Re: R3 rear main leaking
[Re: Plymouth340]
#1908979
09/09/15 12:34 AM
09/09/15 12:34 AM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Or me......
Pulled pan off twice( in the car) second time even installed a rope seal..... before I had enough sense to put the car on a lift and yank the tranny.... Walla..... Oil dripping out the bottom of the cam plug.....
[Re: B3422W5]
#1908994
09/09/15 12:57 AM
09/09/15 12:57 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I had the cam plug leak on my R3.. after I put a new one in I siliconed the plug in.... I didnt have any rear main leaks but I also had the rear of the pan leak after I hit the pan coming back down
[Re: Plymouth340]
#1914799
09/18/15 01:13 AM
09/18/15 01:13 AM
B3422W5
Portage,michigan
Best to use a little anaerobic sealer on that plug, once you push it in it will set up nicely. Never had a leak after that.
