Wide Band O2 kit #1903306
08/31/15 06:01 PM
08/31/15 06:01 PM
Harleysville, PA USA
Tommy D Offline OP
Tommy D  Offline OP
OK. I think I'm ready to bite the bullet and enter the 21st century. Was thinking of taking my new combo to the local chassis dyno. I'm interested in A/F ratios at idle and through the rpm range. My thoughts are that the only information that I won't receive from the wideband kit is HP and shift points. That being said, help me determine what kit to purchase.
My combo is from the stone age. 496 six pack (stock intake). The combo has headers. Will i need to weld a bung into the exhaust? How do i retrieve the information? Is the sensor connected to a laptop, or gauge.
I looked online, and it seems there are lots of options. There also seems to be a significant difference in quality and price. What are you using?
Re: Wide Band O2 kit [Re: Tommy D] #1903322
08/31/15 06:23 PM
08/31/15 06:23 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I run a Lm-1 kit by inovative. Has a screen read out and can down load to a computer if you record a pass. Have used it to get me in the ball park, then use the track to tell me where it needs to be.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Wide Band O2 kit [Re: Tommy D] #1903497
08/31/15 10:12 PM
08/31/15 10:12 PM
Tommy D Offline OP
Tommy D  Offline OP
Thanks Brad. See you next weekend at Cecil??
Re: Wide Band O2 kit [Re: Tommy D] #1903553
08/31/15 11:27 PM
08/31/15 11:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the old LM-1 also.. but I dont have the rpm/logger
so I mount a camera that will see the tach and the LM-1
read out... works fine that way
wave
Re: Wide Band O2 kit [Re: MR_P_BODY] #1903598
09/01/15 12:27 AM
09/01/15 12:27 AM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
just bought/installed a AEM gauge,simple to install and use. welded in the bung in the reducer and mounted the gauge eye sight level. it gets you headed in the right direction but not gospel. I don't know why I waited so long to get one cause you will see how slight changes in your tune makes a big difference.
Re: Wide Band O2 kit [Re: stinger] #1903610
09/01/15 12:48 AM
09/01/15 12:48 AM
Va Usa
beecrazy Offline
beecrazy  Offline
Va Usa
I have a dual O2 sensor LM-2. I have also connected a TPS to my Quickfuel carb and Installed a GM map sensor. Both the TPS and map sensor are connected to the LM-2. The LM-2 can display on its screen or connect to laptop for custom display through log works software. The LM-2 will also log to SD memory card so you can review later. The logs include both O2 sensor output, engine rpm , TPS and map sensor output.
Kevin
Re: Wide Band O2 kit [Re: Tommy D] #1903712
09/01/15 08:07 AM
09/01/15 08:07 AM
Tommy D Offline OP
Tommy D  Offline OP
Good stuff guys. Thanks for your input. Thinking about the LM-2 after reading up on it last night. Looks like the price of one dyno session gets you the tool to get the info any time you want...as long as it can be attached through the bung. I really appreciate your help.
Re: Wide Band O2 kit [Re: Tommy D] #1904945
09/02/15 03:06 PM
09/02/15 03:06 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
google spartan II wideband......good stuff and cheap
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Wide Band O2 kit [Re: Tommy D] #1905254
09/02/15 09:23 PM
09/02/15 09:23 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Why not just put a autometer gauge in it?
Re: Wide Band O2 kit [Re: Tommy D] #1905396
09/03/15 12:19 AM
09/03/15 12:19 AM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
If you have a laptop, the LC2 (used to be LC1) is IMHO the best bang for the buck.
Data logs direct to laptop plus if you go EFI down the road you don't need to buy a wide band controller.
It will also run a gauge so you can install it permanently if you want.
I have the LC1 running the wideband for my ancient Holley 950 Commander EFI.
Kevin.
Re: Wide Band O2 kit [Re: Tommy D] #1905619
09/03/15 12:30 PM
09/03/15 12:30 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I use a Daytona Sensors WEGO IV and a GoPro to record everything while making a pass. I can see the AFR, the tach, shift light and when I shift, oil pressure, fuel pressure, water temp, trans temp...And listen to what the motor is doing the whole time.
Camera was loose. DOH!
https://youtu.be/B2Bcne-I894
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Wide Band O2 kit [Re: Tommy D] #1907429
09/06/15 01:44 PM
09/06/15 01:44 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
I have and reccomend the LM 2. Having the rpm on the graph you can check afr/lambda readings at the top of the gear, the bottom etc.
You can also record water temp.
Don
Re: Wide Band O2 kit [Re: cudadon] #1907432
09/06/15 01:50 PM
09/06/15 01:50 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Don
I like mine, used it the first time this season and told me a lot, only thing is I am going to weld the bung in this winter and put the clamp in the box to use on other peoples cars.
Re: Wide Band O2 kit [Re: Tommy D] #1908637
09/08/15 02:50 PM
09/08/15 02:50 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
For those of you with the LM-2, how does it record RPMs, do you have a separate controller for that?
Re: Wide Band O2 kit [Re: mopowers] #1908644
09/08/15 03:05 PM
09/08/15 03:05 PM
Va Usa
beecrazy Offline
beecrazy  Offline
Va Usa
I have my LM-2 with analog cable connected directly to tach output off my MSD box .
This is then recorded to SD memory card in LM-2 along with AF readings and saved as a session.
Kevin
Re: Wide Band O2 kit [Re: beecrazy] #1908647
09/08/15 03:12 PM
09/08/15 03:12 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Kevin
Nice. How does it know when to start recording? Is there a button you push, or is it just constantly recording?
Also, can they be connected to other types of tach signals, like the coil. Would a mopar ECU work?
Re: Wide Band O2 kit [Re: mopowers] #1908653
09/08/15 03:17 PM
09/08/15 03:17 PM
Va Usa
beecrazy Offline
beecrazy  Offline
Va Usa
Yes there is s record button to start and stop recording.
I have mine on a window mount sitting just above radio. I record 2 AF sensors , RPM, TPS and a map sensor .
Kevin
Re: Wide Band O2 kit [Re: mopowers] #1908662
09/08/15 03:30 PM
09/08/15 03:30 PM
Va Usa
beecrazy Offline
beecrazy  Offline
Va Usa
The Innovate LM-2 manual does say that you can get RPM input from Negative side of coil if not using a MSD type box.
Kevin
Re: Wide Band O2 kit [Re: Tommy D] #1908690
09/08/15 03:57 PM
09/08/15 03:57 PM
I bought the Innovate LM1 kit with thier RPM option, the LM1 is no longer for sell or supportedwhiney I added thier LC1 kit later to mine to make it read and record both sides of the exhaust. I bought if for my pump gas Duster with a 518 C.I. 400 stroker motor with a low deck six pak on it, six paks rock up You will need to weld bungs in for the O2 sensors, as far as AFR on pump gas mine ran well with 14.25 to 15.3 AFR at idle and part throttle, I was shooting for 12.5 to 13.5 AFR at WOT, not sure I ever got it that lean with thee sixpak confused The car did run low tens, 10.28 ET at 127.+ MPH with 14.2 AFR at WOT shruggy I swapped the heads and intake and carb. to a set of Indy SR M.W. size heads and intake with a single 4500 1050 CFM Dominator carb. and it was right at 12.5 AFR, that made the car go 9.993 at 134.5 MPH shruggyIHTHS
