Re: 1970 Barracuda Gran Coupe 383
[Re: 70B5Cuda]
#375271
09/19/13 11:33 AM
09/19/13 11:33 AM
Posts: 1,066 Newton, KS
70B5Cuda
Newton, KS
315/35/20 tire-its too small...
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
[Re: 70B5Cuda]
#375272
09/19/13 11:38 AM
09/19/13 11:38 AM
70B5Cuda
Newton, KS
left rear view of the same tire
[Re: 70B5Cuda]
#375273
09/19/13 11:40 AM
09/19/13 11:40 AM
70B5Cuda
Newton, KS
This is one of my new favorite pictures
[Re: 70B5Cuda]
#375274
09/19/13 11:45 AM
09/19/13 11:45 AM
70B5Cuda
Newton, KS
Right wheel tub and frame rails
[Re: 70B5Cuda]
#375275
09/19/13 11:48 AM
09/19/13 11:48 AM
70B5Cuda
Newton, KS
Right rear tub from below
[Re: 70B5Cuda]
#375276
09/19/13 11:49 AM
09/19/13 11:49 AM
70B5Cuda
Newton, KS
driver side rear tub from the inside
[Re: 70B5Cuda]
#375277
09/19/13 11:51 AM
09/19/13 11:51 AM
70B5Cuda
Newton, KS
Passenger rear tub from the inside.
Re: 1970 Barracuda Gran Coupe 6.1 Hemi/6 speed
[Re: 70B5Cuda]
#1909692
09/10/15 01:45 AM
09/10/15 01:45 AM
70B5Cuda
Newton, KS
[Re: sbhpcb]
#1914338
09/17/15 11:13 AM
09/17/15 11:13 AM
70B5Cuda
Newton, KS
Be sure to check that your rear side marker lights will fit, Check that the socket will fit! I thought mine would work until the car is all painted and I am putting it together. Thank you for the tip-I appreciate it. That would be a pain to figure out later! I plan to delete the side marker lights.
[Re: 70B5Cuda]
#1994641
01/20/16 02:09 AM
01/20/16 02:09 AM
70B5Cuda
Newton, KS
[Re: 70B5Cuda]
#1994646
01/20/16 02:16 AM
01/20/16 02:16 AM
70B5Cuda
Newton, KS
[Re: johnscudashop]
#1995089
01/20/16 06:52 PM
01/20/16 06:52 PM
70B5Cuda
Newton, KS
Looking good ... The 2 in drop in the front frame rails , is that gonna effect the height of the engine in the car?Hence you think it might hit the hood or what is your plans..I thought about the same mod in mine but decided against it for that reason... Awesome build BTW It will raise the intake into the hood but am planning to use a bubble scoop similar to the scoop found on the 2006-2010 Charger SRT8s. Also, I might be able to shorten the engine by going with a roots super charger.
