What do you carry for emergency flat tire repair #1865543
07/07/15 12:00 AM
07/07/15 12:00 AM
Northern Calyfornua
Sxrxrnr Offline OP
Sxrxrnr  Offline OP
Northern Calyfornua
Have 70 Challenger with 275/60's on rear and 235/60's on front, 15 inch
Have no spare tire and if did likely would not be the right size if needed.
Considering carrying some type of temporary fix a flat system such as this product in the event have a need. Do have a AAA card but likely not find a proper replacement tire to match what I need in an emergency. Such as on the way to an event and need a few hours to get there and back home.
Looking at products such as this, or products that one can "plug" a hole externally and then inflate by a cigar lighter pump.
http://www.amazon.com/gp/product/B001DZF..._dp_o_pC_nS_ttl
What do you carry?
Re: What do you carry for emergency flat tire repair [Re: Sxrxrnr] #1865553
07/07/15 12:05 AM
07/07/15 12:05 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
I carry a spare tire and jack. I sure am not going to sit along side the road and try to repair one.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: What do you carry for emergency flat tire repair [Re: Sxrxrnr] #1865562
07/07/15 12:10 AM
07/07/15 12:10 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
For some things, you need a spare.
Re: What do you carry for emergency flat tire repair [Re: MoparforLife] #1865583
07/07/15 12:33 AM
07/07/15 12:33 AM
IN
ahy Offline
ahy  Offline
IN
Me too. In your situation, suggest you look for a 70 or even 75 series tire with diameter about equal to the rear tire and will also fit the front for a spare. Any 7" or 8" steel wheel that fits should do fine for the spare... coat of black paint if needed for the wheel.
My front and rear diameter is about the same... so a spare spec'ed for the front works for the rear. I have driven cross continent and never needed the spare... but glad I had it just in case for the long desert crossings.
Re: What do you carry for emergency flat tire repair [Re: Sxrxrnr] #1865616
07/07/15 01:31 AM
07/07/15 01:31 AM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
I have not carried a spare in over 40+ years. I think it boils down to the advantages of not having an extra 40? pounds of dead weight and losing the extra space, and no $ investment vs your confidence you can deal with whatever pops up. After 2 million+ miles, I'm still confident, and still playing the odds. grin
PS, the above strategy does not apply to everyone, like daughters, wives, etc, not wanting to be chauvinistic.
Re: What do you carry for emergency flat tire repair [Re: Sxrxrnr] #1865624
07/07/15 01:56 AM
07/07/15 01:56 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
AAA card...(although I do have a spare in both daily drivers - had to use the one in the Durango last Friday). I have carried a spare in the GTS as all tires have been the same size, but since tires were different size on my son's Dart I thought it useless to have one.
Re: What do you carry for emergency flat tire repair [Re: Sxrxrnr] #1865657
07/07/15 03:17 AM
07/07/15 03:17 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Will the sure grip burn out driving with uneven sized tires ?
Re: What do you carry for emergency flat tire repair [Re: ademon] #1865669
07/07/15 03:45 AM
07/07/15 03:45 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Yes a AAA card! And a properly inflated spare in case I must to get out of a jam.
Re: What do you carry for emergency flat tire repair [Re: Sxrxrnr] #1865678
07/07/15 04:44 AM
07/07/15 04:44 AM
Louisville, KY
E
E-Ticket Offline
E-Ticket  Offline
E
Louisville, KY
AAA, 9mm, bottle jack and ratchet wrench and sockets.
"Fat drunk and stupid is no way to go through life son......"
http://www.youtube.com/watch?v=bK-Dqj4fHmM
Re: What do you carry for emergency flat tire repair [Re: E-Ticket] #1865686
07/07/15 05:51 AM
07/07/15 05:51 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
A bumper jack, A scissor jack, & a 255 spare that'll go anywhere.
If I had smaller front tires I'd carry a spare for the rear for the sure grip, and some fix-a-flat & some plugs for the fronts.
A cell ph & AAA would be back up.
Re: What do you carry for emergency flat tire repair [Re: ademon] #1866055
07/07/15 08:25 PM
07/07/15 08:25 PM
IN
ahy Offline
ahy  Offline
IN
A sure grip would not like different tire sizes. A few 10's of an inch may be OK but not too much... that's why it important to match rear diameter pretty close.
Also, on the spare question... I always have and have recently used a full size spare for my DD Durango. Piece of metal on the road kicked up by the front tire and perfectly positioned to poke a 1/2" hole in the nice Michelin rear. Glad I could change the tire and continue my road trip. My wife somehow picked up a 3/8" x 7/16" combination wrench in her rear tire on the way to the gym. In through the tread and poking out the sidewall. I keep it as a souvenir. I was glad to get her back on the road with a quick tire change. My older daughter carries a full size and my younger daughter carries a full size + donut. Both have used theirs more than once. On the Neon they both drove at different times they have managed to take out several wheels as well as tires... and get home with no assistance with a quick tire change. All that is why I like to have a spare!
