Push Button 727 in a street rod #190981
01/11/09 10:19 PM
01/11/09 10:19 PM
pa
ramman16248 Offline OP
pa
I don't have a street rod yet, but I am looking into a Chrysler/Plymouth/Desoto/ or Dodge in the 1942-1948 range. I found a great driveline donor here locally. It is a 64 Newport with a 383 and a push button 727. How hard would it be to put the push button transmission and shifter in the old street rod? would it work? Thanks, Jason
Re: Push Button 727 in a street rod [Re: ramman16248] #190982
01/11/09 10:35 PM
01/11/09 10:35 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Using the pushbuttons would be the easy part. You could place them anywhere the cables would reach,dash or console.
Re: Push Button 727 in a street rod [Re: ramman16248] #190983
01/11/09 10:35 PM
01/11/09 10:35 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Sure ..... but be sure the cables are long enough. I am putting the trans and shifter into a dragster.
Re: Push Button 727 in a street rod [Re: dOc !] #190984
01/11/09 10:47 PM
01/11/09 10:47 PM
pa
pa
Ok, so the transmission shifts with cables? I don't really know how it works. So, as long as the cables reach, I can mount it anywhere? Are there any electronic conectors to it, or is it all cable mechanisms? If I know it can work I may step up to buy the driveline donor. Thanks, Jason
Re: Push Button 727 in a street rod [Re: ramman16248] #190985
01/11/09 11:11 PM
01/11/09 11:11 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
All cables,shift and park. no electronics.Only have to hook up kick down linkage from carb.
Re: Push Button 727 in a street rod [Re: ramman16248] #190986
01/11/09 11:16 PM
01/11/09 11:16 PM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
Some years the back-up light switch is mounted on the push-button control box and possibly the starter switch is in with the neutral button, that is the only electrical connections you should find.
Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
Re: Push Button 727 in a street rod [Re: pushbutton] #190987
01/11/09 11:42 PM
01/11/09 11:42 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Not REALLY necessary ... You can just tie-back fully the lever(during HP usage) and partial tie-back during a cruise ...or make-it a permanent manual shift valve-body.
Re: Push Button 727 in a street rod [Re: shinnery] #190988
01/11/09 11:45 PM
01/11/09 11:45 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Bryce
Backlight light switch,yes, starter sw. in N button I don't think in 64. They would look neat in a streetrod,I once saw some mounted on a roll bar in a old altered wheelbase car. The Kentucky Col. I think.
Re: Push Button 727 in a street rod [Re: pushbutton] #190989
01/12/09 10:47 AM
01/12/09 10:47 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
It's a hot set-up for t-buckets. You can put it on the seat riser and save room.
Re: Push Button 727 in a street rod [Re: RodStRace] #190990
01/12/09 12:19 PM
01/12/09 12:19 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
that 64 will have a seperate lever for park.
Other than that all is as mentioned above.
I have seen them used in custom applications and looks and works great
I have mechanical Aptitude.
I can screw up anything.
Re: Push Button 727 in a street rod [Re: bboogieart] #190991
01/12/09 01:16 PM
01/12/09 01:16 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Re: Push Button 727 in a street rod [Re: pushbutton] #190992
01/12/09 06:28 PM
01/12/09 06:28 PM
Oklahoma City, OK
moposcar Offline
moposcar  Offline
Oklahoma City, OK
Don't intend to steal a post, but is a push button 727 different from a regular 727? My 56 has the pushbutton console, but someone put in a floor shifter. Don't know if the cables are there or not.
Re: Push Button 727 in a street rod [Re: moposcar] #190993
01/12/09 06:58 PM
01/12/09 06:58 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Prob. not,56 pushbuttons would have been on the dash. It could have a later model trans. Pushbutton trans cables go into the trany and control gear selection internaly. I don't think 56's had a park lever. 56 was the first year for pushbuttons. 55's had a lever on the dash,at least plymouth's did.
