71-74b body guys. weird question......
#1862337
07/02/15 09:19 PM
07/02/15 09:19 PM
Posts: 8,848 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
I was looking for the brace that goes behind the mirior on our 71 charger. It came with duel chrome racing miriors It lines up perfict with driver door and thought only one door had a brace so walk to other side......hmmmmm not even close Feel the back side of door skin. No brace. And no other holes ever drilled... Get the mirior. It and the holes on passenger side have a 5 inch spacing. Driver side is 3 inch....what the heck??? These are the orignal miriors and doors to the car Also the skin on passenger side is all holds the mirror on And is a smaller holes then then the driver side wich has a plate..... are all 71 b bodys like this? A mid year change?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: 71-74b body guys. weird question......
[Re: toplescuda]
#1862364
07/02/15 09:47 PM
07/02/15 09:47 PM
Posts: 4,922 new berlin wisconsin
Mr T2U
your drivers mirror is original. your right side mirror isn't original equipment. it's from maybe from a 72 or defiantly a 73-74 mirror, I forget the year when they changed. the later mirrors look the same but the mount holes are spaced wider apart.
perception is 90% of reality
[Re: toplescuda]
#1862365
07/02/15 09:48 PM
07/02/15 09:48 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Here is the car before painted Yes passenger side is non remote
[Re: 440trk]
#1864125
07/05/15 03:44 AM
07/05/15 03:44 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
71 and 72 mirrors use the smaller 3"ish mounting. 73 and 74 Mirrors use the longer 5"ish mounting.
Both sides/both styles used a mounting plate inside the door to mount the mirrors to.
Sounds like your passenger mirror is a 73/4 and you are missing the mounting plate for the pass. side.
Correct
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: 440trk]
#1864322
07/05/15 03:07 PM
07/05/15 03:07 PM
Posts: 441 SF Bay Area, CA
charger440sixpak
SF Bay Area, CA
My SPD 201 Charger R/T has factory well nuts on the left(drivers) door to mount the side mirror. The original mirror was a non-racing style which are not as heavy as the racing mirrors. This made me wonder if the backing plates were used for extra support for the heavier racing side mirrors? But I've never run across any indication of that in print anywhere.
[Re: gregn96cuda]
#1870564
07/15/15 12:49 AM
07/15/15 12:49 AM
Posts: 406 California City, CA
dart440
California City, CA
Were the passenger door and mirror replaced with 73-4 parts? That is the later big spacing on the mirror.
When you work on Spaceships for a living, how bad can a workday be?
[Re: toplescuda]
#1871016
07/15/15 06:35 PM
07/15/15 06:35 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
No. Original paint both doors. The passenger side does/did not have brace behind the skin. Only thing I can think of is someone back in the day decided to add a passenger mirrior
[Re: toplescuda]
#1877858
07/25/15 02:20 PM
07/25/15 02:20 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
You didn't ask, but Soff Seal had gaskets if you need them. CH2031R was the pass side. The holes may be off due to the screw hole mounting location between the years so be aware of that.
Common sense is a flower that does not grow in everybody's garden
