Re: worn fuel pump push rod
[Re: mopars4ever]
#1890180
08/12/15 11:51 AM
08/12/15 11:51 AM
Posts: 16,162 Mesa, Arizona
dart4forte
Mesa, Arizona
Mopar supposedly had put a bad batch of the push rods out years ago so when you get a new one I would look elsewhere. This issue has been a subject of conversation for years. Years ago a bad batch of fuel pump rods were in circulation. Looks like you got one of them. The rod should be hardened. Since then I've checked rods that I've installed by running a file over each end. If I get shavings the rod is bad. Make sure you place a few magnets at the bottom of your pan. This issue was also a problem with the mechanical cam adjusters. The tips in contact with the pushrods would prematurely wear down. Crane Cam adjusters were the main culprit since they got most of their small parts from off shore.
Abe Lincoln
[Re: joelson6]
#1890255
08/12/15 02:11 PM
08/12/15 02:11 PM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
I believe mccannix still might have a few NOS Fuel Pump Push Rods around. I bought a tin can full of them off him a year ago or so. He still had a lot more left. I just bought them because of the problem that happened over the years with the wear on these rods.
1971 HEMI E BODY REGISTRY
[Re: joelson6]
#1890264
08/12/15 02:26 PM
08/12/15 02:26 PM
Posts: 13,613 md
mopars4ever
md
The problem is one cannot reduce the problem to one bad batch of fuel pump pushrods sold by MP or Direct Connection. Not reducing it to anything, just warning him to stay away from them.
[Re: joelson6]
#1890950
08/13/15 12:45 PM
08/13/15 12:45 PM
Posts: 863 Pinelands , NJ
joelson6
Pinelands , NJ
Thanks for the concern about the bad batch of fuel pump rods. but like JohnRR said, this rod has been in the engine since 1970. there was no problem with the original cam and rod. the problem developed when i installed the Edelbrock cam. I'm thinking it had something to do with the cam, that's why I'm replacing the cam. now i just have to wait 2 more weeks for the new cam to get here.
[Re: dart4forte]
#1891364
08/13/15 10:16 PM
08/13/15 10:16 PM
Posts: 137 Daytona Beach, FL
cknight
Daytona Beach, FL
Mopar supposedly had put a bad batch of the push rods out years ago so when you get a new one I would look elsewhere. This issue has been a subject of conversation for years. Years ago a bad batch of fuel pump rods were in circulation. Looks like you got one of them. The rod should be hardened. Since then I've checked rods that I've installed by running a file over each end. If I get shavings the rod is bad. Make sure you place a few magnets at the bottom of your pan. This issue was also a problem with the mechanical cam adjusters. The tips in contact with the pushrods would prematurely wear down. Crane Cam adjusters were the main culprit since they got most of their small parts from off shore. Crane made the adjusters (and virtually all of their "small parts") in house. Nothing from offshore. There was a heat treat issue, and a recall followed. As Crane only knew who bought them directly, they had to depend on the distributors to follow up with their customers. No internet back then. Some folks were more responsive then others. Regards, Chase
[Re: joelson6]
#1891577
08/14/15 02:42 AM
08/14/15 02:42 AM
Posts: 13,613 md
mopars4ever
md
He said the rod he reused was the original rod that was installed in the engine in 1970 so those beating the bad batch dead horse are doing just that. Again, not beating a dead horse. His old rod is bad correct? He needs a new one correct? Just warning him to stay away from the mopar ones in case he may get one that may be from that bad batch.
[Re: mopars4ever]
#1891704
08/14/15 10:36 AM
08/14/15 10:36 AM
joelson6
Pinelands , NJ
He said the rod he reused was the original rod that was installed in the engine in 1970 so those beating the bad batch dead horse are doing just that. Again, not beating a dead horse. His old rod is bad correct? He needs a new one correct? Just warning him to stay away from the mopar ones in case he may get one that may be from that bad batch. i never answered this, but i didn't get a "bad" rod from mopar. i bought a rod from Howards Cams. a lot of people recommended that. plus the new cam and lifters are from Howards.
[Re: cknight]
#1891719
08/14/15 10:59 AM
08/14/15 10:59 AM
dart4forte
Mesa, Arizona
Mopar supposedly had put a bad batch of the push rods out years ago so when you get a new one I would look elsewhere. This issue has been a subject of conversation for years. Years ago a bad batch of fuel pump rods were in circulation. Looks like you got one of them. The rod should be hardened. Since then I've checked rods that I've installed by running a file over each end. If I get shavings the rod is bad. Make sure you place a few magnets at the bottom of your pan. This issue was also a problem with the mechanical cam adjusters. The tips in contact with the pushrods would prematurely wear down. Crane Cam adjusters were the main culprit since they got most of their small parts from off shore. Crane made the adjusters (and virtually all of their "small parts") in house. Nothing from offshore. There was a heat treat issue, and a recall followed. As Crane only knew who bought them directly, they had to depend on the distributors to follow up with their customers. No internet back then. Some folks were more responsive then others. Regards, Chase Thanks for the update. Just wanted to point out that there are still some bad adjusters floating around in the used parts world. We're you with the old Crane Cams?
Abe Lincoln
[Re: dart4forte]
#1891876
08/14/15 03:50 PM
08/14/15 03:50 PM
cknight
Daytona Beach, FL
Mopar supposedly had put a bad batch of the push rods out years ago so when you get a new one I would look elsewhere. This issue has been a subject of conversation for years. Years ago a bad batch of fuel pump rods were in circulation. Looks like you got one of them. The rod should be hardened. Since then I've checked rods that I've installed by running a file over each end. If I get shavings the rod is bad. Make sure you place a few magnets at the bottom of your pan. This issue was also a problem with the mechanical cam adjusters. The tips in contact with the pushrods would prematurely wear down. Crane Cam adjusters were the main culprit since they got most of their small parts from off shore. Crane made the adjusters (and virtually all of their "small parts") in house. Nothing from offshore. There was a heat treat issue, and a recall followed. As Crane only knew who bought them directly, they had to depend on the distributors to follow up with their customers. No internet back then. Some folks were more responsive then others. Regards, Chase Thanks for the update. Just wanted to point out that there are still some bad adjusters floating around in the used parts world. We're you with the old Crane Cams? Yes, those have been floating around for over 15 years. Been here at Crane since 1967......Chase
