in-line oil filter #1893632
08/17/15 04:21 PM
08/17/15 04:21 PM
alaska,usa
9
9secondsatellite Offline OP
alaska,usa
anyone use an in-line oil filter between external pickup from the pan to the oil pump? pros and cons of doing so? just a thought.
Re: in-line oil filter [Re: 9secondsatellite] #1893687
08/17/15 05:28 PM
08/17/15 05:28 PM
AndyF Online content
AndyF  Online Content
Has to be a very low restriction type of filter. Probably nothing more than a screen. If your pickup in the pan has a screen on it then that should be all you need. If you're worried about junk in the engine getting into the pan then the best place to put a screen is on the pickup. You can use a really large pickup with a fine screen on it and not have a restriction. There isn't enough room to put a large filter in the extrenal line.
Re: in-line oil filter [Re: 9secondsatellite] #1893700
08/17/15 05:46 PM
08/17/15 05:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
We use them on our dry sumps suction lines... you
can see them under the car(red things)
EDIT
They have them from about 3" long to about 10"...
all thats in it is a screen type filter... we use
them encase you blow up you dont suck trash into
the pump
wave
Re: in-line oil filter [Re: MR_P_BODY] #1893712
08/17/15 06:04 PM
08/17/15 06:04 PM
EDIT
the pump
wave
iagree thumbs A freind of mine lost a hemi motor do to trash seizing the Milidon oil pump from a small piece of debris that was sucked into the Milidon swinging pick and then into the pump puke He ended up buying two short Petersen #10 AN inline filters after that up Andy is correct on using screen around the pickups also, either way will work up
Re: in-line oil filter [Re: 9secondsatellite] #1893718
08/17/15 06:08 PM
08/17/15 06:08 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If you're interested I have a BRAND NEW Earls one for sale - bought it to use with my road race pan but there is nowhere to put it without running a yard of line !! Drop me a PM.
Re: in-line oil filter [Re: 9secondsatellite] #1894227
08/18/15 10:06 AM
08/18/15 10:06 AM
an8sec70cuda Offline
Hemi-itis runs inline oil filters on his hemi. Might want to ask him.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: in-line oil filter [Re: an8sec70cuda] #1894474
08/18/15 03:34 PM
08/18/15 03:34 PM
alaska,usa
9
alaska,usa
thanks for the input guys. was toying with the idea to keep any possible junk from getting into the oil pump and could monitor better what was going into the pan.
Re: in-line oil filter [Re: 9secondsatellite] #1897296
08/22/15 09:14 PM
08/22/15 09:14 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I just plumed mine in today. Then ran pump to test oil to heads so in it goes tomorrow then prime again! :-)
Re: in-line oil filter [Re: Dodgem] #1897748
08/23/15 04:32 PM
08/23/15 04:32 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
This is what I use. Peterson scavange filter. It has a cleanable screen that I check at most oil changes. A few years ago I had a inner valve spring break that cut the valve guide seal clamp and that small part found its way into the oil pan, stood up to go into the Milodon swinging pick up (through the pick up screen) and into the oil pump, locking up the pump and twisting off the end of the oil pump/distributor shaft. The scavange filter did NOT stop the small pieces of aluminum from going into the pump this year when I broke the crankshaft, ruining the oil pump again.
Brian
IMG_0984.JPGOil Pump Damage August 2012 006.JPGOil Pump Damage August 2012 011.JPG
Re: in-line oil filter [Re: 9secondsatellite] #1898445
08/24/15 04:42 PM
08/24/15 04:42 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: in-line oil filter [Re: an8sec70cuda] #1898517
08/24/15 06:44 PM
08/24/15 06:44 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
After In had a piece of debris jam the oil pump rotor and snap the oil pump drive,Jimi Vignogna told me to use these in each line.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
