Band lever #1881715
07/30/15 08:28 PM
07/30/15 08:28 PM
baldwinsville new york
a493demon Offline OP
Anyone know how to identify the band lever ratio ?
I have a billet steel one with no markings on it .
I also have a 5.0 one and they looks just about the same.
The guy who built the trans. says it a 4.2 but I just want to make sure.
So if anyone has anyway to tell I sure would appreciate it.
Guess I'm looking for measurement's .
Thanks Brad
Re: Band lever [Re: a493demon] #1881903
07/31/15 12:07 AM
07/31/15 12:07 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
hope this works..... and if so, hope it helps.
you can see as the ratio increases, the area from the cross shaft hole to the "V" decreases.
Re: Band lever [Re: J_BODY] #1881939
07/31/15 12:34 AM
07/31/15 12:34 AM
Eastern WA
P
ProStock1320 Offline
P
Eastern WA
Wow, doesn't get clearer than that. Great pic.
Re: Band lever [Re: a493demon] #1881949
07/31/15 12:41 AM
07/31/15 12:41 AM
cool thanks for the pic.
That is just what I needed to figure out the ratio.
Thanks Brad
Re: Band lever [Re: a493demon] #1882822
08/01/15 12:52 PM
08/01/15 12:52 PM
NC
440Jim Offline
440Jim  Offline
NC
I never worried about the dimension since Mopar stamps the ratio on the levers. But since somebody is making unmarked levers, it would be good to have the dimensions to help ID them. In my drawers, I only have old stock levers, so can anybody add the dimension for the 4.2 and 5.0 levers?
2.9 = 0.400"
3.2 = 0.335"
3.8 = 0.255"
4.2 = 0.
5.0 = 0.
Re: Band lever [Re: a493demon] #1882871
08/01/15 02:37 PM
08/01/15 02:37 PM
the 5.0 is .126 at the thinnest area.
i'll check the 4.2 later today .
Re: Band lever [Re: a493demon] #1882874
08/01/15 02:46 PM
08/01/15 02:46 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
my 4.2 is in my trans too or I'd put in my .02. All my levers were stamped except for my 4.2 which I bought off of Ebay earlier this year.
Re: Band lever [Re: J_BODY] #1882889
08/01/15 03:12 PM
08/01/15 03:12 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
.214" for the 4.2
Gary
Re: Band lever [Re: Mr340] #1882907
08/01/15 03:27 PM
08/01/15 03:27 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
What's the advantage of the different sizes??
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Band lever [Re: a493demon] #1882911
08/01/15 03:41 PM
08/01/15 03:41 PM
well I get .190 on my 4.2
Re: Band lever [Re: Stroker Scamp] #1882912
08/01/15 03:46 PM
08/01/15 03:46 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Leverage on band apply... 3.8/4.2 seems to be preferred as it gets the job done with less fill time on the servo.
Re: Band lever [Re: a493demon] #1882914
08/01/15 03:56 PM
08/01/15 03:56 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I was told not to use the 5.0 on trans breaks. I am not sure why, I just don't do it.
Re: Band lever [Re: a493demon] #1882922
08/01/15 04:12 PM
08/01/15 04:12 PM
My griner t-brake say's never use a 5.0 lever.
That is why I posted the question.
Re: Band lever [Re: a493demon] #1882925
08/01/15 04:19 PM
08/01/15 04:19 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Wile you have it apart beef up the plate that goes between the lever and band. I make a little thicker one.
Re: Band lever [Re: a493demon] #1882942
08/01/15 04:49 PM
08/01/15 04:49 PM
I have all the good stuff in it already.
But thanks.
Re: Band lever [Re: a493demon] #1882993
08/01/15 06:17 PM
08/01/15 06:17 PM
NC
440Jim Offline
440Jim  Offline
NC
That was quick !
Here is a table including my estimated calculations trying to account for the dia of the hole and the strut contact area. 2.15" is my estimate of the total length between the contact locations. But the caliper measurement of the V to the hole is enough to ID the ratio.
For example:
2.15/3.8 - 0.325 = 0.241
variance = 0.241 - 0.255 = -0.014
Re: Band lever [Re: FastmOp] #1883002
08/01/15 06:27 PM
08/01/15 06:27 PM
NC
440Jim Offline
440Jim  Offline
NC
I agree. There are a couple ways to make it stiffer, here is one that is thick in the middle and tapered to the ends.
Re: Band lever [Re: a493demon] #1883003
08/01/15 06:29 PM
08/01/15 06:29 PM
that's the type I have
Re: Band lever [Re: a493demon] #1883005
08/01/15 06:30 PM
08/01/15 06:30 PM
this should go tech. section t be saved
Re: Band lever [Re: a493demon] #1883025
08/01/15 06:42 PM
08/01/15 06:42 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I've seen picts of a stock strut with a bolt welded to the top of it. smile whatever works!
I agree.... has to be somewhere to stash that chart.
