98 Ram no start #1893014
08/16/15 04:32 PM
08/16/15 04:32 PM
Iowa
3
318Bruiser Offline OP
Iowa
98 Ram stalled and will not start. First I checked the fuses in the fuse block under the hood. It ran for 3 seconds and hasn't since. I first changed the Crank position sensor, no start. I tested the fuel pump, 45 PSI but dropped to 0 in 2 minutes. I swapped it out with a new one. Pressure is 48 and stays there.
My battery is fully charged and I changed the cap,rotor, wires and plugs a month ago. I also changed the coil. There is good gas in the tank. Lawn mower runs on the gas I put in.
I am at my wits end and I can not seem to figure it out. Anything else I can check? Only thing else I can think of is the PCM.
Re: 98 Ram no start [Re: 318Bruiser] #1893122
08/16/15 07:19 PM
08/16/15 07:19 PM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
Do you have spark? Is the coil being commanded to fire? Are the injectors being commanded to fire?
Before changing partrs and adding more questions than answers we need some actual testing.
Angry white pureblood male
Re: 98 Ram no start [Re: 318Bruiser] #1893183
08/16/15 09:23 PM
08/16/15 09:23 PM
Iowa
3
Iowa
No spark per my spark tester. I have a P1389 code, which is the ASD relay. I swapped the relay a few times with the others on the fuse block. Still no start. Cap and rotor still look good. So am I safe to assume that I may have received a bad crank position sensor, or did I miss testing something else?
Re: 98 Ram no start [Re: 318Bruiser] #1893196
08/16/15 09:54 PM
08/16/15 09:54 PM
places
79powerwagon Offline
places
Just a dumb question, but have you cleared your computer and try to start it?
Re: 98 Ram no start [Re: 318Bruiser] #1893199
08/16/15 09:58 PM
08/16/15 09:58 PM
Iowa
3
Iowa
Yes, a few times just in case.
Re: 98 Ram no start [Re: 318Bruiser] #1893204
08/16/15 10:08 PM
08/16/15 10:08 PM
New Brunswick, Canada
TrxR Offline
TrxR  Offline
We lost 2 ecu's on our 98 but when it happened a code reader wouldnt connect to it.
Re: 98 Ram no start [Re: TrxR] #1893369
08/17/15 01:13 AM
08/17/15 01:13 AM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
broken/ corroded wire in the harness. you need to check the powers at the relay. there is a wire that branchs off and goes to a few different components, that connection gets corroded and you loose power to a few different relays and computer. you need to do power and ground checks before throwing more parts at it. relay should have 1 power wire all time and 1 with key on. the computer controls the ground. It has been a while, If I remember correctly the branch is in the harness between the fire wall and battery along the left side inner fender. look for the green powder(corrosion).won't be easy to spot, it is inside the taped harness. Getting an aftermarket Bad part is not that uncommon. a scan tool that is bidirectional can command the coil to fire/spark. if that happens then the wiring is good,
Re: 98 Ram no start [Re: moretoys] #1894797
08/18/15 09:29 PM
08/18/15 09:29 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Just fixed that problem on a 95 Dakota...changed pick up coil..coil..crank sensor...kept dying and not wanting to restart..found a youtube video...showed were the wires were...and this dakota has been in the desert all its life and still corrode...runs great again..
Tony
70 AARCuda Vitamin C
Re: 98 Ram no start [Re: 318Bruiser] #1894865
08/18/15 10:33 PM
08/18/15 10:33 PM
Iowa
3
Iowa
Thank you for the info. It is raining and I do not have a garage so if it is clear tomorrow I will be searching for corrosion and running my multi-meter.
Re: 98 Ram no start [Re: 318Bruiser] #1896117
08/20/15 07:40 PM
08/20/15 07:40 PM
Iowa
3
Iowa
So I was finally able to check the crank position sensor connector and I have just over 5 volts going to it but the ohm test on the ground pin gave me a .13 so I assume I have a corroded wire somewhere. I am looking for a wiring schematic for the truck now. I do not see any corrosion anywhere at first look so I am about to start looking in the looms.
Re: 98 Ram no start [Re: 318Bruiser] #1896349
08/21/15 01:43 AM
08/21/15 01:43 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
'98 if I remember has the coil down by the alternator, ck the coil wire for corrosion.Where are you checking for spark? Also if the truck has a tach a quick check of the crank sensor would show rpm 50-100 even when cranking.
Re: 98 Ram no start [Re: SALEM1912] #1896406
08/21/15 10:06 AM
08/21/15 10:06 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
5 volts is normal. all the sensors operate between 0-5 volts. The crank position trigger uses a 5v or 0v signal- as the windows on the flexplate/flywheel pass under the sensor, the voltage goes from 5 to 0 telling the computer that a piston is at TDC. others, like the MAP, TPS, etc. use a varying voltage to articulate a range of values.
