Milodon gear drive lunati cam degree help #1883027
08/01/15 06:43 PM
08/01/15 06:43 PM
nc
E
earthmover Offline OP
E
nc
Trying to get my cam degreed in my love deck with the milodon gear drive I have the instructions for the gear drive but not my cam card but I do have the basic info..was told by lunati it's a 112 lobe sep. And install at 108..can someone walk me through this I've got my TDC but this gear drive set up is confusing a little. .thanks
Re: Milodon gear drive lunati cam degree help [Re: earthmover] #1883075
08/01/15 09:05 PM
08/01/15 09:05 PM
Minnesota
Coldart Offline
Coldart  Offline
Minnesota
set lash first,Milodon recommends regular newspaper but use printed ad paper. milodon.com geardrive set-up instructions. can get frustrating but is easy
Re: Milodon gear drive lunati cam degree help [Re: Coldart] #1883106
08/01/15 09:36 PM
08/01/15 09:36 PM
nc
E
E
nc
I have the instructions I have it set on TDC now I'm lost lol
Re: Milodon gear drive lunati cam degree help [Re: earthmover] #1883187
08/01/15 11:52 PM
08/01/15 11:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the paper method on my KB gear drive,,, been on
there for 9 years now
wave
Re: Milodon gear drive lunati cam degree help [Re: earthmover] #1883220
08/02/15 12:38 AM
08/02/15 12:38 AM
Wi.
old_racer Offline
old_racer  Offline
Wi.
to get you close if you've never used one take a stock cam gear from any timing chain and hold it up over the milodon one put the dot at 6:00 like you normally would and look where the cam pin is , then put the milodon gear in the same relationship then degree in an see how far you're off and change from there.
Re: Milodon gear drive lunati cam degree help [Re: earthmover] #1883295
08/02/15 02:18 AM
08/02/15 02:18 AM
Welcome to the wondeful world of speed parts, is your cam a three bolt cam? If so position the #1 piston at TDC and move the cam without the outer Milidon gear on it so the cam pin is between 3 oclock and 4 o clock(lower right side of the clock face) position facing the front of the cam, install the outer gear and go throught the lobe seperation timing procedure, move the outer gear to get it where you want it up I've used the 3 major three gear drives like yours, most of the them, Donovan, KB and Milidon, are very similar on the install procedures, a real pain in the rear shruggy Take your time, write it all down and see which way you need to move the gear to make it advance or retard up twocents Let us know how you do up
Re: Milodon gear drive lunati cam degree help [Re: earthmover] #1883301
08/02/15 02:25 AM
08/02/15 02:25 AM
Arizona
Chris'sBarracuda Offline
Arizona
Welcome to the Milodon Gear Drive instructions crowd..
Now you see why they "SELL" the video of how to.. work
From Dodgem: His simple how to, worked for me.
I really like mine got two one in the box form my next 542 and one that came with this JWD 452.
First yo put them on with no lower dowel pins and get gear clearance right drill to 5/16 and install 5'16 dowels and that is done.
Trick is there are no timing marks!
You turn the cam to .050 lift and turn the crank to the @.050 number you desire and then line the top gear up so 7 bolts line up perfectly and tighten gear then do your regular degree checks to make sure where you are!! then mark things and any advancing and retarding of cam from where you are is done buy lining numbers up to the original 1 mark!!
So if you have a 260 @ .050 cam and you want it at 106 you divide 260 by 2 = 130 then you subtract 106 this leave 24 so you want @.050 lift at 24 BTDC (before)
This helped me greatly. thumbs
Chris.. shruggy
Re: Milodon gear drive lunati cam degree help [Re: earthmover] #1883319
08/02/15 03:16 AM
08/02/15 03:16 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
im going through this this weekend too thanks chris's cuda,i went over the websites instructions,got the play done in the gears,pins in,got it installed straight up,now have to go and check centerline number,i check centerline of cam,cam out to 114,and they want it installed at 108,according to the chart ,theres a 4 or 6.5 retard,should I go with 4 or 6.5
Re: Milodon gear drive lunati cam degree help [Re: earthmover] #1883417
08/02/15 11:15 AM
08/02/15 11:15 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I got so fed up trying to set up an old Donovan gear drive I finally tore it off and installed a good chain set !! It would have been really simple if the idler gear had been the same size as the crank gear but it wasn't so if you turned the engine over two revolutions, the timing marks no longer lined up !! Anyhow, I figured it was overkill for my build anyway!
Re: Milodon gear drive lunati cam degree help [Re: earthmover] #1883455
08/02/15 12:24 PM
08/02/15 12:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I do my differently.. I set the crank at 108 on the degree
wheel(after zeroing) then set the number one intake lifter
at max lift... slide on the gear... recheck to see if its on
or change it if needed... I will check the exhaust also...I
usually set the cam with just the #1 piston in it.. makes it
so much easier to turn... when I check I use the .050 before
and after on the lifter
wave
Re: Milodon gear drive lunati cam degree help [Re: MR_P_BODY] #1883464
08/02/15 12:37 PM
08/02/15 12:37 PM
Memphis TN
B1HEAD_USER Offline
B1HEAD_USER  Offline
Memphis TN
I also do it like Mr P. It's so easy a cave man can do it stirthepot
Re: Milodon gear drive lunati cam degree help [Re: B1HEAD_USER] #1884710
08/03/15 11:49 PM
08/03/15 11:49 PM
Arizona
Arizona
Another note..
Your Harmonic Balancer might be about .125"+ out further.
Mine was. I guess the crank gears is thicker than timing chain stuff.
Chris.. wave
