What do you carry for emergency flat tire repair
#1865543
07/07/15 12:00 AM
07/07/15 12:00 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Have 70 Challenger with 275/60's on rear and 235/60's on front, 15 inch Have no spare tire and if did likely would not be the right size if needed. Considering carrying some type of temporary fix a flat system such as this product in the event have a need. Do have a AAA card but likely not find a proper replacement tire to match what I need in an emergency. Such as on the way to an event and need a few hours to get there and back home. Looking at products such as this, or products that one can "plug" a hole externally and then inflate by a cigar lighter pump. http://www.amazon.com/gp/product/B001DZF..._dp_o_pC_nS_ttlWhat do you carry?
Re: What do you carry for emergency flat tire repair
[Re: Sxrxrnr]
#1865553
07/07/15 12:05 AM
07/07/15 12:05 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
I carry a spare tire and jack. I sure am not going to sit along side the road and try to repair one.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: MoparforLife]
#1865583
07/07/15 12:33 AM
07/07/15 12:33 AM
Posts: 7,664 IN
ahy
IN
I carry a spare tire and jack. I sure am not going to sit along side the road and try to repair one. Me too. In your situation, suggest you look for a 70 or even 75 series tire with diameter about equal to the rear tire and will also fit the front for a spare. Any 7" or 8" steel wheel that fits should do fine for the spare... coat of black paint if needed for the wheel. My front and rear diameter is about the same... so a spare spec'ed for the front works for the rear. I have driven cross continent and never needed the spare... but glad I had it just in case for the long desert crossings.
[Re: Sxrxrnr]
#1865616
07/07/15 01:31 AM
07/07/15 01:31 AM
Posts: 22,719 Bitopia
jcc
Bitopia
I have not carried a spare in over 40+ years. I think it boils down to the advantages of not having an extra 40? pounds of dead weight and losing the extra space, and no $ investment vs your confidence you can deal with whatever pops up. After 2 million+ miles, I'm still confident, and still playing the odds. PS, the above strategy does not apply to everyone, like daughters, wives, etc, not wanting to be chauvinistic.
[Re: E-Ticket]
#1865686
07/07/15 05:51 AM
07/07/15 05:51 AM
Posts: 1,805 ky hills
thehemikid
ky hills
A bumper jack, A scissor jack, & a 255 spare that'll go anywhere.
If I had smaller front tires I'd carry a spare for the rear for the sure grip, and some fix-a-flat & some plugs for the fronts.
A cell ph & AAA would be back up.
[Re: ademon]
#1866055
07/07/15 08:25 PM
07/07/15 08:25 PM
Posts: 7,664 IN
ahy
IN
Will the sure grip burn out driving with uneven sized tires ? A sure grip would not like different tire sizes. A few 10's of an inch may be OK but not too much... that's why it important to match rear diameter pretty close. Also, on the spare question... I always have and have recently used a full size spare for my DD Durango. Piece of metal on the road kicked up by the front tire and perfectly positioned to poke a 1/2" hole in the nice Michelin rear. Glad I could change the tire and continue my road trip. My wife somehow picked up a 3/8" x 7/16" combination wrench in her rear tire on the way to the gym. In through the tread and poking out the sidewall. I keep it as a souvenir. I was glad to get her back on the road with a quick tire change. My older daughter carries a full size and my younger daughter carries a full size + donut. Both have used theirs more than once. On the Neon they both drove at different times they have managed to take out several wheels as well as tires... and get home with no assistance with a quick tire change. All that is why I like to have a spare!
[Re: Sxrxrnr]
#1866116
07/07/15 09:37 PM
07/07/15 09:37 PM
Posts: 15,934 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I know nothing beats carrying a spare and jack, but I also hate carrying that extra weight. Yeah, I know, it's not all that much but I still don't like it, along with the room it takes. So I carry a plug kit, pair of pliers to pull out a nail or whatever, a razor, and a bicycle tire pump. It takes a bit but I've pumped up car tires with bicycle pump.
I have a full size spare in garage and would throw it in trunk if taking a trip.
Facts are stubborn things.
[Re: Sxrxrnr]
#1866127
07/07/15 09:43 PM
07/07/15 09:43 PM
Sxrxrnr
Northern Calyfornua
http://smile.amazon.com/Slime-70004-Powe...13C39E6TDV9Q8D8Ordered up this kit as does include plugging option in addition to slime chemical and what appears a fairly decent compressor. Will give some feeling of security until decide on a real spare tire. Can also be moved from car to car as emergency back up for other vehicles. For plugs only, the kit below has many fans. However no compressor, you must buy one separate. Plan would be to have AAA come to your rescue, raise car from ground, plug tire, use their air to reinflate tire. This repair sounds quite durable according to reviewers. http://smile.amazon.com/Slime-70004-Powe...13C39E6TDV9Q8D8At least would not look dopey having car at Goodguy event with a mini spare as your 4th wheel. What happens to a Dana 60 if you run a 235/60/15 on one rear axle and a 275/60 on the other, am considering a 235 as a spare,,,cannot use any larger as front end will not allow. Also still considering other recommendations picked up here.
[Re: Sxrxrnr]
#1866407
07/08/15 08:54 AM
07/08/15 08:54 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
[Re: Sxrxrnr]
#1866408
07/08/15 08:55 AM
07/08/15 08:55 AM
Posts: 8,162 USA
360view
USA
[Re: Sxrxrnr]
#1866462
07/08/15 11:25 AM
07/08/15 11:25 AM
Posts: 2,112 New Jersey, US of A
PlumCrazy73Dodge
New Jersey, US of A
Plug kit with the CO2 cartridges eliminates the need for the compressor. With that you can fix any nail/screw flat. Good tires rarely fail, although I have a spare in everything. Just make sure u have a small jack and LUG wrench to remove said tire and work on it safely off the road.
73 plumcrazy challenger - 318/904, edelbrock performer 600cfm carb, performer intake and cam. Eddy Alum. Heads 3.91 locker, Doug's headers, accurate ltd. exhaust 73 Cuda - Triple Black 340 4 speed MIKE
