Re: R3 rear main leaking
[Re: Plymouth340]
#1908979
09/09/15 12:34 AM
09/09/15 12:34 AM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
Or me......
Pulled pan off twice( in the car) second time even installed a rope seal..... before I had enough sense to put the car on a lift and yank the tranny.... Walla..... Oil dripping out the bottom of the cam plug.....
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#1908994
09/09/15 12:57 AM
09/09/15 12:57 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I had the cam plug leak on my R3.. after I put a new one in I siliconed the plug in.... I didnt have any rear main leaks but I also had the rear of the pan leak after I hit the pan coming back down
[Re: Plymouth340]
#1914799
09/18/15 01:13 AM
09/18/15 01:13 AM
B3422W5
Portage,michigan
Best to use a little anaerobic sealer on that plug, once you push it in it will set up nicely. Never had a leak after that.
