Re: Setting valve lash at base circle with EOIC, weird result??
[Re: RT540]
#1887001
08/07/15 05:29 PM
08/07/15 05:29 PM
Thumperdart
State of confusion
Yes, I had the same results at FULL lift on each but some said maybe shaft deflection however I`m not convinced since I got .004 difference on every single one...........
[Re: RT540]
#1887020
08/07/15 06:03 PM
08/07/15 06:03 PM
Thumperdart
State of confusion
Good luck and enjoy.............
[Re: RT540]
#1887199
08/07/15 11:01 PM
08/07/15 11:01 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
I have shaft rockers and have the same thing, at TDC the valve lash is about .004" more lash compared to setting them at EOIC method. So I always set them on the EIOC method and never had any issues.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: RT540]
#1887224
08/07/15 11:33 PM
08/07/15 11:33 PM
Posts: 778 Sherwood park, Alberta.
go green
Flimsy valvetrain and a small cam shaft core,it is what it is. Just put another hot dog on the barbecue ,crack a beer , and turn up the radio.
[Re: RT540]
#1887230
08/07/15 11:39 PM
08/07/15 11:39 PM
slammedR/T
I don't know I have a billet cam, MRL solid lifters, Manton pushrods and T&D shaft rockers. I don't think that is the issue but I could be wrong...
[Re: go green]
#1887380
08/08/15 11:14 AM
08/08/15 11:14 AM
Posts: 10,018 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Flimsy valvetrain and a small cam shaft core,it is what it is. Just put another hot dog on the barbecue ,crack a beer , and turn up the radio. Stock size parts plus huge springs and radical cam lobes equal problems. It helps in my opinion to set the lash where you see the most clearance just to take some impact loads off the parts when the lifter first contacts the opening ramp.
[Re: RT540]
#1887635
08/08/15 08:26 PM
08/08/15 08:26 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
my dad and just set the lash on a new motor today. We moved the exhaust valve to max lift and it did loosen the lash on the intake a small amount, I didn't mess with measuring it but it made the feeler gauge go in and out easier. We ran it EOIC because that is what the man who spec'd the cam recommended.
68 Barracuda Formula S 340
[Re: RT540]
#1887899
08/09/15 04:09 AM
08/09/15 04:09 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
I never saw the logic of setting one valve according to what another valve is doing, but, whatever.
People that still use the EOIC method must like barring/bumping the motor over about 20 times to set valves when it can easily be done doing it in about 5-6 rotations.
I bring the #1 intake to fully open, then rotate the crank 1 turn, which leaves the #1 intake solidly on it's base circle. Set #1 intake. Rotate crank 90* - Set #8 intake. Rotate crank 90* - set #4 intake. Follow this pattern through firing order to set all intakes. Now bring #1 exhaust to fully open, then rotate crank 1 turn, which leaves the #1 exhaust solidly on it's base circle. Set #1 exhaust. Rotate crank 90* - set #8 exhaust. Again, follow pattern through firing order to set all the exhaust valves.
This works with EVERY canshaft, no matter lift, duration, lobe separation, or firing order, and sets the lash off of its cam lobe and not another one.
Pretty simple, HUH?
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Duner]
#1888043
08/09/15 02:18 PM
08/09/15 02:18 PM
Posts: 7,506 Az
Crizila
Az
I bet that would work awesome on an engine stand.
You are assuming that somebody could get to the crank bolt to turn it 90°? Hahaha
Not in my rig. We're hot-rodders. We do what we need to do to make it work. Ya, it can get pretty tight up front if you are running a blower, etc. I made an adaptor because my crank bolt isn't accessible. Still a pain. End up using a remote start switch and just get as close as I can bumping it over.
Fastest 300
[Re: Duner]
#1888121
08/09/15 04:37 PM
08/09/15 04:37 PM
Evil Spirit
Newport, Mi
Not ASSUMING anything - I KNOW that you have to have a method to turn the crank no matter what method you use.
[Re: Duner]
#1888690
08/10/15 12:13 PM
08/10/15 12:13 PM
Posts: 7,506 Az
Crizila
Az
Isn't the hotrod world awesome? We all get to pick our own way of making things work for ourselves without anybody else being condecending about it or feeling THEIR way is the only way and that everybody else is doing it wrong. Well, one thing is for sure, doing it in 110 degree is wrong - no matter how you do it. Been to the pavilions lately Dwayne?
Fastest 300
[Re: Crizila]
#1889240
08/11/15 01:24 AM
08/11/15 01:24 AM
Posts: 1,969 Chandler, AZ
Duner
Chandler, AZ
Isn't the hotrod world awesome? We all get to pick our own way of making things work for ourselves without anybody else being condecending about it or feeling THEIR way is the only way and that everybody else is doing it wrong. Well, one thing is for sure, doing it in 110 degree is wrong - no matter how you do it. Been to the pavilions lately Dwayne? Hahaha... yeah, it's a bit warm out! The sweat running into my eyes takes some of the fun out of adjusting my valves. LOL The pavilions aren't much fun anymore. They run everybdy out of the parking lot about the time it might even begin to start cooling off. I don't know how some of those guys do it. They show up at noon, pull out their lawn chairs and bake. NO THANKS! I'm not setting foot on the place until it gets dark.