Re: What do you carry for emergency flat tire repair [Re: Sxrxrnr] #1866084
07/07/15 09:00 PM
07/07/15 09:00 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you want to plop 200 bucks down on a spare, mickey thompson sells a 5" wide 28" diameter tire.
Re: What do you carry for emergency flat tire repair [Re: Sxrxrnr] #1866116
07/07/15 09:37 PM
07/07/15 09:37 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I know nothing beats carrying a spare and jack, but I also hate carrying that extra weight. Yeah, I know, it's not all that much but I still don't like it, along with the room it takes. So I carry a plug kit, pair of pliers to pull out a nail or whatever, a razor, and a bicycle tire pump. It takes a bit but I've pumped up car tires with bicycle pump.
I have a full size spare in garage and would throw it in trunk if taking a trip.
Facts are stubborn things.
Re: What do you carry for emergency flat tire repair [Re: Sxrxrnr] #1866127
07/07/15 09:43 PM
07/07/15 09:43 PM
Northern Calyfornua
Sxrxrnr Offline OP
Sxrxrnr  Offline OP
Northern Calyfornua
http://smile.amazon.com/Slime-70004-Powe...13C39E6TDV9Q8D8
Ordered up this kit as does include plugging option in addition to slime chemical and what appears a fairly decent compressor. Will give some feeling of security until decide on a real spare tire. Can also be moved from car to car as emergency back up for other vehicles.
For plugs only, the kit below has many fans. However no compressor, you must buy one separate.
Plan would be to have AAA come to your rescue, raise car from ground, plug tire, use their air to reinflate tire. This repair sounds quite durable according to reviewers.
At least would not look dopey having car at Goodguy event with a mini spare as your 4th wheel.
What happens to a Dana 60 if you run a 235/60/15 on one rear axle and a 275/60 on the other, am considering a 235 as a spare,,,cannot use any larger as front end will not allow. Also still considering other recommendations picked up here.
Re: What do you carry for emergency flat tire repair [Re: Sxrxrnr] #1866170
07/07/15 10:19 PM
07/07/15 10:19 PM
Springfield, MO
Steve88 Offline
Steve88  Offline
Springfield, MO
I have a 15x3.5 Weld Draglite with a 28x7.50 front runner that I use as a spare. It's kinda tall on the front but will work in a pinch. The wheel is dual bolt pattern so it works on my GM muscle cars as well as my Mopar. It's light and doesn't take up much room.
Re: What do you carry for emergency flat tire repair [Re: Sxrxrnr] #1866407
07/08/15 08:54 AM
07/08/15 08:54 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Re: What do you carry for emergency flat tire repair [Re: Sxrxrnr] #1866408
07/08/15 08:55 AM
07/08/15 08:55 AM
USA
3
360view Offline
360view  Offline
3
USA
Re: What do you carry for emergency flat tire repair [Re: Sxrxrnr] #1866410
07/08/15 09:03 AM
07/08/15 09:03 AM
USA
3
360view Offline
360view  Offline
3
USA
There is another screw in plug that i cannot locate right now.
It looks like a black plastic tapered phillips head screw that you slather with sealant bonder and screw into the hole.
Your goal in these repairs is only a temporary repair that will allow you to drive modestly to a good tire repair shop where the tire will be dismounted, inspected and patched from the inside. Good tire repair shops also have a Hunter Computer Balance Center that applies a 800 lb road force load.
Re: What do you carry for emergency flat tire repair [Re: Sxrxrnr] #1866462
07/08/15 11:25 AM
07/08/15 11:25 AM
New Jersey, US of A
PlumCrazy73Dodge Offline
New Jersey, US of A
Plug kit with the CO2 cartridges eliminates the need for the compressor. With that you can fix any nail/screw flat. Good tires rarely fail, although I have a spare in everything. Just make sure u have a small jack and LUG wrench to remove said tire and work on it safely off the road.
73 plumcrazy challenger - 318/904, edelbrock performer 600cfm carb, performer intake and cam. Eddy Alum. Heads 3.91 locker, Doug's headers, accurate ltd. exhaust
73 Cuda - Triple Black 340 4 speed
MIKE
Re: What do you carry for emergency flat tire repair [Re: PlumCrazy73Dodge] #1866556
07/08/15 01:42 PM
07/08/15 01:42 PM
Northern Calyfornua
Sxrxrnr Offline OP
Sxrxrnr  Offline OP
Northern Calyfornua
Good point on jack and lug wrench. Don't need to try doing a plug with the tire on the ground. I have neither in the car.
Any thoughts on the best compact portable chassis jack that one might use on uncertain surfaces? Perhaps carry piece of heavy duty plywood or some such to sit it on. Certainly no bumper jacks allowed, bottle jacks a bit problematic.
