Re: Are big & small blocks the same flywheel?
[Re: express]
#1897962
08/23/15 10:33 PM
08/23/15 10:33 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
There are several OEM 6 bolt A motor internally balanced motors, 273,318,340, 130 tooth nuetral balance flywheels that will work on either the BB, 426 Hemi and B and RB internally balanced motors, same on the internally balanced motors with the larger 143 tooth flywheels The key is internally balanced motors using a nuetral balanced flywheel, aluminum, stee, 130 or 143 tooth IHTHs
[Re: express]
#1897979
08/23/15 10:49 PM
08/23/15 10:49 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I don't know if this will help you or not but my internally balanced 408 small block uses the same powerglide flex plate as my big blocks. Lots of used outdated sfi flex plates are bought for this purpose
[Re: Cab_Burge]
#1898013
08/23/15 11:27 PM
08/23/15 11:27 PM
Posts: 314 North East Missouri
express
North East Missouri
There are several OEM 6 bolt 130 tooth nuetral balance flywheels that will work on either the BB, 426 Hemi and B and RB internally balanced motors, same on the internally balanced motors with the larger 143 tooth flywheels The key is internally balanced motors using a nuetral balanced flywheel, aluminum, stee, 130 or 143 tooth IHTHs So if he gets any 6 bolt flywheel that is for an internally balanced motor it will work?
[Re: express]
#1898159
08/24/15 03:52 AM
08/24/15 03:52 AM
Cab_Burge
There are several OEM 6 bolt 130 tooth nuetral balance flywheels that will work on either the BB, 426 Hemi and B and RB internally balanced motors, same on the internally balanced motors with the larger 143 tooth flywheels The key is internally balanced motors using a nuetral balanced flywheel, aluminum, stee, 130 or 143 tooth IHTHs So if he gets any 6 bolt flywheel that is for an internally balanced motor it will work? I messed up and forgot to include A motor flywheels on my original post, sorry See the post now with the edit, Rhinodart is correct
[Re: Rhinodart]
#1898325
08/24/15 02:20 PM
08/24/15 02:20 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
In a word, YES! Any 6-bolt internally balanced flywheel will work. YEs ASSuMEing the 440 in question is also internal balance ... which the OP never says ...
[Re: JohnRR]
#1898530
08/24/15 07:02 PM
08/24/15 07:02 PM
Posts: 8,941 Holly/MI
Dean_Kuzluzski
Holly/MI
10.5" - 130 tooth - YES 11" - 143 tooth - YES (they did come on some LA truck motors) 11" - 172 tooth (Hemi 66-67) - NO
What # of teeth does this dyno already use is the BIG question. If 130T, then get a 10.5" and you're good to go.
