727 Front Clutch ? #1866955
07/08/15 10:59 PM
07/08/15 10:59 PM
New England
Tech Instructor Offline OP
New England
Resealing a 727 68 vintage.Front cutch inner seal on trans is much smaller lip than one supplied with kit.Kit is Transtar kit 62 70.Has the drum been replaced with a different one perhaps? I have never ran into this before.The warehouse gave me another kit same seal in this kit as well.Any thoughts?
Re: 727 Front Clutch ? [Re: Tech Instructor] #1866981
07/08/15 11:57 PM
07/08/15 11:57 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
1970 and earlier kits used a front clutch seal with a larger lip. 1971 and up use a seal with a shorter lip.
Re: 727 Front Clutch ? [Re: Tech Instructor] #1867241
07/09/15 03:29 PM
07/09/15 03:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
How wide is the bushing in the drum?
The '71 and later drum has a wide bushing (3/4") and uses the narrow-lip seal. '70 and earlier drum has a narrow bushing (1/2") and uses the wide-lip seal.
If your drum has the narrow bushing and a narrow-lip seal, somebody installed the wrong seal. The later drum will accept only the narrow seal but the early drum will accept either one. The narrow seal in the early drum will work but it's not ideal.
Re: 727 Front Clutch ? [Re: John_Kunkel] #1867433
07/09/15 10:39 PM
07/09/15 10:39 PM
New England
New England
Thanks for the help it has the later drum.
Re: 727 Front Clutch ? [Re: Tech Instructor] #1867752
07/10/15 02:57 PM
07/10/15 02:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
What's the number of the '62-'70 Transtar kit you have? The K22950E-4 supplement kit hasn't been available around here for a while.
Re: 727 Front Clutch ? [Re: John_Kunkel] #1867996
07/10/15 11:26 PM
07/10/15 11:26 PM
New England
New England
I will check the kit number.
Re: 727 Front Clutch ? [Re: John_Kunkel] #1868025
07/11/15 12:31 AM
07/11/15 12:31 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
John, thanks for continuing to post with your knowledge on the TF's up beer
