push-on window trim/seals #1890916
08/13/15 12:15 PM
08/13/15 12:15 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
I am looking for some window trim / seals for my glass doors. Have about 7/32" gap between the glass and the door edges (pretty consistent on both sides and all around ). Door edge thickness = 3/32". Any suggestions would be appreciated. Thanks, John
Fastest 300
Re: push-on window trim/seals [Re: Crizila] #1891389
08/13/15 10:33 PM
08/13/15 10:33 PM
moparx Offline
moparx  Offline
i remember seeing some straight lengths of "fuzzies" material[similar to the material in the glass channel]that were used as a universal application, attached to about a 1/2-3/4" stainless flat strip about 36" or so long. the strips were attached to the door on the outboard side, and the garnish molding on the inboard side. as there was a rolled bead at the top, this was used to align the door and molding edge and provide a finished look. bad thing is, i can't remember where i saw this. does your glass shop have any suggestions ?
beer
Re: push-on window trim/seals [Re: ] #1891763
08/14/15 12:18 PM
08/14/15 12:18 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Thanks guys. Both good suggestions. Sent Steele rubber products an E-mail and will check with my glass guy today. bow
Fastest 300
Re: push-on window trim/seals [Re: Crizila] #1897959
08/23/15 10:32 PM
08/23/15 10:32 PM
Georgia
69bfan Offline
69bfan  Offline
Georgia
Check out Restoration Specialties and Supply in Windber, PA. They will have pretty much everything that you will need. They may already have them made up for this application. Reach them at 814-467-9842. You can also see some of their product online by doing a search.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
