Need help with 60' times
#1900279
08/27/15 10:59 AM
08/27/15 10:59 AM
Posts: 1,123 Seaford Delaware
JSR1485
Seaford Delaware
My car 1969 Dart about 500hp small block, 5500 stall converter 4.56 gears 29x12-15 slicks I had an 9.5 4000 stall converter and it would 60' 1.69 and went 11.35 118 mph
New converter concepts converter 8" 5500 stall 60' 1.65 to 1.70 went 11.28 119.8 mph
Car has caltracs and split mono leafs with Rancho shocks on lightest setting I tried putting 1 click to firm in the shocks and dropped the tires pressure to 8lbs and the 60' went 1.75
Not sure where to go from here with it , I would think the 60's should be in 1.50's ?
Switched to the dark side...
Re: Need help with 60' times
[Re: JSR1485]
#1900349
08/27/15 12:29 PM
08/27/15 12:29 PM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
Footbrake or transbrake? What front suspension? Is the car spinning at all? Or is it just a dud out the gate?
[Re: JSR1485]
#1900355
08/27/15 12:37 PM
08/27/15 12:37 PM
JSR1485
Seaford Delaware
Foot brake 6 cylinder torsion bars and Qa1 adjustable shocks It almost seems like it hooks then spins a little Could I be unloading the tires?
[Re: JSR1485]
#1900362
08/27/15 12:56 PM
08/27/15 12:56 PM
an8sec70cuda
The 60' does seem soft for the ET. Those Rancho shocks always worked well for me at the stiffer end of the settings. I'm surprised you're at the lightest setting and footbraking. How are your front shocks set up? Real loose? Try stiffening them up a little, in case it is rising too fast and causing it to unload. 8 psi in those tires sounds low to me for this car...I'd start around 10 psi and see.
How are your Cal-Trac bars adjusted? Typical baseline for me was always 1/4 turn preload on both sides and use whatever front mount hole makes the bar close to parallel w/ the ground.
[Re: JSR1485]
#1900376
08/27/15 01:27 PM
08/27/15 01:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Foot brake 6 cylinder torsion bars and Qa1 adjustable shocks It almost seems like it hooks then spins a little Could I be unloading the tires? Whats the front and rear weights ..... video the runs.. video does wonders ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: JSR1485]
#1900377
08/27/15 01:28 PM
08/27/15 01:28 PM
JSR1485
Seaford Delaware
I have to check the front shocks I am new to caltracs so I check them also
I think i will start by bring the tires to 12psi and putting the rear shocks on firm and see what that does, then work on the caltracs
[Re: JSR1485]
#1900402
08/27/15 02:13 PM
08/27/15 02:13 PM
Posts: 5,895 Florida
Locomotion
If you are footbraking, accellerator pump tuning is critical. Gotta make sure your jetting is optimized too otherwise you'll have a harder time figuring out what to do with the squirters and pump cams.
* Jet for more MPH * Squirters and pump cams for 60' * Pump cams (duration of squirt) for 330'
I was surprised to learn that the fresh engine I ran for the first time this past weekend picked up a couple of tenths by jetting 2 #'s leaner than the same combo/set-up which had 4+ seasons on it. I still have to fine tune the jets and accellerator pump system to optimize the whole run. 1.46 60' was as good as ever, but should have been faster when compared to the rest of the run and previous engine.
[Re: JSR1485]
#1900407
08/27/15 02:16 PM
08/27/15 02:16 PM
JSR1485
Seaford Delaware
Myron Thanks as always , I was just looking at the carb and I think the squiter is too big
[Re: JSR1485]
#1900620
08/27/15 08:37 PM
08/27/15 08:37 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I used to run my ranchos between 8 and 9 nearly all the time on SS springs and 31x10.5" hoosiers between 13 and 14 psi best 60ft was 1.43 on ranchos. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: JSR1485]
#1900808
08/28/15 12:49 AM
08/28/15 12:49 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I agree it should 60 much better and if the eng is down on power some at launch it will also hurt your 60. For reference my old 440 combo ran a best of 11.49 @ 116 and had a 1.57 best 60. And thats on 3400 lb SS springs and the longer MP shocks with no settings on it. I do use Comp 90/10 shocks up front. I would tune the carb first and go from there but that should help. Good luck , Ron
[Re: 383man]
#1900905
08/28/15 05:35 AM
08/28/15 05:35 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I'm going to take a stab in the dark and say it only makes 450hp.. which means that he is fine for the 60 foot times and et.
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: JSR1485]
#1900985
08/28/15 11:32 AM
08/28/15 11:32 AM
JSR1485
Seaford Delaware
Thanks Guys for all the input! I changed my Carb to a 850CFM Ultra XP Carburetor I going to tighten the rear springs and up the tire pressure to 13psi for starting point The engine made 486 hp and 440 lbft TQ on the Dyno
[Re: JSR1485]
#1901483
08/28/15 11:14 PM
08/28/15 11:14 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
Jason, I always ran it with 11.5 lbs in the tires. And after you get a good baseline experiment with the squirters in the carb. The bars were setup with an 1/8 gap in them when you got it. Jim
[Re: JSR1485]
#1901596
08/29/15 01:12 AM
08/29/15 01:12 AM
Posts: 1,553 baldwinsville new york
a493demon
I would try full tight on rear shock's 8 or 9. More PSI in tire's . ( I run 14.5 lbs) if they are 3 way fronts I would go with the 70/30 setting to start . I have my cal's set at 1/16th gap. Oh are you running tube's in the tire's ?
[Re: JSR1485]
#1901823
08/29/15 01:30 PM
08/29/15 01:30 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
A little more info about your car will get you more helpful ideas.
"Just a Bracket car dressed up like a streetcar"
[Re: JSR1485]
#1902365
08/30/15 12:05 PM
08/30/15 12:05 PM
JSR1485
Seaford Delaware
My Lovely wife took some very good pictures of me running the car, after looking at the pictures the whole car was lifting off the starting line. The rear tires where rolling over them selfs also. The front & rear shocks where on the lightest settings, so I put 3 clicks in the front shocks to tighten up the extension. I put the rears on 8 to start with and I will put the tire pressure at 12 psi for a starting point.
[Re: JSR1485]
#1902448
08/30/15 02:51 PM
08/30/15 02:51 PM
Posts: 429 Washington
skrews
Washington
As said earlier more air in rear tires I run 13. Measure the front end extension, you want 5 inches or more. I cut down my upper control arm stops and lowered the car to half an inch off the lower bump stops. These mods help to keep the front end from topping out too quickly and unloading the rear. This helped my car a ton. Also make sure nothing is binding in the suspension. Very common to over tighten rear suspension components, this will cause a lot problems.
My car is very close to yours. It averages 1.48-1.52 60 ft times with a best of 1.42 using an 8" ATI 5800 converter. Runs bottom 11s at 118-119.