Re: Push Button 727 in a street rod [Re: moposcar] #190994
01/12/09 09:19 PM
01/12/09 09:19 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The push button shifters changed during the 65 model year. Its possible someone installed a 65 or newer 727 which required a different shift mechanisum. The floor shift would have been the fast, easy way out. Gene
Re: Push Button 727 in a street rod [Re: poorboy] #190995
01/12/09 09:57 PM
01/12/09 09:57 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
the 65's were the last year for the cable shift trans. although they got away from the pushbuttons. They are very desireable because 65's had a slip yoke instead of the ball and trunion joint.
Re: Push Button 727 in a street rod [Re: pushbutton] #190996
01/13/09 01:14 AM
01/13/09 01:14 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Wouldn't a '56 trans be cast iron vs aluminum?What does your '56 have?
RT
Re: Push Button 727 in a street rod [Re: RTSrunner] #190997
01/13/09 10:43 PM
01/13/09 10:43 PM
Oklahoma City, OK
moposcar Offline
moposcar  Offline
Oklahoma City, OK
It is definitely a later model transmission...motor too. Someone swapped out the originals and put the later model one in before i bought it. They had a big sheetmetal screw or something for the transmission crossmember to bolt onto the transmission mount. Glad someone didn't try driving it b/c it was a very unsafe swap out.
I am in the process of putting the fat man fab front end on it, then putting a 383 and 727 in it. It will be my wife's daily driver for our first kid.
Re: Push Button 727 in a street rod [Re: ramman16248] #190998
02/03/09 11:46 PM
02/03/09 11:46 PM
Oakbank, MB Canada
mbmopar Offline
mbmopar  Offline
Oakbank, MB Canada
Using it is as easy as this - find a puchbutton shifter assy, ( I'm using one out of a 57 truck in my 55 truck ..."loadflite" for trucks ) get a shifter cable and bracket kit from inperial services..they will want to know what year os shifter for the correct cable end style....the kit comes with bracket that mounts to trans pan rail bolts and light weight shifter detent ball spring.......hook it up and go.
Well, it's not that easy, some fab work no doubt.
I'm planning on using the 1972 Torqueflite that came with the 440 New Yorker I stripped for the driveline and will be instlling it the 440/727 in my 55 Dodge truck. The cable i got seems almost 5 ft long if memory serves, they can custom make cables as well.
I can't wait to bolt it up and go,
ps - if you use a shifter from a trans that had no "park" detent feature built in, make shure your hand brake is good !
best,
Derek
"Put a Dodge in your garage!"
Re: Push Button 727 in a street rod [Re: RTSrunner] #190999
02/04/09 12:59 PM
02/04/09 12:59 PM
RT
Late 56 Powerflites had an aluminum case. My 56 Plymouth has an iron case with aluminum bellhousing and aluminum tailshaft.
Only a few late-56 Chryslers and Imperials had Torqueflites; no Dodges or Plymouths. Torqueflites were available in all models in 1957.
AFAIK, pre-62 Torqueflites all had cast iron cases with separate aluminum bellhousings.
1962 was the first year for the park lever and the first year for the aluminum-case Torqueflite with the integral bellhousing. But 62 Chryslers did not have a park lever (even though they had the new aluminum trans, they still had the parking brake drum on the rear of the trans).
All of the pre-62 Torqueflites and Powerflites are hooked up to engines with the old-style extended crank, and the torque convertor bolts directly to the crank, with no flex plate.
Re: Push Button 727 in a street rod #191000
02/08/09 11:34 AM
02/08/09 11:34 AM
Pennsylvania
cantspel Offline
cantspel  Offline
Pennsylvania
I am currently putting a pushbutton trans in an early dodge truck. I was not familiar with this swap before I started and tracking down the individual pieces is a pain and its EXPENSIVE. I've got most all of what I need now but If I had to do it all over, I would have bought a car with everything as you stated. It would have been much easier and cheaper. All that aside, its way cool. Anybody can bolt in a ratchet shifter. Other thing to keep in mind is that when you call for anyparts, (overhaul kit, valvebody pieces, torque converter) it helps to know the year of your trans, and you must make it clear to your parts taker exactly what you have or you will get standard torqueflite parts.
