Ignition help asap!!!! #1866767
07/08/15 06:00 PM
07/08/15 06:00 PM
Lethbridge, AB, Canada
dangina Offline OP
dangina  Offline OP
Just starting my 71 runner to get ready for the big show this weekend and I'm having a problem. For the ignition switch I have 12v on the blue wire on ignition one, zero on brown. On ignition two when I turn the key I have zero on blue and 12v on brown. Is this correct?
Re: Ignition help asap!!!! [Re: dangina] #1866776
07/08/15 06:06 PM
07/08/15 06:06 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sounds right. What is the problem you are having?
Re: Ignition help asap!!!! [Re: dangina] #1866778
07/08/15 06:11 PM
07/08/15 06:11 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Yes, that is correct. The blue wire is your power wire to the coil in the "run" position. The brown wire sends power to the coil in the "start/crank" position and bypasses the ballast. This gives you full power to the coil for start-up.
Re: Ignition help asap!!!! [Re: dangina] #1866780
07/08/15 06:13 PM
07/08/15 06:13 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
My money is on another ballast resistor issue.
- Stu Harmon
Re: Ignition help asap!!!! [Re: dangina] #1866810
07/08/15 07:11 PM
07/08/15 07:11 PM
New Jersey, US of A
PlumCrazy73Dodge Offline
New Jersey, US of A
feets has my vote too
73 plumcrazy challenger - 318/904, edelbrock performer 600cfm carb, performer intake and cam. Eddy Alum. Heads 3.91 locker, Doug's headers, accurate ltd. exhaust
73 Cuda - Triple Black 340 4 speed
MIKE
Re: Ignition help asap!!!! [Re: dangina] #1866836
07/08/15 07:56 PM
07/08/15 07:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
OP hasn't explained the problem if there is one.
Re: Ignition help asap!!!! [Re: dangina] #1867050
07/09/15 02:11 AM
07/09/15 02:11 AM
Is this correct?
No, if the ballast has continuity You will have some voltage at either end of the ballast wheather the current is entering from the upstream (ign1 blue wire "run" end or the downstream (ign2/brown wire/"cranking" end. If open (ballast) it'll wanna start but die when you let off the key. What is going on/more info please
Re: Ignition help asap!!!! [Re: dangina] #1867304
07/09/15 05:44 PM
07/09/15 05:44 PM
dangina Offline OP
dangina  Offline OP
Sorry guys, I pulled the tape off the harness under the dash, tested the ignition switch, which is good. I found the problem, the new m&h harnesses has a pigtail for charger hideaway headlights (2 blue wires with white stripe) they told me to cut it as I didnt need it and tape it up. Well wouldn't you know its the same wire from the ignition switch, cutting that wire cut the circuit.
Car starts!!!!
New problem.
Its the mopar orange box, all brand new wiring
Car doesnt shut off when the key turns off. frown any thoughts?
Re: Ignition help asap!!!! [Re: dangina] #1867344
07/09/15 07:19 PM
07/09/15 07:19 PM
dangina Offline OP
dangina  Offline OP
Bump! What should I see on blue/ brown wires? I have to kill the battery disconnect to turn motor off
Re: Ignition help asap!!!! [Re: dangina] #1867349
07/09/15 07:37 PM
07/09/15 07:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I would disconnect the blue wire with the white stripe and start fresh. Brown wire in start position should be full battery voltage. Blue wire in run should be lower about 9v. Make sure the power at the coil is in these areas. If not then check the ballast resistor. Where is the M&H wiring harness installed? Under dash or under hood? Ignition switch gets it's power from the amp gauge out wire.
Re: Ignition help asap!!!! [Re: dangina] #1867435
07/09/15 10:48 PM
07/09/15 10:48 PM
dangina Offline OP
dangina  Offline OP
I deleted the ammeter, the black has its own 12v, and the red wire is now used as a trigger for the solenoid for the starter, and the starter relay has its own 12v. The entire car has new m&h harnesses.
Re: Ignition help asap!!!! [Re: dangina] #1867448
07/09/15 11:19 PM
07/09/15 11:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Back to basics. How much voltage do you have at the coil + in start and run ignition positions with the blue with a white stripe wire disconnected? With the key off you should have no power to either the blue or brown wires from the ignition switch.
Re: Ignition help asap!!!! [Re: dangina] #1867462
07/09/15 11:38 PM
07/09/15 11:38 PM
dangina Offline OP
dangina  Offline OP
No key, blue 10.5v, brown 5v, coil+ 5v,
with blue disconnected, 0v on brown and at the coil +,
Key in ign one position and blue disconnected, 5v on brown at ballast and starter
Blue always has power. Would that be ignition switch?
Re: Ignition help asap!!!! [Re: stumpy] #1867468
07/09/15 11:46 PM
07/09/15 11:46 PM
What Stump said: Only the ign1 blue wire (run) wire should be powering the coil (to/thru the ballast to the coil) and T ing over to the ECU power wire (blue/yellow) with the ign key "on". when you turn the key off this blue wire circuit goes dead & so does the coil/ECU & it (the eng) shuts off. Sumpin ain't wired right still. EDIT to clarify, weather you are on blue (run) or brown (crank) the one system you are on is going to back feed to the other (blue to brown or brown to blue) all the way back to the ign switch but when the key is off both ign1 and ign2 terminals at the ign SWITCH are dead
Re: Ignition help asap!!!! [Re: dangina] #1867469
07/09/15 11:47 PM
07/09/15 11:47 PM
dangina Offline OP
dangina  Offline OP
Add to the confusion, I pulled the ignition switch off, put my tester on the harness from the bulkhead to the ignition switch I have 10.5v on blue, 5 on brown and 12v on battery.
Re: Ignition help asap!!!! [Re: dangina] #1867474
07/09/15 11:50 PM
07/09/15 11:50 PM
dangina Offline OP
dangina  Offline OP
I thought blue and brown get power from the ignition switch? ?! I gotta strip more harness tape. I bought a $400 ****ing harness to avoid this bs
Re: Ignition help asap!!!! [Re: dangina] #1867480
07/09/15 11:56 PM
07/09/15 11:56 PM
yes they do (blue ign1 run/brown ign2 crank)
Re: Ignition help asap!!!! [Re: dangina] #1867490
07/10/15 12:06 AM
07/10/15 12:06 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Some how you are bypassing the ignition switch.
Re: Ignition help asap!!!! [Re: dangina] #1867502
07/10/15 12:15 AM
07/10/15 12:15 AM
dangina Offline OP
dangina  Offline OP
Ya!!! Problem solved I have a aftermarket toyota denso alternator. The problem is this thing. What is the proper way of hooking this alternator up?
Re: Ignition help asap!!!! [Re: dangina] #1867504
07/10/15 12:16 AM
07/10/15 12:16 AM
dangina Offline OP
dangina  Offline OP
Big wire goes to starter relay. What do the red, green, blue wires for the plugin harness go to?
