Trans blanket ? #186256
01/06/09 10:53 PM
01/06/09 10:53 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
In light of Chip's tranny massacre I have been thinking about my own feet.What is the best protection for an auto to limit the potential damage from such an explosion?
The TCI streetfighter trans has been a trooper but it does have some miles and I am collecting parts for another build that should be in the 600+ hp range.
What are you guys using on a street car??
Re: Trans blanket ? [Re: gch] #186257
01/06/09 10:59 PM
01/06/09 10:59 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Just from my experience,I would get a CSR sheild.They suck to install in a stock bodied car,but the few I have run blankets on retained too much heat.
Just my
Re: Trans blanket ? [Re: Dunnuck Racing] #186258
01/06/09 11:10 PM
01/06/09 11:10 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Does the CSR shield allow the trans to cool that much better?
I'm running an RCI blanket on mine - on the street, and I am certainly making some heat with the 4,000 stall convertor and 4,000+ lbs.
Re: Trans blanket ? [Re: Duner] #186259
01/06/09 11:18 PM
01/06/09 11:18 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
I don't know that it does unless it conducts the heat better. I can take pics of mine (CSR) if you like, the trans is out of the car right now (I pulled it with the motor).
Re: Trans blanket ? [Re: Kevins493] #186260
01/06/09 11:25 PM
01/06/09 11:25 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
That would be great if I could just see a couple of pics of it. I'm not sure they make one for my trans. I don't know enough about the different cases to know if a 727 shield would fit my 46RE trans.
Re: Trans blanket ? [Re: Duner] #186261
01/06/09 11:25 PM
01/06/09 11:25 PM
Northern Indiana
Northern Indiana
I have 2 bracket cars.On one ,I installed a blanket as soon as it was fast enough to need one,and the temps went way up.And this thing gets cooled between rounds.The second one got the CSR sheild once it was fast enough,without a noticable increase in temps.Both of them have front mounted coolers,and I have had the same convertor in both cars at one time or another.
So really the only difference I can see is the blanket for retaining heat,I can only imagine what it would do on the street.
Re: Trans blanket ? [Re: Duner] #186262
01/06/09 11:34 PM
01/06/09 11:34 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
It was real hard to get a decent pic givin the tranny's location (and its a little chilly in the garage. ) but here's some really bad pics of it.
Re: Trans blanket ? [Re: Kevins493] #186263
01/06/09 11:35 PM
01/06/09 11:35 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
Re: Trans blanket ? [Re: Kevins493] #186264
01/06/09 11:36 PM
01/06/09 11:36 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
Re: Trans blanket ? [Re: Duner] #186265
01/06/09 11:54 PM
01/06/09 11:54 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I have a CSR shield on my CRT 727...But I've since seen pictures of a CSR shield looking like burnt pop corn too.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Trans blanket ? [Re: Adobedude] #186266
01/07/09 12:09 AM
01/07/09 12:09 AM
Central NC
gch Offline OP
gch  Offline OP
Central NC
So is a blanket the only option for a stock bodied street car?Car in question is a 70 Dodge Polara.
Re: Trans blanket ? [Re: Kevins493] #186267
01/07/09 12:11 AM
01/07/09 12:11 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Thank you.
That gives me a much better look at that shield.
I'll have to call their tech like to see if one of those would fit on my trans.
Re: Trans blanket ? [Re: Duner] #186268
01/07/09 09:53 AM
01/07/09 09:53 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Been running Lofgren designed trans blanket for years. They fit GREAT and cover the critical area of the torqueflight.
Re: Trans blanket ? [Re: J_BODY] #186269
01/07/09 09:55 AM
01/07/09 09:55 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: Trans blanket ? [Re: J_BODY] #186270
01/08/09 10:24 AM
01/08/09 10:24 AM
Central NC
gch Offline OP
gch  Offline OP
Central NC
Thanks J_BODY
Re: Trans blanket ? [Re: J_BODY] #186271
01/08/09 12:50 PM
01/08/09 12:50 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Ive got one of the Lofgren blankets. They fit very well!!
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Trans blanket ? [Re: gch] #186272
01/08/09 12:54 PM
01/08/09 12:54 PM
Wellington, Ohio (20 minutes f...
MrMoparRacing Offline
If you need a Trans blanket I have an RCI that I only used a couple of times. It has a few small grease stains but that is it. For $50 it's yours!
Re: Trans blanket ? [Re: MrMoparRacing] #186273
01/08/09 01:15 PM
01/08/09 01:15 PM
organ
maximum entropy Offline
organ
fwiw, i have an rci on mine- fits fine. no overheating issues either. i think that's not even an issue as my heap is a street/strip 10 second monster that gets driven an hour to the track in 100+ degree heat, hot lapped, driven home, and my trans fluid temp has never gone over 200. ever. even when it was 114 last summer. i almost died on the way home. really. what matters is my car was fine. that's all that matters.
Re: Trans blanket ? [Re: MrMoparRacing] #186274
01/08/09 01:18 PM
01/08/09 01:18 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
I also use a Lofgren on my 69 Dart street/strip car. It only goes mid 12's but I like the additional safety factor. For what its worth I bought a brand new RCI and I couldnt get it to fit worth a crap so I sold it and got the Lofgren,its a little tight getting it in while the trans is in the car but definately less hassle than the RCI.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Trans blanket ? [Re: G-Money1320] #186275
01/08/09 09:54 PM
01/08/09 09:54 PM
Ma
Voluster Offline
Voluster  Offline
Ma
I use a RCI blanket on mine also and never had any heat issues.
I drive it on the street and race it never really gets over 180ish I still use the stock radiator and a 2nd cooler with a 8 inch j converter
Phil
