Re: 7AL-2, 7220 and start retard? Is it available?
[Re: Jeremiah]
#1876354
07/23/15 01:35 AM
07/23/15 01:35 AM
Posts: 1,443 Maryland
Dads426
Maryland
Put the advance back in the dizzy and only install one spring on the weight (other weight is installed with no spring). Motor will crank with less advance and go to full advance when it fires. Advance comes in so fast it will not vary with rpm.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#1876416
07/23/15 04:45 AM
07/23/15 04:45 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Put the advance back in the dizzy and only install one spring on the weight (other weight is installed with no spring). Motor will crank with less advance and go to full advance when it fires. Advance comes in so fast it will not vary with rpm. It comes locked out, no springs or weights.
[Re: jim sciortino]
#1876417
07/23/15 04:47 AM
07/23/15 04:47 AM
DemonDust
Menomonee Falls
MSD 8984 Starter Saver w/signal stabilizer
$120
Added it to the 7AL-2 in my car and it works like a charm. This sounds like exactly what I will need. Thanks Jim!
[Re: DemonDust]
#1876671
07/23/15 05:39 PM
07/23/15 05:39 PM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
Jesse I have the same box and its starts just fine with 15.4 comp with my timing locked out at 30*.
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
[Re: 440W8 Duster]
#1876710
07/23/15 06:32 PM
07/23/15 06:32 PM
DemonDust
Menomonee Falls
Jesse I have the same box and its starts just fine with 15.4 comp with my timing locked out at 30*. You just have the 7AL-2 or you have the box Jim mentioned as well?
[Re: DemonDust]
#1876996
07/24/15 12:42 AM
07/24/15 12:42 AM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
$120
Added it to the 7AL-2 in my car and it works like a charm. This sounds like exactly what I will need. Thanks Jim! Welcome..... My W8 has 14-1, locked at 31*....with a Braille 21 in the trunk. It turned lazy until I added the 8984 box.
[Re: DemonDust]
#1877047
07/24/15 02:07 AM
07/24/15 02:07 AM
440W8 Duster
San Antonio,TX
Jesse I have the same box and its starts just fine with 15.4 comp with my timing locked out at 30*. You just have the 7AL-2 or you have the box Jim mentioned as well? I have the 7220 box.