.13 ohms in a wire sounds normal. copper wire has resistance and will show some value of resistance on an Ohm test.
**Photobucket sucks**
Re: 98 Ram no start [Re: 70Cuda383] #1896727
08/21/15 07:29 PM
08/21/15 07:29 PM
Iowa
3
Iowa
If the .13 Ohm test is around normal then I am glad to hear that. I will have to test the coil connections, but I am going to take a break tonight and start again in the morning. I really hope it is just a part, even if it is the computer because I really hate wiring and electronics.
Re: 98 Ram no start [Re: 318Bruiser] #1897292
08/22/15 09:06 PM
08/22/15 09:06 PM
Iowa
3
Iowa
So I went and exchanged the new CPS just in case. I went over all grounds and made them shiny or replaced. Same with power wires that were questionable. I still get the P1389 code, which is the "No ASD Relay Output Voltage At PCM".
I switched relays around. Still no power to coil. My battery charger buzzed and smoked so it is toast now. I am kinda of at a lose now and not sure what else to do. I think I may double check some more wires tomorrow.
Re: 98 Ram no start [Re: 318Bruiser] #1897514
08/23/15 02:40 AM
08/23/15 02:40 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
Re: 98 Ram no start [Re: 318Bruiser] #1897592
08/23/15 11:45 AM
08/23/15 11:45 AM
Iowa
3
Iowa
I just removed all the tape on those wires from the video and I have nothing like what they showed, but I am not getting any power to the asd relay. I have I think 3 or 4 thicker red wires going to the power box and I am about to check them now with the meter.
Re: 98 Ram no start [Re: 318Bruiser] #1897776
08/23/15 05:22 PM
08/23/15 05:22 PM
ohio
ohio
OK calm down. The code indicates a problem with the asd relay or its wiring. Since the relay has been changed with no effect, its safe to say it's wiring related. Fortunately the wiring isn't all that complicated.
IIRC theres 4 wires on that relay:
1 Battery power, should be hot at all times
2 Key on power, hot when key on
3 Feed to items that are fed from the relay, things like the fuel pump relay, power for ecm etc.
4 Control for relay, this will be a ground when the ecm is commanding the realy to operate. Should be ground when cranking and for a couple seconds after. If the ecm doesn't see a crank/rpm siginal it will command the relay off (no ground)
A basic test ;light can test these circuits. Obviously 1 terminal in the socket should have power all the time, The 2nd should have power with the key on. Test for these by clipping the test light to battery negative and probing the terminals to see which lights up. Make a sketch and mark em for future reference.
The control circuit is tested by cliping the test light to battery positive, probing the other 2 terminals. One should only light the test light when cranking and like stated will light the test light for a coupe seconds after key release. Add this to your sketch.
The feed wire should theoretically show a ground with the test light connected the same as checking the control circuit. This should be a constant ground.
Check these and report back with what is not working as expected. Then we can narrow down which circuit is out of order.
Re: 98 Ram no start [Re: ruderunner] #1897817
08/23/15 06:28 PM
08/23/15 06:28 PM
Iowa
3
Iowa
These are the results of the test:
1. No constant power (no power at all) pin 30
2. No power when key on (no power at all) pin 87
3. Connection to positive on battery then to pin 85 and I get constant light. Ground is good.
4. Connection to positive on battery then to pin 86 and I get light for about 2 seconds after key release.
30 Common feed
85 Coil ground
86 coil battery
87 normal open
87a normal closed
When I checked #3 my cruise control clicked for about 2 seconds and I heard a faint hum for 2 seconds but I could not figure out where the hum came from.
Re: 98 Ram no start [Re: 318Bruiser] #1897864
08/23/15 08:06 PM
08/23/15 08:06 PM
ohio
ohio
By putting the light into #3 you were effectively providing power to the components that run off the asd relay. The noises are a good sign that that part of the wiring is indeed connected.
The lack of power to either hot terminal at the relay starts to point towards a failed fuse link. These go between the battery and fuse block. Normal test for a fuse link is to pull on it, if it stretches, its burnt.
Follow the positive cable to a point where 5 or 6 wires are spliced to it. Those will likely be the fuse links. Start at the battery. You may have more than 9ne bad link, I don't know if the same one provides power to the asd and ignition switch.
Re: 98 Ram no start [Re: 318Bruiser] #1897891
08/23/15 09:00 PM
08/23/15 09:00 PM
Iowa
3
Iowa
I have 3 set of white and black wires encased in a red protective cover. 1 from the firewall and 2 go under the cab. All of the black wires have been sliced with 20 amp blade links and they connect to the terminal on the distribution block. The positive cable attaches to the same terminal.
One of the white wires from under the cab is spliced into a ground. The other 2 white wires are spliced to each other. All three of the blade links have power, when key is on, per my test light. I did not find any other fusible links.
