is there a better shifter ?
#1871791
07/16/15 07:56 PM
07/16/15 07:56 PM
Posts: 2,363 Sydney,Australia
tex013
Sydney,Australia
is there a better shifter than Hurst/B&M ? or at least a affordable option with rear exit cable ? driving to work this morning feels like cable has stretched or gone out of adjustment and wont pull into 3rd .Again . And yes the cable is shielded etc is going back to stock column shift the answer ? I have a griner RMVB thoughts ?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: is there a better shifter ?
[Re: tex013]
#1871864
07/16/15 09:19 PM
07/16/15 09:19 PM
Posts: 18,536 Las Vegas
Al_Alguire
Las Vegas
PPP is the best stuff out there and can be made the way you wan it.
[Re: tex013]
#1871880
07/16/15 09:38 PM
07/16/15 09:38 PM
tex013
Sydney,Australia
thanks guys any thoughts on the TA Cheetah ?
Tex
[Re: tex013]
#1871965
07/16/15 10:49 PM
07/16/15 10:49 PM
tex013
Sydney,Australia
DusterW2 , I see what you mean . a little awkward . Just talked to Brad @ PPP , will see what pricing and shipping is . He suggested a push pattern to help with the trigger , made sense . Anyone try this ?
Tex
[Re: tex013]
#1872110
07/17/15 01:33 AM
07/17/15 01:33 AM
Posts: 491 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
Dixie shifter..anyone ever use one of these? they are very nice besides the handle.its electric and can shift each gear at different rpm when running a three speed.had mine 20 years never missed a shift..
[Re: tex013]
#1872502
07/17/15 07:55 PM
07/17/15 07:55 PM
Posts: 17,904 Akron, Ohio
ProSport
Akron, Ohio
I LOVE my $200 B&M ProRatchet, first thing I do is sell the 5' cable and buy a 4' cable and a 3' section of heat sleeve, no problems on a big block A-body and it's impossible to miss a shift like you can easily do on the Cheetah and Winters type shifters.
I'd like a PPP shifter just for the rear cable exit but can't justify the price for my street cruiser.
Sassy Grass street Duster, best of 10.69 at 124 driven to the track with 3.23 gears, naturally aspirated on 93 octane.
[Re: DusterW2]
#1872514
07/17/15 08:17 PM
07/17/15 08:17 PM
Posts: 1,597 fresno ca
mikeysmopars
fresno ca
The Cheetah cable exits the front of the shifter and loops around on the passenger side of the trans and back under the tail housing and attaches to the trans lever from the rear. It is not a ratchet shifter. It is gated and I have shifted 1-3 several times until I focused on what I was doing. Now, it shifts great and smooth. They have forward and reverse gates. www.turboaction.com  Exactly what he said. Good shifter for the money but the standard plate for the reverse shifter can make you shoot streight to high gear. I guess they make a dummy proof plate for that but that would be too easy  My next shifter will be a PPP
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: vc360]
#1872515
07/17/15 08:17 PM
07/17/15 08:17 PM
tex013
Sydney,Australia
VC360 , will you be at Mopar Sunday ? if so I will have a look at your setup . the only worry I have with a PPP is room as I use a bench seat - have not seen 1 with this and not sure of how much room it needs
Tex
[Re: tex013]
#1872577
07/17/15 10:16 PM
07/17/15 10:16 PM
Posts: 426 Cairns Queensland Australia. T...
vc360
Tex, sorry I won't be there this year. Looks tight with the bench but they are compact. I will measure the length and width of the bracket and let you know. Shifter is 240mm overall where the top bolts are. 190mm at the bottom. Overall height of the shifter without bracket is 250mm to top of handle with bracket is 310mm. The cable extends out around 200mm before it bends 180degrees. You could make extended height brackets for it easy enough.
[Re: tex013]
#1872699
07/18/15 01:35 AM
07/18/15 01:35 AM
tex013
Sydney,Australia
thanks VC360, that's great . how high off floor is the cable? shame you will miss the day but oh well it happens I do like how Willowbank is good to 10.50 for me woohoo
Tex
[Re: tex013]
#1872752
07/18/15 04:55 AM
07/18/15 04:55 AM
tex013
Sydney,Australia
Thanks again VC360 I hear you on travel ,closer for me but still best part of 11 hrs drive . Yes there is a t&t the night before , plan on running it with a couple of mates Hope all issues are done - broke t bar last month , front band strut yesterday , now dealing with shifter adjustment . Feel like i must have killed a chinaman .
Tex
[Re: tex013]
#1872762
07/18/15 07:07 AM
07/18/15 07:07 AM
Posts: 4,536 aotearoa
rebel
aotearoa
like some others i've experianced 1-3rd shifts with my TA shifter, but it was my fault being too over excited in the heat of racing. i got over that when i did some training. now that i run a clean Neutral brake the shifter is almost imposible to stuff up. oh & before someone thinks there's something wrong with my set up, my Dart is Right Hand Drive & thats a trans line pressure guage youre looking at.
