Re: 727 clutch and manual valve body install
[Re: Adam71Charger]
#1862350
07/02/15 08:31 PM
07/02/15 08:31 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Thats a really good idea Andy, do you sell those adapter brackets? @Barracuda7199, I cannot find a number on my kickdown lever, is it really tiny? What you have pictured is the throttle pressure lever and since you are going to a RMVB you will not be using it when you put the transmission back in. The kickdown lever is the one that pushes on the strut that closes the 2nd gear band and they are numbered.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Adam71Charger]
#1878639
07/26/15 07:39 PM
07/26/15 07:39 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
Finally got time to reassemble my tranny. Ive got 15 springs in my front clutch, and 4 frictions and steels. Tranzact specifies that a front clutch clearance of .060 and .050 is required for their valve body. I had almost .080. So I switched my front drum snap ring with the rear drum snap ring, but I still have about .072 clearance, too much. The snap ring is .076", so i guess my only solution is to order a set of thicker snap rings. After assembling the rear drum, even with the thinner snap ring (.062"), I barely have .010 clearance. I dont know how to solve that issue, as Im supposed to have .030 to .040
[Re: Adam71Charger]
#1878788
07/26/15 10:32 PM
07/26/15 10:32 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Suppose to check the clearance with the disc dry....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Adam71Charger]
#1879325
07/27/15 04:38 PM
07/27/15 04:38 PM
Posts: 27,254 Rio Linda, CA
John_Kunkel
The Erection Connection
Rio Linda, CA
My lever has 3.8 stamped on it. You're good to go. Friction discs are generally about the same thickness but thicker steel plates are available...you might have those and they'll tighten up the clutch pack. Standard thickness is .070" and the thicker ones are .090".
[Re: Adam71Charger]
#1884344
08/03/15 02:22 PM
08/03/15 02:22 PM
John_Kunkel
Rio Linda, CA
Mix the thick/thin steels any way you desire...personally, I use the thicker steels at the outer end of the clutch pack, toward the snap ring.
[Re: Adam71Charger]
#1888859
08/10/15 02:52 PM
08/10/15 02:52 PM
John_Kunkel
Rio Linda, CA
Looks OK...if in doubt, look at the witness marks where the drum tangs previously wore on the driving shell slots.
[Re: Adam71Charger]
#1948130
11/09/15 03:18 PM
11/09/15 03:18 PM
John_Kunkel
Rio Linda, CA
Depends on the valve body, if the large hole in the separator plate over the accumulator is there the accumulator will still be in use....if there is no hole in the plate you can omit the accumulator piston.
