300K individual 2305nr. Sears,Irwin and ebay sells them also. You can use an air hammer and bump the side. Vise grips should work. Tractor Supply or Fastenal sells new grade 10.9 bolts. Maybe your local hardware. Make sure the thread size, pitch and length are the same. Snap On normally waits 8 to 10 years before making a specialty socket. Vim,Lisle or KD will eventually make one. Rotunda,Miller,J.Kent Moore make specialty sockets. Mitsubishi also uses the same bolt.
http://www.vimtools.com/ Click on picture VimV10PT 12mm 10 point 3/8 square drive. I got my sample today but not on web site yet.
