2008 Ram: A./C clutch coil and blend door questions? #1865521
07/06/15 11:28 PM
07/06/15 11:28 PM
Houston, Texas
Slant6pak Offline OP
Houston, Texas
Hey guys,
Got a question about my 2008 Ram. The A/C has been out for the last two years (in Texas) and I've been to lazy to do anything about because I work 5 minutes from home.
Well that is about to change and I'm working on repairing it.
I'm traced my lack of A/C to the A/C clutch coil, its toast and I've found info on the web that this is a common problem and that is easy to repair ($40 and a hour so they say), but I can't find a part number or source for the part or instructions on how to change it. Can somebody point me in the right direction?
Also, I have infamous broken blend door in my A/C box, I found a website (HeaterTreater) that sells a repair kit. Has anybody used it?
2016 Challenger Scat Pack Shaker smile
1000 ci Brass Era Speedster project
Re: 2008 Ram: A./C clutch coil and blend door questions? [Re: Slant6pak] #1865770
07/07/15 11:33 AM
07/07/15 11:33 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Mopar # would be 5003681AA If you can get it done for $40 and a hour labor go for it,sounds a little too cheap? Are you sure it's the blend air door and not the recir door?
Re: 2008 Ram: A./C clutch coil and blend door questions? [Re: Slant6pak] #1865773
07/07/15 11:34 AM
07/07/15 11:34 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
I replaced the recirc. door and a/c clutch on my '06 earlier this year. Check youtube for info on the clutch (I'm sure there is plenty there)- I'm a retired mechanic so I knew how to do it already. wink As for the recirc. door, I ordered one from RockAuto. It's so easy to replace I didn't see the need to pay HeaterTreaters price. shocked
Edit: Missed where you said blend door. Sorry.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 2008 Ram: A./C clutch coil and blend door questions? [Re: Slant6pak] #1866330
07/08/15 01:54 AM
07/08/15 01:54 AM
Houston, Texas
Houston, Texas
Any other source for the coil besides the dealer?
Some of the info I read mentioned ebay... but they don't cross reference part numbers so well.
How the heck do you change it? I imagine the clutch has to come off...
As far as the broken door in the dash goes, I'm not sure which one is broken, maybe all this point.
When the A/C was still working, it blew fire out of the driver's side vents and ice cubes out the passenger side. I was thinking going with the Heater Treater kit because it replaces the flimsy plastic doors and you don't have to tear the whole dash apart.
Re: 2008 Ram: A./C clutch coil and blend door questions? [Re: Slant6pak] #1866609
07/08/15 03:01 PM
07/08/15 03:01 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Do an online search for "how to replace an AC clutch for a ..." I think you will have no trouble finding an instructional video.
Re: 2008 Ram: A./C clutch coil and blend door questions? [Re: stumpy] #1867162
07/09/15 12:54 PM
07/09/15 12:54 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
BTW you have tried to rotate the compressor to make sure it hasn't seized?
The inter part or maybe just put a 13mm(maybe 10mm) socket on the center nut and rotate it. You should spin with a little drag.
Re: 2008 Ram: A./C clutch coil and blend door questions? [Re: Slant6pak] #1867376
07/09/15 08:35 PM
07/09/15 08:35 PM
ky.
K
kenworth_goose Offline
K
ky.
I'd bet all the door inside the heater box are broken. Very common problem.
Re: 2008 Ram: A./C clutch coil and blend door questions? [Re: Slant6pak] #1868160
07/11/15 11:09 AM
07/11/15 11:09 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: 2008 Ram: A./C clutch coil and blend door questions? [Re: Slant6pak] #1868297
07/11/15 04:54 PM
07/11/15 04:54 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
I'm doing this exact thing now. I have voltage going to the compressor. I can not spin the compressor at all. My blend door will be next. I wish those pics worked on the above link for plugs.
BTW, it is an 8mm center nut. Mine will loosen, but will not spin the compressor in the tightening direction.
I think a whole compressor is in my unfortunate future.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: 2008 Ram: A./C clutch coil and blend door questions? [Re: Slant6pak] #1868316
07/11/15 05:25 PM
07/11/15 05:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sunroof I do believe you have it right. Compressor is locked up. wrench
