Re: Ignition help asap!!!!
[Re: dangina]
#1866780
07/08/15 06:13 PM
07/08/15 06:13 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
My money is on another ballast resistor issue.
[Re: dangina]
#1867050
07/09/15 02:11 AM
07/09/15 02:11 AM
RapidRobert
No, if the ballast has continuity You will have some voltage at either end of the ballast wheather the current is entering from the upstream (ign1 blue wire "run" end or the downstream (ign2/brown wire/"cranking" end. If open (ballast) it'll wanna start but die when you let off the key. What is going on/more info please
[Re: dangina]
#1867304
07/09/15 05:44 PM
07/09/15 05:44 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
Sorry guys, I pulled the tape off the harness under the dash, tested the ignition switch, which is good. I found the problem, the new m&h harnesses has a pigtail for charger hideaway headlights (2 blue wires with white stripe) they told me to cut it as I didnt need it and tape it up. Well wouldn't you know its the same wire from the ignition switch, cutting that wire cut the circuit. Car starts!!!! New problem. Its the mopar orange box, all brand new wiring Car doesnt shut off when the key turns off. any thoughts?
[Re: dangina]
#1867435
07/09/15 10:48 PM
07/09/15 10:48 PM
dangina
I deleted the ammeter, the black has its own 12v, and the red wire is now used as a trigger for the solenoid for the starter, and the starter relay has its own 12v. The entire car has new m&h harnesses.
[Re: dangina]
#1867462
07/09/15 11:38 PM
07/09/15 11:38 PM
dangina
No key, blue 10.5v, brown 5v, coil+ 5v, with blue disconnected, 0v on brown and at the coil +,
Key in ign one position and blue disconnected, 5v on brown at ballast and starter
Blue always has power. Would that be ignition switch?
[Re: stumpy]
#1867468
07/09/15 11:46 PM
07/09/15 11:46 PM
RapidRobert
With the key off you should have no power to either the blue or brown wires from the ignition switch. What Stump said: Only the ign1 blue wire (run) wire should be powering the coil (to/thru the ballast to the coil) and T ing over to the ECU power wire (blue/yellow) with the ign key "on". when you turn the key off this blue wire circuit goes dead & so does the coil/ECU & it (the eng) shuts off. Sumpin ain't wired right still. EDIT to clarify, weather you are on blue (run) or brown (crank) the one system you are on is going to back feed to the other (blue to brown or brown to blue) all the way back to the ign switch but when the key is off both ign1 and ign2 terminals at the ign SWITCH are dead
[Re: dangina]
#1867480
07/09/15 11:56 PM
07/09/15 11:56 PM
RapidRobert
I thought blue and brown get power from the ignition switch? yes they do (blue ign1 run/brown ign2 crank)
