Re: worn fuel pump push rod [Re: mopars4ever] #1890180
08/12/15 11:51 AM
08/12/15 11:51 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Originally Posted By mopars4ever
Mopar supposedly had put a bad batch of the push rods out years ago so when you get a new one I would look elsewhere.
This issue has been a subject of conversation for years. Years ago a bad batch of fuel pump rods were in circulation. Looks like you got one of them. The rod should be hardened. Since then I've checked rods that I've installed by running a file over each end. If I get shavings the rod is bad. Make sure you place a few magnets at the bottom of your pan.
This issue was also a problem with the mechanical cam adjusters. The tips in contact with the pushrods would prematurely wear down. Crane Cam adjusters were the main culprit since they got most of their small parts from off shore.
Abe Lincoln
Re: worn fuel pump push rod [Re: dart4forte] #1890224
08/12/15 01:23 PM
08/12/15 01:23 PM
dogdays Offline
dogdays  Offline
The problem is one cannot reduce the problem to one bad batch of fuel pump pushrods sold by MP or Direct Connection.
There were PLENTY of insufficiently hardened fuel pump pushrods put in AT THE TRENTON ENGINE PLANT. I have heard from several people who had it happen to their car that they bought new in 1968 or whenever. They remember it because it took some digging to figure out what the problem was.
Most people don't even know that the fuel pump has a pushrod.
R.
Re: worn fuel pump push rod [Re: joelson6] #1890255
08/12/15 02:11 PM
08/12/15 02:11 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
I believe mccannix still might have a few NOS Fuel Pump Push Rods around. I bought a tin can full of them off him a year ago or so. He still had a lot more left. I just bought them because of the problem that happened over the years with the wear on these rods.
1971 HEMI E BODY REGISTRY
Re: worn fuel pump push rod [Re: joelson6] #1890264
08/12/15 02:26 PM
08/12/15 02:26 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Not reducing it to anything, just warning him to stay away from them.
Re: worn fuel pump push rod [Re: joelson6] #1890369
08/12/15 04:58 PM
08/12/15 04:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
He said the rod he reused was the original rod that was installed in the engine in 1970 so those beating the bad batch dead horse are doing just that.
I'm going to surmise that the cam lobe is the culprit that caused this, I wonder what the blank is that Ebrock uses for their cams?
Re: worn fuel pump push rod [Re: joelson6] #1890950
08/13/15 12:45 PM
08/13/15 12:45 PM
Pinelands , NJ
joelson6 Offline OP
joelson6  Offline OP
Pinelands , NJ
Thanks for the concern about the bad batch of fuel pump rods. but like JohnRR said, this rod has been in the engine since 1970. there was no problem with the original cam and rod. the problem developed when i installed the Edelbrock cam. I'm thinking it had something to do with the cam, that's why I'm replacing the cam. now i just have to wait 2 more weeks for the new cam to get here.
Re: worn fuel pump push rod [Re: joelson6] #1890966
08/13/15 01:02 PM
08/13/15 01:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
2 weeks for a cam ???
Re: worn fuel pump push rod [Re: joelson6] #1891018
08/13/15 02:28 PM
08/13/15 02:28 PM
Pinelands , NJ
joelson6 Offline OP
joelson6  Offline OP
Pinelands , NJ
yea, if i was building an 11 second car, i could have it tomorrow. but i want a stock cam for a '70 Newport, THAT has to be made to order. go figure.
Re: worn fuel pump push rod [Re: joelson6] #1891035
08/13/15 02:54 PM
08/13/15 02:54 PM
Pinelands , NJ
joelson6 Offline OP
joelson6  Offline OP
Pinelands , NJ
and to my surprise, look what showed up at my door today. Summit said it was gonna be shipped on the 28th. i guess i know what i'm doing tonight.
Re: worn fuel pump push rod [Re: dart4forte] #1891364
08/13/15 10:16 PM
08/13/15 10:16 PM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
Crane made the adjusters (and virtually all of their "small parts") in house. Nothing from offshore. There was a heat treat issue, and a recall followed. As Crane only knew who bought them directly, they had to depend on the distributors to follow up with their customers. No internet back then. Some folks were more responsive then others. Regards, Chase
Re: worn fuel pump push rod [Re: joelson6] #1891577
08/14/15 02:42 AM
08/14/15 02:42 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Again, not beating a dead horse. His old rod is bad correct? He needs a new one correct? Just warning him to stay away from the mopar ones in case he may get one that may be from that bad batch.
Re: worn fuel pump push rod [Re: mopars4ever] #1891704
08/14/15 10:36 AM
08/14/15 10:36 AM
Pinelands , NJ
joelson6 Offline OP
joelson6  Offline OP
Pinelands , NJ
i never answered this, but i didn't get a "bad" rod from mopar. i bought a rod from Howards Cams. a lot of people recommended that. plus the new cam and lifters are from Howards.
Re: worn fuel pump push rod [Re: cknight] #1891719
08/14/15 10:59 AM
08/14/15 10:59 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Thanks for the update. Just wanted to point out that there are still some bad adjusters floating around in the used parts world. We're you with the old Crane Cams?
Abe Lincoln
Re: worn fuel pump push rod [Re: dart4forte] #1891876
08/14/15 03:50 PM
08/14/15 03:50 PM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
Yes, those have been floating around for over 15 years. Been here at Crane since 1967......Chase
Re: worn fuel pump push rod [Re: joelson6] #1892405
08/15/15 02:12 PM
08/15/15 02:12 PM
Pinelands , NJ
joelson6 Offline OP
joelson6  Offline OP
Pinelands , NJ
it's back together with the new cam and running nice on the mechanical fuel pump. just broke in the cam and now i gotta change the oil. then take her for a ride.
