Page 2 of 5 1 2 3 4 5
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: Duner] #1889376
08/11/15 11:12 AM
08/11/15 11:12 AM
Az
Crizila Offline
Crizila  Offline
Az
Originally Posted By Duner
Isn't the hotrod world awesome?
We all get to pick our own way of making things work for ourselves without anybody else being condecending about it or feeling THEIR way is the only way and that everybody else is doing it wrong. boogie
Well, one thing is for sure, doing it in 110 degree is wrong - no matter how you do it. Been to the pavilions lately Dwayne?
Hahaha... yeah, it's a bit warm out!
The sweat running into my eyes takes some of the fun out of adjusting my valves. LOL
The pavilions aren't much fun anymore. They run everybdy out of the parking lot about the time it might even begin to start cooling off. I don't know how some of those guys do it. They show up at noon, pull out their lawn chairs and bake. NO THANKS! I'm not setting foot on the place until it gets dark.
Look to the right of the pic and you can see where my car has been for the last 3 months. See ya in the fall. wave
Fastest 300
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: Evil Spirit] #1889508
08/11/15 02:40 PM
08/11/15 02:40 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Originally Posted By Evil Spirit
I never saw the logic of setting one valve according to what another valve is doing, but, whatever.
People that still use the EOIC method must like barring/bumping the motor over about 20 times to set valves when it can easily be done doing it in about 5-6 rotations.
I bring the #1 intake to fully open, then rotate the crank 1 turn, which leaves the #1 intake solidly on it's base circle. Set #1 intake. Rotate crank 90* - Set #8 intake. Rotate crank 90* - set #4 intake. Follow this pattern through firing order to set all intakes. Now bring #1 exhaust to fully open, then rotate crank 1 turn, which leaves the #1 exhaust solidly on it's base circle. Set #1 exhaust. Rotate crank 90* - set #8 exhaust. Again, follow pattern through firing order to set all the exhaust valves.
This works with EVERY canshaft, no matter lift, duration, lobe separation, or firing order, and sets the lash off of its cam lobe and not another one.
Pretty simple, HUH?
How about the reason that according to the laws of physics, what one lobe is doing, TELLS you what the other lobe is doing.
And your method seems anything BUT simple to me. That's a lot of crank turning, looking at marks and walking from side to side. I would imagine I could adjust my valves 4 times using the other method, before you got done with one this way.
I have NEVER seen anything as brutally simple as valve adjustment, get as much play anywhere as it does on THIS board. Some seem to think it's like rocket science or something. You have to remember, you get 5 people together and tell them to set the SAME valve to .024, you likely get 5 different TRUE settings, because everybody's FEEL is different as to the drag on the feeler gauge. So is it .024 or is it a loose .024 or a tight .024........LOL!!!
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: RT540] #1889528
08/11/15 03:21 PM
08/11/15 03:21 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
the EOIC methods works fine for me. can adjust all valves in about 20 min. tops and that includes pulling the covers. one cylinder at a time. go down one bank then the other and use a remote start. quickest and easiest way for me.
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: RT540] #1889557
08/11/15 03:50 PM
08/11/15 03:50 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
It's VooDoo I tell ya just plain VooDoo
Ok at least on Moparts it is Voodoo. Flex is what you are seeing nothing more nothing less. Set things how you like. FWIW a "billet" STANDARD size cam core means nothing in terms of flex in a valvetrain. Could be your pushrods, the cam core, rockers, rockershafts or yes even that fancy cam is the spring load is high enough and the cam is a STD core size, yes even a billet. The reason for larger cam cores like 55, 60, 70 was to try and keep them from flexing under load.
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: RT540] #1889599
08/11/15 05:32 PM
08/11/15 05:32 PM
North Sweden
RT540 Offline OP
RT540  Offline OP
North Sweden
I have a STD core cam, its a custom grind from cam motion, so flex sounds like a reasonable answer with the PSI springs at 370pounds seat pressure.
Thanks for helping.
/Tom
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: RT540] #1889781
08/11/15 09:34 PM
08/11/15 09:34 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
370 on the seat with a stock core........yes sir, you have some serious core flex going on there
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: RT540] #1890041
08/12/15 02:19 AM
08/12/15 02:19 AM
North Sweden
RT540 Offline OP
RT540  Offline OP
North Sweden
The cam is a left over part from the B1TS engine that had a block with a crack in the main cap area.
