Re: Indy Aluminum Block Oil Pressure Issues
[Re: KD800X]
#1889233
08/11/15 01:09 AM
08/11/15 01:09 AM
Posts: 11,719 Portage,michigan
B3422W5
Portage,michigan
I bet they will tell him to bush the lifter bores to fix those leaks. Probably the issue.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: KD800X]
#1889247
08/11/15 01:35 AM
08/11/15 01:35 AM
Posts: 576 Texas
ChevyTS
Texas
We had an issue with a cam bearing walking out on our Indy block causing low oil pressure.
T & K Performance
[Re: ChevyTS]
#1889562
08/11/15 04:01 PM
08/11/15 04:01 PM
Posts: 31,050 Oregon
AndyF
We had an issue with a cam bearing walking out on our Indy block causing low oil pressure. Yeah, that would do it too! The big problem with aluminum blocks is the thermal expansion. If the engine builders aren't used to building with aluminum blocks they might not select the correct clearances. When the block grows the clearances open up. In some cases the clearances can open up enough to cause problems.
