Pinion Bearing Seized up and now trans smoked #1885602
08/05/15 02:12 PM
08/05/15 02:12 PM
Illinois
SGTFURY62 Offline OP
Illinois
Took the 62 Plymouth out awhile back and BAM car stopped in it's tracks. Rear locked up. Pulled everything and found the pinion bearing had seized itself to the pinion. Replaced the 3rd member and now realize won't move in 2nd or drive. Major slipping and can feel engage but no go. Looks like I'll replacing a transmission. Is this common when a rear locks up? Was only going around 10 mph from a stop sign so feel lucky didn't do more damage.
Re: Pinion Bearing Seized up and now trans smoked [Re: SGTFURY62] #1885606
08/05/15 02:16 PM
08/05/15 02:16 PM
New Jersey, US of A
PlumCrazy73Dodge Offline
New Jersey, US of A
The trans has too much moving inside when the car is moving. When you just basically throw a wrench into the gears it does not end well. I am not surprised to see a trans issue after a rear locking. If all you did was swap the member, the trans is collateral damage if its having issues too.
73 plumcrazy challenger - 318/904, edelbrock performer 600cfm carb, performer intake and cam. Eddy Alum. Heads 3.91 locker, Doug's headers, accurate ltd. exhaust
73 Cuda - Triple Black 340 4 speed
MIKE
Re: Pinion Bearing Seized up and now trans smoked [Re: SGTFURY62] #1885724
08/05/15 04:58 PM
08/05/15 04:58 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Something sound fishy to me? You sure the pinion bearing caused the rear to lock? Wouldn't the pinion bearing have to be welded/ seized in the third member to lock up the rear? or was it?
Maybe it was the trans the whole time? Or not?
Re: Pinion Bearing Seized up and now trans smoked [Re: Challenger 1] #1885738
08/05/15 05:23 PM
08/05/15 05:23 PM
an8sec70cuda Offline
Something sound fishy to me? You sure the pinion bearing caused the rear to lock? Wouldn't the pinion bearing have to be welded/ seased in the third member to lock up the rear? or was it?
iagree Maybe he just worded it wrong. shruggy
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Pinion Bearing Seized up and now trans smoked [Re: SGTFURY62] #1885907
08/05/15 09:36 PM
08/05/15 09:36 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Busted sprag? Like a 1st gear bburnout?
Angry white pureblood male
Re: Pinion Bearing Seized up and now trans smoked [Re: SGTFURY62] #1885919
08/05/15 09:56 PM
08/05/15 09:56 PM
Illinois
Illinois
Pinion seized and welded self to 3rd member. It was reason car stopped.
Re: Pinion Bearing Seized up and now trans smoked [Re: SGTFURY62] #1885946
08/05/15 10:39 PM
08/05/15 10:39 PM
Illinois
Illinois
Think it burnt 2nd and 3rd out, first and reverse band still normal. Car tries to move in upper gears but slips too much
