Page 1 of 3 1 2 3
is there a better shifter ? #1871791
07/16/15 07:56 PM
07/16/15 07:56 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
is there a better shifter than Hurst/B&M ?
or at least a affordable option with rear exit cable ?
driving to work this morning feels like cable has stretched or gone out of adjustment and wont pull into 3rd .Again . And yes the cable is shielded etc
is going back to stock column shift the answer ? I have a griner RMVB
thoughts ?
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: is there a better shifter ? [Re: tex013] #1871826
07/16/15 08:40 PM
07/16/15 08:40 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Tex, Winters Performance has a rear entry gate style shifter for about $220. Summit says the housing/boot is not included so that means additional $$. From there they go up, way up. Even my PPP still uses a B&M cable but it "should" last longer just being away from the heat.
Re: is there a better shifter ? [Re: tex013] #1871864
07/16/15 09:19 PM
07/16/15 09:19 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
PPP is the best stuff out there and can be made the way you wan it.
Re: is there a better shifter ? [Re: tex013] #1871880
07/16/15 09:38 PM
07/16/15 09:38 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks guys
any thoughts on the TA Cheetah ?
Tex
New best MPH 130.32
Re: is there a better shifter ? [Re: tex013] #1871887
07/16/15 09:47 PM
07/16/15 09:47 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
The Cheetah cable exits the front of the shifter and loops around on the passenger side of the trans and back under the tail housing and attaches to the trans lever from the rear. It is not a ratchet shifter. It is gated and I have shifted 1-3 several times until I focused on what I was doing. Now, it shifts great and smooth. They have forward and reverse gates.
www.turboaction.com
Re: is there a better shifter ? [Re: tex013] #1871965
07/16/15 10:49 PM
07/16/15 10:49 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
DusterW2 ,
I see what you mean . a little awkward .
Just talked to Brad @ PPP , will see what pricing and shipping is . He suggested a push pattern to help with the trigger , made sense . Anyone try this ?
Tex
New best MPH 130.32
Re: is there a better shifter ? [Re: tex013] #1871968
07/16/15 10:54 PM
07/16/15 10:54 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
PPP is the best..........hands down
Re: is there a better shifter ? [Re: tex013] #1871992
07/16/15 11:07 PM
07/16/15 11:07 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I never had cable issues with the Cheetah..... however on about the third hit on our W8 combo, of wondering what the L was going on, the shifter was making the 1-2 shift when I'd release the trans brake on it's own. Also had our fair share of going from 1 to 3. It actually improved greatly when I ordered a different gate for it when I went to my clean N valve body...... but I sold it last week as I've had a used PPP that Al made me buy.
Re: is there a better shifter ? [Re: tex013] #1872110
07/17/15 01:33 AM
07/17/15 01:33 AM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
Dixie shifter..anyone ever use one of these? they are very nice besides the handle.its electric and can shift each gear at different rpm when running a three speed.had mine 20 years never missed a shift..
Re: is there a better shifter ? [Re: tex013] #1872471
07/17/15 07:25 PM
07/17/15 07:25 PM
Cairns Queensland Australia. T...
V
vc360 Offline
vc360  Offline
V
I have a PPP and love it, with griner rmvb pull back to up shift.
Re: is there a better shifter ? [Re: Al_Alguire] #1872493
07/17/15 07:45 PM
07/17/15 07:45 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
x100
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: is there a better shifter ? [Re: tex013] #1872502
07/17/15 07:55 PM
07/17/15 07:55 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I LOVE my $200 B&M ProRatchet, first thing I do is sell the 5' cable and buy a 4' cable and a 3' section of heat sleeve, no problems on a big block A-body and it's impossible to miss a shift like you can easily do on the Cheetah and Winters type shifters.
I'd like a PPP shifter just for the rear cable exit but can't justify the price for my street cruiser.
Re: is there a better shifter ? [Re: DusterW2] #1872514
07/17/15 08:17 PM
07/17/15 08:17 PM
fresno ca
mikeysmopars Offline
fresno ca
www.turboaction.com
iagree Exactly what he said. Good shifter for the money but the standard plate for the reverse shifter can make you shoot streight to high gear. I guess they make a dummy proof plate for that but that would be too easy biggrin
My next shifter will be a PPP
Founder and CEO of the Central Valley Mopar Drag Pack
Re: is there a better shifter ? [Re: vc360] #1872515
07/17/15 08:17 PM
07/17/15 08:17 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
VC360 ,
will you be at Mopar Sunday ? if so I will have a look at your setup .
the only worry I have with a PPP is room as I use a bench seat - have not seen 1 with this and not sure of how much room it needs
Tex
New best MPH 130.32
Re: is there a better shifter ? [Re: tex013] #1872577
07/17/15 10:16 PM
07/17/15 10:16 PM
V
vc360 Offline
vc360  Offline
V
Tex, sorry I won't be there this year.
Looks tight with the bench but they are compact.
I will measure the length and width of the bracket and let you know.
Shifter is 240mm overall where the top bolts are. 190mm at the bottom. Overall height of the shifter without bracket is 250mm to top of handle with bracket is 310mm.
The cable extends out around 200mm before it bends 180degrees.
You could make extended height brackets for it easy enough.
Re: is there a better shifter ? [Re: tex013] #1872699
07/18/15 01:35 AM
07/18/15 01:35 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks VC360,
that's great . how high off floor is the cable?
shame you will miss the day but oh well it happens
I do like how Willowbank is good to 10.50 for me woohoo
Tex
New best MPH 130.32
Re: is there a better shifter ? [Re: tex013] #1872739
07/18/15 03:09 AM
07/18/15 03:09 AM
V
vc360 Offline
vc360  Offline
V
Around 100 off floor.
Yes went last year but did not have happy day. Water pump packed it in.
Long way for me for a single day. Usually there is a t&t on the sat night before which makes it good but not last year.
Re: is there a better shifter ? [Re: tex013] #1872752
07/18/15 04:55 AM
07/18/15 04:55 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Thanks again VC360
I hear you on travel ,closer for me but still best part of 11 hrs drive . Yes there is a t&t the night before , plan on running it with a couple of mates
Hope all issues are done - broke t bar last month , front band strut yesterday , now dealing with shifter adjustment . Feel like i must have killed a chinaman .
Tex
New best MPH 130.32
Re: is there a better shifter ? [Re: tex013] #1872762
07/18/15 07:07 AM
07/18/15 07:07 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
like some others i've experianced 1-3rd shifts with my TA shifter, but it was my fault being too over excited in the heat of racing. i got over that when i did some training. now that i run a clean Neutral brake the shifter is almost imposible to stuff up. oh & before someone thinks there's something wrong with my set up, my Dart is Right Hand Drive & thats a trans line pressure guage youre looking at.
Re: is there a better shifter ? [Re: tex013] #1872815
07/18/15 11:32 AM
07/18/15 11:32 AM
west palm beach, florida
modelmakerinc Offline
iagree
I too have shifted past 2nd with a Cheetah but it is because of our body's geometry and "hanging on" to it through the shifts. I simply scewed the shifter to the right a little to better work with the direction my arm naturally pulls makes the gates more of a V than an L. It solved the trouble completely
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Page 1 of 3 1 2 3