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: RT540] #1890850
08/13/15 09:33 AM
08/13/15 09:33 AM
North Sweden
RT540 Offline OP
RT540  Offline OP
North Sweden
Just got of the phone with PSI springs tech, and it´s ok to remove the inner spring, as these are triple. He said it was quit common.
They are installed at 2.10" with 375 and 960 open at 790 intake lift.
With just two springs, the PSI tech guy said that seat will be at 317pounds and 820 open.
These B1 heads have titan. intake valves, so I think I will remove the inner spring until I can have the block machined for a 55mm cam. It will be a nitrous cam.
Still have not started the engine, but maybe this weekend.
Thanks for all posting.
Tom
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: RT540] #1890872
08/13/15 10:50 AM
08/13/15 10:50 AM
Nebraska
70VcodeCoronetRT Offline
Nebraska
Anyone use the Mopar Performance 90 degree method anymore?
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: 70VcodeCoronetRT] #1890995
08/13/15 01:55 PM
08/13/15 01:55 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You're kidding right??? This IS Moparts
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: RT540] #1891026
08/13/15 02:42 PM
08/13/15 02:42 PM
Nebraska
Nebraska
I Guess I'm not in the know. grin
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: 70VcodeCoronetRT] #1891032
08/13/15 02:50 PM
08/13/15 02:50 PM
Az
Crizila Offline
Crizila  Offline
Az
I use it.
Fastest 300
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: 70VcodeCoronetRT] #1891054
08/13/15 03:29 PM
08/13/15 03:29 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I do, but I'm not afraid to try different methods. My new build uses a solid roller so I think while it's on the stand with the intake off I'll try some different methods just to see how accurate they are. I'm no where near that point in the build yet though.
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: 70VcodeCoronetRT] #1891057
08/13/15 03:35 PM
08/13/15 03:35 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
"Anymore" would imply that you EVER used it, which I have not. Seemed like a waste of time to me the first time I ever saw it............LOL!!!
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: Monte_Smith] #1891065
08/13/15 03:52 PM
08/13/15 03:52 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I have set valves between runs going with the KISS method, Exhaust starts to open, set intake. Intake starts to close, set exhaust. What's the problem?
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: 70VcodeCoronetRT] #1891097
08/13/15 04:42 PM
08/13/15 04:42 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I used it recently, at least I think so. I used the chart that came with my Hughes Camshaft. I followed the directions that came with it to a T to make sure I didn't wipe the cam, or that if the cam did wipe it hopefully wasn't my fault.
I did it during the last angry thread about valve lash so was kind of worried about it. I didn't have the valley pan or intake on and can say the chart had me on the base circle like it should. I also paid attention to the rockers so I knew what to look for with the preferred EOIC as this was my first time with adjustable rockers. I think both methods would of netted me the same results for MY CAM.
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: RT540] #1891120
08/13/15 05:06 PM
08/13/15 05:06 PM
North Sweden
RT540 Offline OP
RT540  Offline OP
North Sweden
Tig welded this tool tonight( it´s nine a clock in Sweden) to remove valve springs.
Found two pieces of laser cut tabs.
Do I place the piston at BDC and add air pressure so the valves don't drop down?
Will need to cut a spark plug and weld on the air connection.
I guess I don't need much pressure to keep the valves staying up.
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: RT540] #1891137
08/13/15 05:29 PM
08/13/15 05:29 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Piston at TDC and add air. I use the hose from my compression tester (remove the schrader valve)...hooks right up to my air hose.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: RT540] #1891138
08/13/15 05:30 PM
08/13/15 05:30 PM
Az
Crizila Offline
Crizila  Offline
Az
Piston at TDC. That way there is no chance of the valves falling in to the cylinders if they come unseated.
Fastest 300
Re: Setting valve lash at base circle with EOIC, weird result?? [Re: RT540] #1891139
08/13/15 05:31 PM
08/13/15 05:31 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I don't worry about where the piston is, sometimes it moves to the bottom but most of the time it doesn't move at all. I use around 35 psi when I do it.
