Re: in-line oil filter
[Re: 9secondsatellite]
#1893700
08/17/15 05:46 PM
08/17/15 05:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
anyone use an in-line oil filter between external pickup from the pan to the oil pump? pros and cons of doing so? just a thought. We use them on our dry sumps suction lines... you can see them under the car(red things) EDIT They have them from about 3" long to about 10"... all thats in it is a screen type filter... we use them encase you blow up you dont suck trash into the pump
[Re: MR_P_BODY]
#1893712
08/17/15 06:04 PM
08/17/15 06:04 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
anyone use an in-line oil filter between external pickup from the pan to the oil pump? pros and cons of doing so? just a thought. We use them on our dry sumps suction lines... you can see them under the car(red things) EDIT They have them from about 3" long to about 10"... all thats in it is a screen type filter... we use them encase you blow up you dont suck trash into the pump A freind of mine lost a hemi motor do to trash seizing the Milidon oil pump from a small piece of debris that was sucked into the Milidon swinging pick and then into the pump He ended up buying two short Petersen #10 AN inline filters after that Andy is correct on using screen around the pickups also, either way will work
#1894227
08/18/15 10:06 AM
08/18/15 10:06 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Hemi-itis runs inline oil filters on his hemi. Might want to ask him.
[Re: an8sec70cuda]
#1898517
08/24/15 06:44 PM
08/24/15 06:44 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
Hemi-itis runs inline oil filters on his hemi. Might want to ask him. After In had a piece of debris jam the oil pump rotor and snap the oil pump drive,Jimi Vignogna told me to use these in each line.
