360 popping sound from my exhaust #1889318
08/11/15 06:20 AM
08/11/15 06:20 AM
midwest
superchuck Offline OP
On thin ice
On thin ice
midwest
My 360 gives off a popping sound through the exhaust I can't track down. Also it will idle good for a minute then slowly get rough and I cant get the RPM over 5000 RPM going down the track and starts cackling around 3000 like having a miss.
The engine is a 360 with speed pro flat tops stock heads, lunati voodoo 268 cam with the correct valve springs and pressures. Holley 650 DP on a crosswinds airgap intake. The ignition is a Mallory hyfire 6al and a MP dizzy.
Thing I ruled out or swapped
1 The dizzy
2 checked the cam lobes and lifter they are good
3 no broken valve springs
4new wires, cap, rotor, and plugs
5 timing at 35 degrees at 3000 rpm (doesn't matter where I set it, it popps.
6 intermediate shaft clocked correctly
7 ignition box (swapped with a know good one)
8 engine and chassis grounds
9 carb float levels good
I have the engine running a bit rich plugs were dark but 3 of the plugs were wet with fuel. Will running way rich cause this problem with the popping and not getting it to go over 5000 at the track? Vacuum leak?
Re: 360 popping sound from my exhaust [Re: superchuck] #1889336
08/11/15 09:20 AM
08/11/15 09:20 AM
OH--IO
3
360904 Offline
360904  Offline
OH--IO
push rods to long, if this is a hydraulic cam the lifter pumps up and hangs the valves open. amhik......
Re: 360 popping sound from my exhaust [Re: superchuck] #1889366
08/11/15 10:55 AM
08/11/15 10:55 AM
Az
Crizila Offline
Crizila  Offline
Az
Replace the other 4 ignition wires. Fuel delivery issues as in "not enough" - even though the float level is ok.
Fastest 300
Re: 360 popping sound from my exhaust [Re: superchuck] #1889440
08/11/15 12:48 PM
08/11/15 12:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
1 The dizzy
NEW plugs and get a wideband so you have a direction to go based on your readings and what fuel pump do you run......
Re: 360 popping sound from my exhaust [Re: superchuck] #1889464
08/11/15 01:16 PM
08/11/15 01:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Does your carb have air bleeds... if so check
for a plugged one... is this a fresh engine
wave
Re: 360 popping sound from my exhaust [Re: 360904] #1890066
08/12/15 04:27 AM
08/12/15 04:27 AM
midwest
On thin ice
On thin ice
midwest
Not the pushrods, Ive ran them with the this cam before I swapped out to the MP solid. Never had an issue
Re: 360 popping sound from my exhaust [Re: Thumperdart] #1890067
08/12/15 04:28 AM
08/12/15 04:28 AM
midwest
On thin ice
On thin ice
midwest
1 The dizzy
New plugs, and I'm using a Holley blue pump and set at 5 PSI on the regulator.
Re: 360 popping sound from my exhaust [Re: MR_P_BODY] #1890068
08/12/15 04:31 AM
08/12/15 04:31 AM
midwest
On thin ice
On thin ice
midwest
wave
I'll check the air bleeds then swap on a new HP750 off a known good engine.
Engine isn't new, rebuilt it 12 years ago but has been refreshed about 3 years ago (rings and bearings) it's been run kind of hard but has less that 10K miles
Re: 360 popping sound from my exhaust [Re: superchuck] #1890073
08/12/15 05:17 AM
08/12/15 05:17 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I had a broken centrifigal advance spring that would make the engine do that on decel.
Re: 360 popping sound from my exhaust [Re: MR_P_BODY] #1928857
10/09/15 08:02 AM
10/09/15 08:02 AM
midwest
On thin ice
On thin ice
midwest
wave
UPDATE:
Went through the carb, airbleeds are clean. I thought I found the problem with the needle and seat. I upgraded to a .130 one. I cannot get this engine above 5500 RPM whether running it down the track or popping it in neutral and stomping the gas. One thing that did happen was on my 3rd pass of the night it blew the vacuum plug off the base of the carb. The car didn't seem to backfire but how can a very tight rubber cap with a vacuum sucking on it blow off? Exhaust valve not sealing at higher RPM? My compression test read good. Maybe the pushrods are too long like 360 904 said.
Re: 360 popping sound from my exhaust [Re: superchuck] #1928858
10/09/15 08:09 AM
10/09/15 08:09 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Valve springs.
Re: 360 popping sound from my exhaust [Re: superchuck] #1928867
10/09/15 09:14 AM
10/09/15 09:14 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Lean= pop in the intake
Rich= pop in the exhaust
If you're getting pops in the exhaust, there is un burned fuel going through the engine. Look at ignition, and/ or extreme rich mixture.
Re: 360 popping sound from my exhaust [Re: superchuck] #1928877
10/09/15 09:57 AM
10/09/15 09:57 AM
France Europe
Laurent Offline
Laurent  Offline
France Europe
??? Faulty ignition coil / ballast resistor ????
Re: 360 popping sound from my exhaust [Re: Laurent] #1929084
10/09/15 03:24 PM
10/09/15 03:24 PM
(1) carb issue (2) vac leak. swap on another carb even a stock one & you'll have an answer quick. Not it?, then (I'd) replace the intake gaskets with the felpro ones with the blue borders around the port openings with permatex 99MA spray glue/cement & toss the cork end gaskets (most are too tall & can hold the intake up/depends on prior milling etc) & use "the right stuff" cement instead EDIT swap a coil FIRST! (easy)
Re: 360 popping sound from my exhaust [Re: superchuck] #1929126
10/09/15 04:21 PM
10/09/15 04:21 PM
P
Paul_Fancsali Offline
P
Go with rapidrobert on this one I finally fixed my one car and found low voltage to coil.
