7AL-2, 7220 and start retard? Is it available? #1876173
07/22/15 11:21 PM
07/22/15 11:21 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
Just curious and thinking ahead. If my engine being 15:1 now starts very hard since the dizzy is locked out. Is there anything I can add to my 7AL-2 for start retard? Or will I have to upgrade my ignition?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: 7AL-2, 7220 and start retard? Is it available? [Re: DemonDust] #1876181
07/22/15 11:28 PM
07/22/15 11:28 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
MSD makes timing modules that are either selectable or use the MSD style ship depending on what you buy. They also make a three step. They are usually ground-start i.e. you ground a wire to activate the timing retard so it could easily be tied into the "start" circuit.
http://www.jegs.com/i/MSD+Ignition/121/8...CFYMWHwodlEUNPQ
Re: 7AL-2, 7220 and start retard? Is it available? [Re: Jeremiah] #1876354
07/23/15 01:35 AM
07/23/15 01:35 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Put the advance back in the dizzy and only install one spring on the weight (other weight is installed with no spring). Motor will crank with less advance and go to full advance when it fires. Advance comes in so fast it will not vary with rpm.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: 7AL-2, 7220 and start retard? Is it available? [Re: DemonDust] #1876415
07/23/15 04:22 AM
07/23/15 04:22 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
MSD 8984 Starter Saver w/signal stabilizer
$120
Added it to the 7AL-2 in my car and it works like a charm.
Re: 7AL-2, 7220 and start retard? Is it available? [Re: Dads426] #1876416
07/23/15 04:45 AM
07/23/15 04:45 AM
Menomonee Falls
Menomonee Falls
It comes locked out, no springs or weights.
SDG Motorsports
Re: 7AL-2, 7220 and start retard? Is it available? [Re: jim sciortino] #1876417
07/23/15 04:47 AM
07/23/15 04:47 AM
Menomonee Falls
Menomonee Falls
$120
This sounds like exactly what I will need.
Thanks Jim!
SDG Motorsports
Re: 7AL-2, 7220 and start retard? Is it available? [Re: DemonDust] #1876671
07/23/15 05:39 PM
07/23/15 05:39 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
Jesse I have the same box and its starts just fine with 15.4 comp with my timing locked out at 30*.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: 7AL-2, 7220 and start retard? Is it available? [Re: 440W8 Duster] #1876710
07/23/15 06:32 PM
07/23/15 06:32 PM
Menomonee Falls
Menomonee Falls
You just have the 7AL-2 or you have the box Jim mentioned as well?
SDG Motorsports
Re: 7AL-2, 7220 and start retard? Is it available? [Re: DemonDust] #1876996
07/24/15 12:42 AM
07/24/15 12:42 AM
Trumbull,CT.
Trumbull,CT.
$120
Thanks Jim!
Welcome.....
My W8 has 14-1, locked at 31*....with a Braille 21 in the trunk. It turned lazy until I added the 8984 box.
Re: 7AL-2, 7220 and start retard? Is it available? [Re: DemonDust] #1877047
07/24/15 02:07 AM
07/24/15 02:07 AM
San Antonio,TX
San Antonio,TX
I have the 7220 box.
70 Duster W8 motor.
@3170 lbs.
