Good .030 383 piston for street application #1888261
08/09/15 08:52 PM
08/09/15 08:52 PM
California
P
Plymouth273 Offline OP
P
California
Going through the engine and need a .030 bore What is a good piston to use for a street car, dome or flat top, type, brand etc? Car is a 383 auto 4bbl running basically a 383 magnum cam, 906 heads, just a nice driver.
Thanks.
Re: Good .030 383 piston for street application [Re: Plymouth273] #1888315
08/09/15 09:52 PM
08/09/15 09:52 PM
SE PA
Yellow Fever Offline
SE PA
Since you're going to have to re-balance anyway, why not go stroker? I dropped a muscle motors 383/450 kit in a low mileage 383 .030 over and it worked great. Once you go stroker you never go back! laugh
Re: Good .030 383 piston for street application [Re: Plymouth273] #1888333
08/09/15 10:11 PM
08/09/15 10:11 PM
JohnRR (the other double R) is the 383 piston guru, maybe he will see this. He ain't been around as much lately tho
Re: Good .030 383 piston for street application [Re: Plymouth273] #1888569
08/10/15 02:52 AM
08/10/15 02:52 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Somebody is selling a new 383 piston design over in the new products section here. Its hard to find a shelf piston that fits most of the usual wishlist for a street 383 build.
I want my fair share
Re: Good .030 383 piston for street application [Re: Plymouth273] #1888912
08/10/15 04:50 PM
08/10/15 04:50 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Thanks.
For my 383HP resto engine build, open for suggestions, I think I'll pay the money for a set of semi-custom pistons from Diamond with the following key features:
* 4032 forging for a little bit better expansion for a street engine.
* Compression Distance of 1.932"
* No valve reliefs.
* A more modern 1/16 x 1/16 x 3/16 ring pack.
Basically, a copy of a stock HP piston with a modern spin. Should be about 9.2:1 compression with stock 906 heads so should run okay on pump gas.
Re: Good .030 383 piston for street application [Re: Plymouth273] #1890974
08/13/15 01:06 PM
08/13/15 01:06 PM
KY
65pacecar Offline
65pacecar  Offline
KY
I have one engine with the KB400-030 Pistons in it, nice dome piston. The engine and performance is nice, set up with a mild cam.
Re: Good .030 383 piston for street application [Re: Plymouth273] #1890976
08/13/15 01:13 PM
08/13/15 01:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Flat top piston is best , dome impedes flame travel. The problem with 383's is piston selection sucks. There is no piston out there that has the same compression height as a stock 383HP piston and the factory lied about the compression ratio.
There is a member that has a piston available that is close to stock , you want one wit ha small valve relief , 3cc would be best .
The best piston would be a custom Diamond with a step head dome for use with the 906.
What is your budget ?
Just reread your post , you are in Cali , land of crap gas , you need to build it right so it will run on the swill that is at the pump.
Re: Good .030 383 piston for street application [Re: JohnRR] #1891749
08/14/15 11:52 AM
08/14/15 11:52 AM
California
P
P
California
JohnRR thanks for the information,
Who is the member that offers the good piston that you mentioned? The car spends most of its time in Arizona, I think the gas quality is better plus I usually mix 25-50% Racing fuel anyway.
Don't want to spend a ton on it but get a nice build. Is there a good flat top that is readily available for the 383, it seems that someone has referenced a Speed Pro piston in the past they have had luck with.
Re: Good .030 383 piston for street application [Re: Yellow Fever] #1891753
08/14/15 11:54 AM
08/14/15 11:54 AM
California
P
P
California
Its a thought up
Re: Good .030 383 piston for street application [Re: Plymouth273] #1891982
08/14/15 07:07 PM
08/14/15 07:07 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
"Who is the member that offers the good piston that you mentioned? The car spends most of its time in Arizona, I think the gas quality is better plus I usually mix 25-50% Racing fuel anyway."
Hot deals piston thread.
https://board.moparts.org/ubbthreads/ubbt...tml#Post1686955
Re: Good .030 383 piston for street application [Re: Plymouth273] #1891987
08/14/15 07:15 PM
08/14/15 07:15 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
plymouth273 ,check out the speedpro sealed power L2315F. as close to original without custom ordering. ronnie
Re: Good .030 383 piston for street application [Re: Plymouth273] #1891992
08/14/15 07:18 PM
08/14/15 07:18 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Not much selection in off the shelf, stock stroke crank and rods, the KB162-30 would work for a mild street build.
I don't know about the new one someone mentioned?
Re: Good .030 383 piston for street application [Re: Plymouth273] #1892053
08/14/15 08:55 PM
08/14/15 08:55 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Diamond has pistons for use in the 383,using both the 383 rod and 440 rod non stroker.
Nautilus Racing-
Re: Good .030 383 piston for street application [Re: Plymouth273] #1893111
08/16/15 07:06 PM
08/16/15 07:06 PM
California
P
P
California
Anyone ever use this cam? Is it any good. Would it work with the 2315 speed pro flat tops or the KB400 Pistons
http://m.summitracing.com/parts/sum-k6401
Re: Good .030 383 piston for street application [Re: Plymouth273] #1893282
08/16/15 11:40 PM
08/16/15 11:40 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I have used this cam in 3 440's and love it. Has a slight lope, just enough to know it's not stock, and makes lots of torque.
Re: Good .030 383 piston for street application [Re: 1969ronnie] #1893415
08/17/15 02:42 AM
08/17/15 02:42 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Close but .012 shorter than a stock piston. will lower the compression ratio but he could cut the heads , which he should anyway.
Re: Good .030 383 piston for street application [Re: 451Mopar] #1893417
08/17/15 02:44 AM
08/17/15 02:44 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That piston plain sucks, it's .024 shorter than stock and has a HUGE valve CANYON , he'll end up with 8.0ish compression.
Re: Good .030 383 piston for street application [Re: Plymouth273] #1893419
08/17/15 02:46 AM
08/17/15 02:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I ran it with a worn out 383 2 bbl engine and a 4 speed with 3.23's, wasn't bad for what it was.
