64 Max Wedge #1876249
07/23/15 12:12 AM
07/23/15 12:12 AM
TX
RiskyRickey Offline OP
TX
Need to know what to look for to ID a orignal max wedge car.the motor does not have # on pad .Aluminum front not with car.Thanks in advance
Re: 64 Max Wedge [Re: RiskyRickey] #1876345
07/23/15 01:17 AM
07/23/15 01:17 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Hole in the dash for the choke cable...
Brackets on the floorpan for the E brake cable re-route..
Screw holes on the drivers inner fender for the heater hose brackets
Firewall brake line/wiring harness re-routed
Decal in the glovebox
Re: 64 Max Wedge [Re: RiskyRickey] #1876363
07/23/15 01:52 AM
07/23/15 01:52 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
My suggestion? Hire an expert, pre 1966 cars are NOT easy to document, a few hints from a web forum will not arm you with what it really takes.
Re: 64 Max Wedge [Re: ScottSmith_Harms] #1876493
07/23/15 11:51 AM
07/23/15 11:51 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I thought all of the serial numbers are listed in the Darrel Davis books? If so then it's easy - right --- shruggy
Re: 64 Max Wedge [Re: max_maniac] #1876743
07/23/15 07:20 PM
07/23/15 07:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yeah, the DD book would be the first place to look.
Re: 64 Max Wedge [Re: RiskyRickey] #1876929
07/23/15 11:01 PM
07/23/15 11:01 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, the DD book is definitely the best place to refer to. That said, not all Max Wedge car VINS are in his books.
The bigger concern, a LOT of MW and early Hemi cars were race cars that have been hacked up and re-bodied over the years. You'll need to know a lot more than just finding the VIN# in the DD book to verify the car, but it's a good place to start. twocents
Re: 64 Max Wedge [Re: ScottSmith_Harms] #1876951
07/23/15 11:33 PM
07/23/15 11:33 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And if it's never been re bodied there should be the second set of emergency brake cable brackets welded to the floor pan or at least an indication that they were there at one time.
