Re: sun pro super tach
[Re: bonefish]
#1873538
07/19/15 02:53 PM
07/19/15 02:53 PM
Posts: 11,747 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Red and black are 12v + and -. Green is the trigger. I also believe that those tachs need an adapter to function correctly on the MSDs. Hook it up and try it. If it's way off, you need the adapter.
If accuracy is important, perhaps a higher quality, more up to date instrument would be a better choice. Not sure how much I would trust that old tach. A used Autometer or other modern unit should be easy to find for a good price.
[Re: bonefish]
#1873554
07/19/15 03:19 PM
07/19/15 03:19 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If it's really an old one and it works ok, guys will buy those for old muscle cars and period correct old race cars. If it's one of those with the American flag design or a "Big Daddy Don Garlits" model, throw it ebay and get a good tach for distributor machine.
[Re: bonefish]
#1873853
07/19/15 10:06 PM
07/19/15 10:06 PM
Posts: 4,848 Memphis
HemiRick
Memphis
It will NOT work without a tach adapter
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: bonefish]
#1874045
07/20/15 01:19 AM
07/20/15 01:19 AM
Posts: 360 Ohio
shorthorse
Ohio
Some people confuse the original Sun SST tachs with the Sunpro. They only look similar and that's where it stops. The original Sun tachs came in several different models. Some needed the tach adapter and some didn't. The easiest way to tell on an old Sun is to look at the lugs. If one is marked "trigger" it does not need an adapter. The ones that do will say "series transmitter" on the tag. To the best of my knowledge Sunpro didn't make tachs that required an adapter/transmitter but I could be way off on that. Sunpro was a tach manufactured in China by the Actron Corp. since 1988 which has since been acquired by Bosch.
From an article about Actron - "Since the 1980's, Actron has used acquisitions to advance its market position with significant additions: In 1986, Actron acquired the KAL Equip Company, a maker of professional automotive diagnostic equipment. And in 1988, Actron licensed the rights to the Sunpro tachometer and gauge business from Sun Electric/Snap-On. Meanwhile the company was years ahead of all other industry players with the implementation of its "right-sourcing" manufacturing strategy and the establishment of a factory in Yantai, China, in 1989."
After further investigation I understand the difference between the Sun transmitter adapter and the need for the MSD Tach Adapter. HemiRick is correct. It doesn't specifically say Sunpro but according to the 6AL installation instructions -
[Re: bonefish]
#1874211
07/20/15 12:02 PM
07/20/15 12:02 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
I used an old Sun super tach in my car for awhile for the 'period correct' look. It DID require an adapter that cost about $80.00 from MSD to work with the 6AL. I later saw where Sun makes NEW tachs that DON'T require an adapter that look like the old Sun tachs.
If you like drag racing, support your local track.
[Re: bonefish]
#1874296
07/20/15 01:44 PM
07/20/15 01:44 PM
HemiRick
Memphis
My one of those did NOT work w/o an adapter
[Re: bonefish]
#1874390
07/20/15 04:01 PM
07/20/15 04:01 PM
CHAPPER
Belpre,Ohio
this is the tach in question. Yep....that's the one I used too. Needed an adapter box.
[Re: bonefish]
#1874467
07/20/15 05:54 PM
07/20/15 05:54 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
No MSD= no adapter? I.E. MP box?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: poboyengineering]
#1874484
07/20/15 06:39 PM
07/20/15 06:39 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
No MSD= no adapter? I.E. MP box? Yup. Back in the early 80's I tried to run a new Sun Super Tach II with an MSD box, and even with the adapter it did not work. Gave up and bought an autometer.
[Re: bonefish]
#1874955
07/21/15 10:54 AM
07/21/15 10:54 AM
Posts: 75,102 A Banana Republic near you.
JohnRR
how can I tell how old it is?i think ive only had for MABEY 20 years and it was used when I got it.its just made out of plastic. Just saw the pictures super tach II, it's pretty much garbage. The tachII that was in my 69 Dart read low , 400 at idle , 1500 at 5000.
